Old 10-04-2012, 11:32 PM   #1
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Default My e85 6262 2002 WRX - CORN FED
So I have been working on this thing forever, and kept running into issues. I finally just recently got it back together and on the road. A friend of mine on the local Subaru forum took some pictures for me and I figured I would post them up.
Quick run down of engine/drivetrain:
Sleeved 2.5l block
Manley Turbo Tuff Rods
Ross Racing 10:1 e85 Pistons
JDM v8 STi AVCS heads w/ Ferrea Valvetrain
FIC 2150cc Injectors
Aeromotive Fuel Rails
Precision 6262 Turbo
Precision Wastegate
e85
GPMoto Equal Length Header
Custom 3" Exhaust w/ Coast Fabrications Bullet Muffler
Custom Surge Tank Setup
Custom Oil Catch Can/Breather Tank
Tilton Twin Hybrid Clutch
05 STi 6mt with Rallispec Legacy Spec B Gearset
Hybrid SuberDave r180/r160 Axles
16x8 Rota Slipstreams
245/50/16 BFG G-Force Sports
JDM v8 STi ECU running Speed Density with a custom Carberry ROM
Tuned by Jason Carberry
Other items of note:
Bride Zeta III Seats
2004 USDM STi Rear Seats, Front Door Panels, E-brake, Door Handles, Carpet
JDM STi Type C Spec RA Rear Door Panels (crank windows)
JDM Power Folding Mirrors
JDM Projectors w/ Morimoto H1 HID Retrofit
Scoopless RS Carbon Hood
All kinds of Kartboy/TiC Bushings
DBA 5000 Rotors
H6 Rear Brake Upgrade
Here's a shot of the engine bay:
Photoshoot:
Rizzo314 is offline   Reply With Quote
Old 10-04-2012, 11:32 PM   #2
Rizzo314
Member#: 42215
Old 10-05-2012, 12:02 AM   #3
i50caL
Member#: 94899
91 GTR, 75 S30Z,
97 STI, EVO X?
#'s??
i50caL is offline   Reply With Quote
Old 10-05-2012, 08:14 AM   #4
Rizzo314
Member#: 42215
Originally Posted by i50caL View Post
#'s??
Don't have any yet.
Old 10-05-2012, 08:18 AM   #5
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Ohhhhh that's nice
2.5L Monster is offline   Reply With Quote
Old 10-05-2012, 09:05 AM   #6
Rizzo314
Member#: 42215
Here are some crappy pictures I took with my phone, but it shows some of the stuff you can't see from the outside.
The catch can:
The fuel surge tank, that fits under my full size spare:
And, if you hadn't noticed, it has the stock muffler on it. Why? Well, because I'm a genius and it's a discreet exhaust dump/turn down. The entire inside of the stock muffler is gutted. The 3" pipe comes in through the back and exits through the bottom of it. I thought it was pretty clever.
Old 10-05-2012, 10:36 AM   #7
CatfaceType-R
Member#: 81102
Good stuff, you're going to put some folks to sleep.
Old 10-05-2012, 10:39 AM   #8
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Ah good idear on that muffler. Sounds good facing the ground? Wanna hear
dirtslayer is offline   Reply With Quote
Old 10-05-2012, 10:44 AM   #9
mbs627
Member#: 99794
2013 FR-S
Darky dark
Like the beefy tire choice.
mbs627 is offline   Reply With Quote
Old 10-05-2012, 02:43 PM   #10
Rizzo314
Member#: 42215
Yea, the lack of a melon shooter and hood scoop make it pretty un-assuming.
This is before I added the Coast Fab muffler, but it actually doesn't sound too bad. The biggest difference is the EL manifold. If I had a standard style header/manifold on it then it would sound different.
Same here. I had to wait 4-5 months to get the Rotas from Japan because no one stocks them any more, but it was definitely worth the wait to get the look I wanted.
