Old 09-06-2006, 11:23 PM   #1
GHOS Ti
Member#: 42067
gara ge not big enou
gh...need more space
Default STi Brembos vs Evo Brembos
Are they exactly the same? Just differ in color? Anyone know the dimensions?
GHOS Ti is offline   Reply With Quote
Old 09-07-2006, 12:11 AM   #2
nater
Member#: 105543
1965 Factory Five
Cobra, carbon fiber black
They are very very similar, but not the same. The biggest difference that I know of is that the evo calipers have an external line that connect the 2 different sides of the caliper, where as the sti calipers have the fluid line internally. Just visually, the casting appear to be very similar other then that...
nater is offline   Reply With Quote
Old 09-07-2006, 12:19 AM   #3
GHOS Ti
Member#: 42067
Would they be a direct replacement or would I need that external line you were talking about?
Old 09-07-2006, 12:23 AM   #4
NotoriousD
Member#: 97025
98 04 RSTI
RBP
The Sti brembros are alot sensitive than the evo brembros.. thats all i know.. sorry
NotoriousD is offline   Reply With Quote
Old 09-07-2006, 01:06 AM   #5
aznburn210
Member#: 84062
2005 WRX
CGM on Bronze Work's
i know the evo brembos perform better but thats do to weight of cars..
aznburn210 is offline   Reply With Quote
Old 09-07-2006, 01:35 AM   #6
ESmooth
Member#: 118082
The EVO calipers have larger pistons than the STi calipers..they would overbias the front if you managed to install them on an STi. They do use the same pads front and rear though.
ESmooth is offline   Reply With Quote
Old 09-07-2006, 12:43 PM   #7
SlvrRS
Member#: 39462
04 STi
Type R Spec Broken Wallet
and notice how the evo brembo's are mounted on the other side of the wheel (fore) than the sti (aft).
I've always kinda wondered the reasoning behind the mounting position of a caliper...such as in this case (either fore or aft on a particular wheel). what benefits and drawbacks are there for either position?
I don't see any heat dissipation advantage with either....stopping power either...seems arbitrary maybe, just depending on where the mfr. wants to run brake lines? I've never looked up any of this, it may as well be in another thread.
lets discuss
SlvrRS is offline   Reply With Quote
Old 09-07-2006, 12:49 PM   #8
ESmooth
Member#: 118082
caliper location is usually dependent on where there steering linkage and suspension connect. There is not benefit to a leading or trailing design, but the caliper should be clocked as cose to the 3 or 9 o'clock position as possible to reuce knockback as much as possible which is limited by the suspension.
Old 10-05-2012, 02:01 PM   #9
Frey Bone
Member#: 6252
2000 GC8 w/STI
OK, so this is an old thread, but because I'm interested in red calipers behind my black wheels (sorry, just one of those things)- I was thinking this would be a good option to do a simple swap- so far doesn't seem to be that way-
Anyone have a definitive answer?
Thanks,
Frey
Frey Bone is offline   Reply With Quote
Old 10-05-2012, 02:19 PM   #10
funk32
Member#: 245787
2004 STi
get STi ones and have them powder coated
funk32 is offline   Reply With Quote
Old 10-05-2012, 02:21 PM   #11
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
It is not a direct bolt on. The bolt centres distance is slightly different on the EVO vs STi, the bolt used is slightly different size, EVO has front mounted calipers and STI has rear mounted calipers (ie. Piston order is backwards).
People have use EVO Brembos with some mod you just have to search for it.
It will be easier to just paint your Brembos red.
minifreak is offline   Reply With Quote
Old 10-05-2012, 02:27 PM   #12
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
This. It's waaaaaaaay easier to paint than to make something fit.
Counterfit is online now   Reply With Quote
STi pad vs EVO brakes huytuan123 Brakes, Steering & Suspension 5 04-26-2006 11:05 AM
STI 10 vs Evo 9 vs HSV STI8U News & Rumors 35 01-07-2006 07:44 AM
Another Mini vs STi/WRX vs Evo challenge? HoRo1 Southern California Impreza Club Forum -- SCIC 32 04-27-2004 09:20 PM
Sti Brembos vs. Aftermarket Brembos tifosi77 Brakes, Steering & Suspension 4 02-14-2002 09:35 AM
