#6476 | ||
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
From the Kinugawa vs. Blouch thread in Built Motor Forum: Quote:
#6477 |
Member#: 149262
Vehicle:2003 03WRXw6sp/05FXT PSM |
Yeah you most def have to do your research on everything. Turbos, injectors, E85, all that stuff. Making a car better than stock and functional is way worth it! Any car stock is lame.
#6478 |
Member#: 176723
Vehicle:2005 WRX STi Platinum Silver Metallic |
My two pennies - I broke in my built motor/heads(r199c) with my two 044 T1R surge setup fed by my 255 running id2ks on 91. I'm on an AEM v1 and everything was great. Now switched over to e85 and my only tickle is my average of 12mpg. Man I love the torque!
My next major mod is either going to be a bigger turbo or a flex fuel capable stand alone. Most of my friends on other platforms with bigger setups and 1000+ whp recommended injector dynamics. None had failures and they ran lots of different fuel types. A friends 840hp integra ran e85 and id2ks for years without a hitch. That was enough for me. |
#6479 |
Member#: 152680
Vehicle:2002 ej22t 2.35 s363 surged aem ems 6spd wagon |
I try to do everything cheaper and different than everyone else., and 100% of everything myself (machine work, fabricating, tuning etc.)
This is what I've learned... I've saved major amounts of money being a DIYer... And the learning is priceless... But I'm also guilty of going too cheap, not buying the really good stuff, or using parts that are just too worn out to save money... I've learned that in the end, a good portion of the time- this has bitten me in the ass! Do it right, or do it twice... Sadly that's true more often than I'd like to admit!! |
#6480 |
Member#: 108163
Vehicle:2005 STI - 10.8@129 more in the works! |
Great time this weekend with the NF crew at the track. Awesome team, great support! E85 FTW!
(Car #33 vs. CTS-V) ![]() |
#6481 |
Member#: 159243
Vehicle:sg3 Turbo Tek Tuned Hakt Ecu e85 30r 6spd |
Damn you! That's the time slip I'm shooting for!
Congrats! No video? |
#6482 |
Member#: 156358
Vehicle:1995 Impreza 2.6RS-L RED |
Hey guys,
I just went to the track with my slow car. Race weight is 2400ish pounds with driver. I've been running E85 for about 1 year now, in my 1995 2.5rs-L (2001 2.5rs in a 1995 L shell) Engine is 2.6L 11.4:1 compression ratio with 440cc injectors. Naturally asperated. I'm still running the stock ECU, no timing and running pretty rich, so I'm basically at stock power levels. My best ET was a 14.6 and my best MPH 91.7 I'm having alot of problems with the tune, it breaks up at the top of 1st and 4th, and the car stops accelerating at around 90mph. I built the car for the roadcourse, so it launches and shifts very hard, which doesn't equal fast. Due to the suspension, and the tune difficulties my 60ft times wouldn't get any better than a 2.0. I'll post up time slips and a cell phone video eventually. Next year, I'll have around 190whp, and a 7000rpm redline (currently 6150rpm) and I'm expecting to be in the low 13s @ 100ish mph. Fast enough for NA. |
#6483 |
Member#: 159243
dw1300s plus e85 plus turbo tek E tune =
#6484 | |
Member#: 193014
Vehicle:02 WRX WRB, 05 STI FPGreen E85 400+whp |
#6485 |
Member#: 299040
Vehicle:2011 STI Satin White |
2011 STI
E85 Bosch 1180's Radium Surge/Dual Bosch 044's Elevation ~700 Temp ~65* ![]() Notes: TMIC is too hot @22.5psi to do more than one 3rd gear pull at a time when starting cold. |
#6486 |
Member#: 159243
cant seem to figure out how to do an airboy.
#6487 |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
Im turbo hunting for my 2010 wrx. Headers, dp walbro 255 and dw 1000's. i was looking at a blouch 20g but im liking the fp's, any suggestions? Question is geared toward reliability.
#6488 | |
Member#: 252195
RMIC
Vehicle:07 WFC #900 @ 451awhp-404awtq |
#6489 |
Member#: 159243
![]() ![]() 17#s. |
#6490 | |
Member#: 249068
South East
#6491 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
you need to lower your base weight to 3085....and the wheel size is probably wrong too. |
#6492 |
Member#: 159243
southern new jersey 08055.
it was 81 this afternoon, bit humid, but its nice now. gonna be low 80s at the track tomorrow. |
#6493 |
Member#: 159243
ill get the car weighed again tomorrow. i weigh 240. 02 wrx with 04 six speed. 04 bbs with 235 40 17 goodyear summer. 1/2 tank of E.
car was 3300 with me in it last year... |
#6494 | |
Member#: 249068
South East
#6495 | |
Member#: 249068
South East
#6496 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Ron's theory is to always go bigger. IMO, if you're dead set on being "reliable", then pick the power you think is safe and choose the smallest turbo that will get you there. No point in going bigger than necessary and having to deal with the extra lag and none of the payout.
#6497 |
Member#: 82064
Vehicle:2011 sti & evo ix white |
Jakes Base weight should be about 150 lbs heavier than a wrx, because of the transmission and other drive train components weight differences, Bigger brakes and a few other things. so i say a base weight of 3235 will probably be more in line. also the car has sti bbs wheels so the wheel size is accurate. which should bring his airboy down closer to 370 whp
#6498 |
Member#: 159243
theres a scale near me...ill get a proper measurement. just looking for a baseline anyway, we still have work to do.
#6499 |
Member#: 36033
SCIC
he said a couple posts above he has 235/40/17 which is 1/2" smaller than a 225/45/17 which is the stock tire in the spreadsheet. same wheels /=/ same diameter tire. the tire size will drop the power 15-20whp and the 100bs weight another 5-10.
#6500 |
Member#: 282204
Vehicle:2011 5 Door STi Plasma Blue Pearl |
ok take what you will from this but:
in General 10cm 8cm if auto-x or quicker spool, but 10cm for better top end and better breathability. (please note this is from my research but no actual first hand knowledge. Just lots of research and talking with 2.5xtr owners...) |
| Thread Tools | |
| Display Modes | |
| Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
| jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
| The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
| Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
| Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
