Old 10-05-2012, 12:19 AM   #1
EVT_Dan
Member#: 143534
Default Any difference between wrx and sti subframe (05-07)
Hi guys
I'm putting an Grp N quick steering rack in my 04 STi. I understand that to do it right, I need an 05+ front subframe.
Is the 05+ WRX and STi subframes the same ? I've seen vague references to different internal bracing. Can't find much info though.
EVT_Dan is offline   Reply With Quote
Old 10-05-2012, 10:24 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
part number appears to be different so there's SOMETHING different between them. What it is I am not sure.
Old 10-05-2012, 12:47 PM   #3
EVT_Dan
Member#: 143534
Hmm, interesting.
I'll keep looking for an STi version then, just to play it safe and stay STi
Old 10-05-2012, 12:52 PM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Subframe or crossmember?
The earlier STI subframe and crossmember required two extra/additional mounting bolts for a total of fourteen. For 2006 and 2007, these two additional mounting points were eliminated.
I can confirm that the front crossmember on my 2006 WRX is a factory OEM STI piece - it's stamped 'STI' on both legs where the jacking-reinforcement plate mounts.
