#1 |
Member#: 290920
Hi I have a 2011 wrx sedan I and N invidia cattless downpipe Cobb sf intake with box spt cat back and my car is dyno tuned I have read that the factory bpv only hold to about 16psi I'm at 18 am I ok or should I up grade it I'm planing on getting a grimmspeed ebc Perrin top mount and new fuel pump and injectors. Thanks guys
#2 |
Member#: 316415
Vehicle:2006 WRX WRB |
False. Pretty sure the stock bpv holds up to about 21? Not sure exactly but I boost about 18 psi well and mine is holdin up fine.
#3 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
The 08+ WRX plastic BPV's are hit or miss. Some will work at 20psi and some will leak at 15psi. It's hard to tell when they're leaking. For the price, I think the Forge is well worth it for a Stage 2 car.
#4 | |
Member#: 283784
RMIC
Vehicle:2012 SWP WRX HATCH White |
#5 |
Member#: 294644
Vehicle:2011 WRX Agile Auto DGM 290.5whp 331wtq |
Xlubens right ive seen both i got lucky and mines holding up to 19 atm (crosses fingers)
#6 |
Member#: 290920
What does te forged one hold to and does it have that loud stupid woosh
#7 |
Big Ron
Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
You have done zero research. Go to the top of this forum and you'll see a post titled:
Hey everybody new to the forum: READ THIS! Now go read the damn thing. Inside is a post titled BOV FAQ. If you want to futz with your car, this is how you do it: 1. Research. 2. Research. 3. Buy. If you don't do the first two steps, it could lead you to motor shopping. L E A R N exactly what a BOV and BPV is and then you will know and have knowledge. Do it right or don't do it at all. |
#8 |
Member#: 261612
#9 | |
Member#: 245218
South East
Vehicle:2013 STI Limited Ice Silver |
You should add a grammar FAQ. It drives me nuts to see people post **** using the grammatical abilities of a 3rd grader. |
#10 | |
Member#: 263329
Vehicle:2011 Impreza WRX DGM |
#11 |
Member#: 270482
Vehicle:2011 forester xt corn fed td06 20g 8cm |
16 cent bov mod ftw!!! My plastic stocker holds 24psi with this mod.
#12 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