Old 10-05-2012, 03:09 PM   #11
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
I knew I've seen this somewhere before!
CarverSnell is offline   Reply With Quote
Old 10-05-2012, 03:13 PM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Is it fast?
This turbo seems like an intriguing choice. I'm very curious to see how the powerband looks.
xluben is online now   Reply With Quote
Old 10-05-2012, 03:49 PM   #13
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Stock 207 heads or cammed/chamber matched?
Old 10-05-2012, 04:11 PM   #14
bjohnson_55
Member#: 216580
Stock cams, I'm not sure about chamber matched. Nick can answer that.
It spools very well though.
bjohnson_55 is offline   Reply With Quote
Old 10-05-2012, 04:18 PM   #15
Jive Turkey
Member#: 219492
love the plates, i love the exhaust idea you did. its always nice to see things you've never seen before. keep it up!
Jive Turkey is offline   Reply With Quote
Old 10-05-2012, 04:43 PM   #16
07imprezRS
Member#: 164302
2011 STi Ltd Sedan
DGM & 02 WRB WRX
Looks awesome with the carbon RS hood as oppose to the other you had on the second vid. Sounds great 2. Curious about the numbers you'll put down as well.
07imprezRS is offline   Reply With Quote
Old 10-05-2012, 05:20 PM   #17
Rizzo314
Member#: 42215
http://youtu.be/e7tD9DQqLLw
Yep, that's me, haha.
Is it fast?
I'm hoping it will be.
They have mild port work with Ferrea valves, springs, retainers, etc. Stock JDM cams, and they are chamber matched.
What he said. It spools very nicely, and we're guessing it may even see full boost before or around 4000 rpm.
I have had the idea to do the exhaust this way for a long time now, but never got around to finishing it. The stock muffler is flanged, and I also have a Dynomax muffler that I can bolt on in it's place. It's amazing the stuff you can finally get done when you have a welder in your garage, haha.
Yea, the other hood came on the car when I bought it. I wasn't a huge fan and was happy to replace it with the RS hood.
I have an idea of the numbers I would like to see, but ultimately it will put down what it puts down. A local guy has an STi with a similar setup, but is running a 35r. He recently put down 601/534 at P&L. The 6262 sees more power per psi, so I should realistically be able to see about the same numbers. Although, with as long as I have been working on this thing, I would be happy with anything North of 400whp.
Old 10-05-2012, 08:32 PM   #18
25rsti
Member#: 166324
Awesome build but I think if you change your grille it would look 1000x better.
Old 10-05-2012, 08:49 PM   #19
07imprezRS
Member#: 164302
2011 STi Ltd Sedan
DGM & 02 WRB WRX
I'm sure with a proper tune you'll be over 400awhp. Those injectors should be able to handle that no problem.
Old 10-05-2012, 11:54 PM   #20
C J
Member#: 132587
2006 JrTuned STi
[email protected]
maybe on wastegate boost...I am sure with a sleeved shortblock he is looking for big power not scraps.
600whp easily on 30-35psi.
C J is offline   Reply With Quote
Old 10-06-2012, 01:33 AM   #21
T U R B U L N T
Member#: 160634
2oo6 STI
CGm with a beard.
All i have to say is respect this car.. well played sir!
your car is simple & right to the point everything is well put together
T U R B U L N T is offline   Reply With Quote
Old 10-06-2012, 06:15 AM   #22
561wrx
Member#: 166427
03 wrx
I totally love ur car
561wrx is offline   Reply With Quote
Old 10-06-2012, 07:12 AM   #23
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Double thumbs up brother! FTMFW!
Old 10-13-2012, 02:49 PM   #24
shano
Member#: 223839
2004 WRX
Java black
bad mahfackin ass
shano is offline   Reply With Quote
Old 10-17-2012, 07:35 PM   #25
Rizzo314
Member#: 42215
Originally Posted by shano View Post
bad mahfackin ass
Thanks. I do what I can.
