Old 10-01-2012, 04:52 PM   #1
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Default Main bearing choices
Has anyone on here used Clevite 77 bearings for EJ257? I am in process of building a motor for my 06 Sti and need to get some main bearings. Car is around 400whp and this build wont see much more than that. Motor being built is OEM crank and rods with Mahle power pack pistons.
My choices are
1. OEM bearings and they will run me around $130 with no shipping
2. Clevite 77 bearings which are same part number as Mahle bearings that I have been finding. Different part number than old Mahle Vandervell bearings. Not sure if quality of these are good and I would like to know if any engine builders have used them with good results. ~$50 + shipping
3. ACL bearings, Im kinda trying to stay away from them since I have read quality had went down and they are around $90+ shipping and that would put them around same price as set of OEM bearings.
bswilmington is offline   Reply With Quote
Old 10-01-2012, 05:24 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I have had good success with King race brgs.
john 1badSTI is offline   Reply With Quote
Old 10-01-2012, 05:35 PM   #3
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
+1
I've heard ACLs had an issue with clearance consistency. Kings can take a massive amount of detonation from what I've seen as well.
Old 10-01-2012, 05:45 PM   #4
john 1badSTI
Member#: 77470
^^^me too the acl rod brgs have been good but the mains are all over the board in consistancy.
Old 10-01-2012, 06:02 PM   #5
bswilmington
Member#: 217563
I have read the same info about ACL, thats one reason Im trying to stay away from them.
I have read good things about Kings, and looking at there website it shows they try to keep them consistant.
Have you guys been running the standard or extra oil clearance bearings. Looking to set my main clearance around 0.0012". Should standard set get me in ball park?
Old 10-05-2012, 02:30 PM   #6
Kyle_J
Member#: 292364
ISM
I recently built a new ej25 and had originally ordered clevite main and rod bearings. Installed the clevites in the block and rods to check clearances and they were all over the place, very inconsistent. Decided to order all acl race bearings. Main clearances specd out at with only .0003 variance, rods were all exactly .0021 clearance. 1300 miles later and they are doing perfect, no metal on my drain plug at the 1000 mile oil change. Also the mains I used were std, rods were hx's.
Kyle_J is offline   Reply With Quote
Old 10-05-2012, 03:31 PM   #7
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
i built a couple motors with king bearings and wasnt thrilled at the prep work i had to do to them including deburring to make them the same quality as a ACL bearing. If the customer is doing it themselves ive been suggesting Cosworth as they are pretty close to on the money. if im doing it i use ACL both h and hx. Bearings is not somewhere to cut corners... for the extra 40 bucks that the cosworth ones run they seem to check them twice before sending them out. just my 2 cents.
Bamofo is offline   Reply With Quote
Old 10-05-2012, 05:34 PM   #8
bswilmington
Member#: 217563
I've already ordered and got a set of the kings since I have heard pretty much all good things about them.
For what I read in past IIRC Cosworth bearing are made by ACL.
Old 10-07-2012, 10:39 AM   #9
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
Originally Posted by bswilmington
I've already ordered and got a set of the kings since I have heard pretty much all good thugs about them.
Yes they are made by ACL but cosworth checks them over before they send them out. My cosworth/ACL bearings were spot on the first try which to me is worth the extra 40 bucks to not have my motor apart for another week waiting for more bearings to show up.
woodys77 is offline   Reply With Quote
Old 10-08-2012, 11:29 PM   #10
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
All my builds and friends builds have been ACL and never had issues with them. Clevite; Ive had a spun bearing under 200 miles on a fresh shortblock build and never used them again.. may have been a fluke incident but spun a rod bearing on break in. Whats the difference between Kings and ACL's?
99imprezd is offline   Reply With Quote
