Old 10-04-2012, 09:56 AM   #26
lavid2002
Member#: 226864
Which parts go where? That was answered with the take pix / vids comment.
Old 10-04-2012, 10:06 AM   #27
the suicidal eggroll
Member#: 51961
2005 STi
Originally Posted by claythrow View Post
Also, I see blocks of all sorts everywhere, but I don't see many heads around. New, built or otherwise…My tuner said I should take care of that while I'm at it. Why are heads so much more scarce?
Mostly because head work is incredibly expensive without a whole lot of benefit unless you're pushing a lot of power (500whp+)
Cams are nearly $1k alone. Most decent cams have enough lift to require new valve springs, that's another $4-800. Aftermarket valve springs means new valves (unless you want to risk snapping a stock valve in half from the higher seat pressure), that's another $3-500. New valves means a valve job for another $200 or so. New valves/cams means new buckets, that's another $400. So far we're up to around $2500 and we haven't even ported the heads yet. Unless you're pushing a lot of power, there is much more you can do with that $2500 than do cams. There are low lift cams that don't require new springs/valves, but they're not really going to do anything for you versus the stock ones, so for the most part they're just a waste of time/money.
Old 10-04-2012, 06:52 PM   #28
claythrow
Member#: 283663
2004 STI
Root Beer
Ok, got the engine stand today, have the car jacks and stands creeper etc. it seems that harbor freight has just today stopped carrying the engine lift/crane. Ay other ideas of where to get a reasonably good one that won't break the bank?
Also, could someone direct me to the measuring equipment I should get/need? Car will be towed here tomorrow and if I had that damned engine hoist work could commence
claythrow is offline   Reply With Quote
Old 10-04-2012, 07:10 PM   #29
biodude
Member#: 271720
wow, when did HF stop carrying the hoist? that sucks
biodude is offline   Reply With Quote
Old 10-04-2012, 10:11 PM   #30
claythrow
Member#: 283663
2004 STI
Root Beer
Autozone has them. Picking it up tomorrow
Old 10-04-2012, 11:11 PM   #31
Nickerz
Member#: 43451
Anything is possible with enough time, patience and discipline. HOWEVER, the small things that are learned, and not actively shared can make a big difference. This is what sets apart people who are known engine builders, from the rest.
Nickerz is offline   Reply With Quote
Old 10-05-2012, 09:57 AM   #32
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Default yep
Definitly.. experience is a plus. tricks of the trade.. so take your time on the first build and your on the road to the addiction of engine building
99imprezd is offline   Reply With Quote
Old 10-05-2012, 04:00 PM   #33
lavid2002
Member#: 226864
I ran into very few problems my first time doing shortlbock work. I.E. I didn't put rags on my connecting rods and scratched a cylinder :|
It will definitely be a learning curve.
-Dave
Old 10-07-2012, 09:08 PM   #34
ctfjr
Member#: 297540
2011 STI
fwiw I'll throw my $.02 in also.
When I built my 1st motor (a complete 351C built from a 4 bolt block on up) I hired a dealer's mechanic to help me. The problem with doing it on your own is not even knowing the questions to ask - do you know what plastigage is and what its used for? I didn't.
If you can find a local Subie mechanic to come over for an hour or 2 every few days and pay him for his time to guide you, I think it would help you a ton and maybe save you some serious regret time & $$$
I think its great that you are tackling this - life is all about learning!
ctfjr is offline   Reply With Quote
