Old 10-04-2012, 10:54 PM   #1
justice2002
Member#: 332102
Default new gears or sti transmission?
So I know there's a lot of threads relevant to this but in all the reading I could not find an answer to my problem.
I'm building an 02 wrx and heard rumors that the tranny is a glass box if you venture too far above 300whp, grandid driving habits are a big factor. I've read up on STi swaps and just putting stronger gears in, both are costly and a pain in the ***, but which is truly more reliable?
justice2002 is offline   Reply With Quote
Old 10-04-2012, 11:17 PM   #2
rudymcskoody
Member#: 257618
2006 wrx
aspen white
This is highly debated. To be honest, mine blew at stage 2 power levels. I don't think it was my driving. Some say a heavy clutch will do it, witch I have. Could have been from the previous owner. I don't know for sure.
I wouldnt worry about it too much. I've heard of people with decent power and never had a problem. Just know it could happen and be prepared.
There are a few options. 6 speed is a good one. Finding all the parts you need can be a hassle, bit they are super strong. I've heard of people doing the hole swap for under 4k doing all the labor themselves.
Ppgs are vary strong, but pricey. I, myself didn't have the time to find all the things I needed for the 6 speed swap as my wrx is my only car and didn't have the money for ppgs. I ended up using the 08+ gear set. Cheaper then the other options and said to hold 400 whp ok. I don't plan on getting to 400whp so this option suited my needs. I had Cobb tuning do the work, got it back in a little less than a week.
At the moment I have an act heavy duty clutch, 300whp, 350wtq. I've had the new gear set for almost a year with no problems. Just don't forget to change the little speedo gear like I did. Its a little off but no biggie.
Hope this helped.
rudymcskoody is offline   Reply With Quote
Old 10-04-2012, 11:27 PM   #3
justice2002
Member#: 332102
Oh ok, I didn't know the 08+ gears were interchangeable. Ya, I don't plan to go over 400hp. And I still have the stock clutch in there for now. About how much did it cost for COBB to do that for you? If you don't mind me asking.
Old 10-05-2012, 12:08 AM   #4
rexblake
Member#: 178426
2010 S4
Gray
An RA gear set will hold 400whp, I ran mine for years with no issues. PPGs are not worth the money, an STI stock tranny will hold more power and be the same price if not cheaper.
Old 10-05-2012, 12:21 AM   #5
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
There are 2 reasons why the NON-sti tranny's fail.
1. The gears.
2. The tranny casings themselves.
All decent builders i've talked to say: "ALWAYS go STI," if you are going to put serious power through them. You can get away with aftermarket gears, but from what i understand.. the casing itself is what FLEX's under HUGE load... which breaks the gears. You need the gears to be strong, but you also need the Tranny casing to also hold the power.
Ask in the tranny forum.. they know far more.
DHRDAN is offline   Reply With Quote
Old 10-05-2012, 02:03 AM   #6
sc00by4life
Member#: 97135
nope.
RA gears are only marginally stronger than the stock 5 speed gears.
PPG 5 speed would be just as fine as the 6 speed.
Old 10-05-2012, 02:14 AM   #7
sfk1412
Member#: 290974
2005 WRX Wagon
I recently had the same question and also searched and searched. Finally I PM'd AndrewTech and told them I.couldn't afford PPGs and what a good option would be. This was their reply: " the 08 plus legacy gears, ra gears, and 09 plus gears are very similar with RA. Only strong stock gearset is the 6 speed." However I know alot of people that got there trannys rebuilt with the legacy gt gears and they seem to hold really well which is probably the route ill go being that it's the cheapest gearset and I don't plan on making more then 350~whp/Tq. Unless I run into a spare 5g for PPGs
sfk1412 is offline   Reply With Quote
Old 10-05-2012, 04:26 AM   #8
rexblake
Member#: 178426
2010 S4
Gray
Originally Posted by sc00by4life View Post
nope.
The old ones perhaps, the new ones are great. Mine ran 400whp plus for 4 years and still shifted smoother than my stock one ever did. I know they are strong.
Old 10-05-2012, 05:45 AM   #9
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
BTW its tq that breaks transmissions not hp
k04sti is offline   Reply With Quote
Old 10-05-2012, 06:48 AM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I am the Lord of the Transmission Forum. It is where I live and breathe. The amount of useful information given here so far hovers around 9%. Do the following exactly:
1. Choose Start-->Shutdown on your computer.
2. Dial (240) 683-1000
3. State your budget, your car and its mods, and your car's use
4. Converse about the options
Buying a gearset is a no ****ing around proposition. Take it as such. If you don't, you might as well send me 1/2 the projected cost and do nothing as at least my advice saved you 50%.
Old 10-05-2012, 06:57 AM   #11
rudymcskoody
Member#: 257618
2006 wrx
aspen white
They are not exactly interchangeable. I font mind telling you what Cobb charged me but they might. Give them a call and will be happy to give you a quote. I can tell you its the cheapest option.
Old 10-05-2012, 07:12 AM   #12
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
Hmmmmm........I would have said to just call Andrewtech and ask them.....but some people have their telephone number in their head (see post 10).
Call them. Ask them.
Old 10-05-2012, 08:20 AM   #13
and this is cross posted
Old 10-05-2012, 08:40 AM   #14
rudymcskoody
Member#: 257618
2006 wrx
aspen white
That's because they are lovers. Sorry I couldn't keep the secret anymore.
