#1 |
Member#: 313071
MWSOC
Vehicle:1998 Forester L White |
I bought a 98 Forester last fall and drove it for a couple weeks and discovered it had bad headgaskets (big surprise, I know). I was going to just get the heads resurfaced and replace the headgaskets until I happened across an 02 WRX on my local craigslist. It came with the motor and transmission and it was pretty cheap, so I decided to go get it,
![]() Instead of just replacing the headgaskets on the Foz (where's the fun in that? ) I thought I might as well just get rid of the pos Forester 2.5L, And put in the WRX EJ20, ![]() So, I pulled the 2.5L, ![]() ![]() ![]() And got to work... ![]()
#2 |
Member#: 313071
MWSOC
Jeez, look at that dirty engine bay, gross!
![]() Really nasty. So I decided to strip the engine bay, ![]() ![]() Clean up some problem (rusty) areas ![]() And repaint the engine bay, ![]() On to the interior... |
#3 |
Member#: 313071
MWSOC
Got the dash off,
![]() Locating dash harness, ![]() ![]() ![]() ![]() Removed the dash bar, ![]() Time to get the dash harness out of there... |
#4 |
Member#: 313071
MWSOC
Unplugging,
![]() ![]() Getting closer, ![]() Got it out! Whew! PITA. ![]() Now what? Get ahold of Brian at iWire. ![]() |
#5 |
Member#: 313071
MWSOC
Since the Foz is going to be motivated by forced induction the old crossmember had to go.
![]() Out of there! ![]() ![]() Sourced a crossmember from an early-90s turbo Legacy. ![]() Better get that bolted up... |
#6 |
Member#: 313071
MWSOC
Whew, been busy! Got the crossmember bolted up...
![]() Decided I'm going to run e85 (got an e85 station just a few blocks from my house), so a fuel pump swap was in order (along with injectors and a tune). Out with the old fuel pump.. ![]() ![]() ![]() ![]() And... |
#7 |
Member#: 313071
MWSOC
...In the with new. Actually, it's a used Walbro I bought from a fellow NASIOC member...
![]() ![]() Old pump off... ![]() New pump on... ![]() New pump in... ![]() Stay tuned... ![]() |
#8 |
Member#: 232060
Dude, as awesome as this is, your pictures are all out of wack.
#9 | |
Member#: 153412
MWSOC
Vehicle:1998 Impreza wrxRS Black |
#10 |
Member#: 171127
MAIC
Vehicle:62XX Rotated *Mo Displacement |
#11 |
Member#: 313071
MWSOC
Long time, no post. Busy, busy, busy!
Time for updates... Now that the Walbro fuel pump is installed, it's time to focus on the engine... Got the EJ20 up on the engine stand: ![]() |
#12 |
Member#: 313071
MWSOC
The stock TD04.
![]() Say by-bye! |
#13 |
Member#: 313071
MWSOC
Here today, gone tomorrow.
#14 |
Member#: 313071
MWSOC
The VF48 I'm going to be using:
#15 |
Member#: 313071
MWSOC
Before I install the VF 48, have to take care of the hotside. I'm going to run EL Fujitsobo headers and an Invidia uppipe.
First things first - I need to wrap the headers and the uppipe: ![]() Done! Well, not quite...going to spray 'em with some silicone protectant: |
#16 |
Member#: 313071
MWSOC
Now they're done!
![]() Installed: ![]() Seems like something's still missing... ![]() |
#17 |
Member#: 313071
MWSOC
VF48 installed:
![]() On to the injectors...need to get rid of these: ![]() And put in some ID 1000s (for the E85): ![]() |
#18 |
Member#: 313071
MWSOC
Next: colder plugs:
![]() ![]() Torque 'em proper: ![]() |
#19 |
Member#: 280149
MAIC
Vehicle:2004 Impreza WRX blue |
nice thread, I'm doing a wrx into my sf foz soon too
#20 |
Member#: 333468
RMIC
Vehicle:93 SS Black Pearl |
Sweet swap! I'm building a 22T to swap in my 95 L wagon. It's going slowly and expensively, lol.
#21 |
Member#: 313071
MWSOC
#22 |
Member#: 313071
MWSOC
Installed TGV deletes:
![]() Replaced the stock inlet with a Samco piece: ![]() Larger intercooler: ![]() |
#23 |
Member#: 251061
SCIC
Vehicle:2002 wrx wrb |
SWEET, subscribing.
#24 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
Nice project!
#25 |
Member#: 313071
MWSOC
Meanwhile...I had sent the Forester dash harness and the WRX engine harness off to Brian K. at iWire to be merged. Brian did an amazing job and was a great help when it came time to reinstall the harnesses: ![]() ![]() Whew! Glad THAT's done! ![]() |
