Old 10-05-2012, 07:43 PM   #1
joeyb504
Member#: 171586
2004 Wrx
Default Whining noise while driving?
Hello everyone new here. I have a quick question was driving home tonight without the radio on I could hear while I was in 5th gear a whining noise while accelerating it was to loud but would go away when I let off the gas. It doesn't do it at idle and haven't hear it in lower rpms or other gears. Any ideas thanks!
joeyb504 is offline   Reply With Quote
Old 10-05-2012, 07:47 PM   #2
jimbosv650
Member#: 261307
04 wrx wagon
Maybe a boost leak. Check all vacuum hoses and hoses coming off the turbo. Also check the bpv is bolted snug if you've messed with that recently.
jimbosv650 is offline   Reply With Quote
Old 10-05-2012, 07:49 PM   #3
joeyb504
Member#: 171586
2004 Wrx
No haven't messed with anything it's all stock. Really only noticed it today while in 5th and noise stops when I take my foot off the pedal. Don't think this is trans diff related? Thanks for the quick response!
Old 10-05-2012, 08:03 PM   #4
rob1n1
Member#: 276425
Turbo spooling up?
rob1n1 is offline   Reply With Quote
Old 10-05-2012, 08:07 PM   #5
joeyb504
Member#: 171586
2004 Wrx
Ya I can hear the turbo spool different sound. It's not super Lou can only hear it without the radio on?
Old 10-05-2012, 10:00 PM   #6
joeyb504
Member#: 171586
2004 Wrx
Anyone ideas?
Old 10-05-2012, 10:07 PM   #7
wowjason62606
Member#: 325356
2005 Impreza wrx sti
Haha I just had this problem if it's only 5th gear at speed your hearing likely 1 of 2 things wind noise over the mirrors try folding them in just to see
Or
Front diff is whining
I had this problem an found out for me it was the wind and mirrors others have said they tried that but no fix and found out it was the front dif but was not a problem and not damaging anything
Google it and you can see tons of threads about it.
Hope this helps you
wowjason62606 is offline   Reply With Quote
Old 10-05-2012, 10:21 PM   #8
joeyb504
Member#: 171586
2004 Wrx
Can rule out the mirrors it only happens while I'm on the gas and immediately goes away when I let off the gas
Old 10-05-2012, 10:31 PM   #9
bigdog826
Member#: 314841
2001 2.5 RS
this happens to my car. fill out your profile so we can see what you drive. i have an 01 RS 5 speed and that happens to me in fourth gear. whines then goes away when i let off the gas. i believe its either differential related or possibly transmission
bigdog826 is offline   Reply With Quote
Old 10-05-2012, 10:43 PM   #10
joeyb504
Member#: 171586
2004 Wrx
I drive an 04 wrx about 115k is this something to be worried about.
Old 10-05-2012, 10:45 PM   #11
Jack ffr1846
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I get whining like that sometimes. It only goes away when I give the evil eye to my kids in the back seat.
Jack ffr1846 is offline   Reply With Quote
Old 10-05-2012, 10:58 PM   #12
CrazyOC949
Member#: 330460
2012 WRX Hatch
Hahaha
CrazyOC949 is offline   Reply With Quote
Old 10-05-2012, 11:12 PM   #13
Napalm3nema
Member#: 263954
2013 STi
Dark Gray
If you'd get your wife out of the trunk, and let her ride in the car you'd hear a lot less whining. I tell you, if I had a nickle for every time I heard 'When I slip these restraints, you're in for it!' Whine whine whine whine. <makes talking hand motion> She was much more agreeable when she rode up front. (it was her Birthday)
I tell you...good times...good times.
Napalm3nema is offline   Reply With Quote
Old 10-05-2012, 11:22 PM   #14
tommyson01
Member#: 154579
2002 WRX Wagon
PSM - Sold
First, which car/year do you have?
Does it sound like a supercharger whine? If so, check your AC idler pulley.
tommyson01 is offline   Reply With Quote
Old 10-05-2012, 11:24 PM   #15
joeyb504
Member#: 171586
2004 Wrx
2004 wrx. It does sound like a supercharger wind. Can't hear it with the radio on goes away when I take my foot off the pedal noticed more higher speeds
Old 10-06-2012, 12:26 AM   #16
tommyson01
Member#: 154579
2002 WRX Wagon
PSM - Sold
My guess is the AC idler pulley. Take the AC belt off and go for a drive.
Old 10-06-2012, 12:34 AM   #17
joeyb504
Member#: 171586
2004 Wrx
Thanks I will try that never thought that would make that Kim if noise with the a/c not even on. Why does the pulley cause this noise ?
Old 10-06-2012, 01:19 AM   #18
tommyson01
Member#: 154579
2002 WRX Wagon
PSM - Sold
It's because the bearings on the pulley are going bad. Even with the AC off the belt/pulley still spins, the AC clutch just isn't engaged.
Old 10-06-2012, 02:06 AM   #19
djtypewhazn
Member#: 292747
i noticed the same thing in my 11wrx. believe its the ac pully. next time it happens turn ur ac off. it sounds almost like alternator whine
djtypewhazn is offline   Reply With Quote
Old 10-06-2012, 09:29 AM   #20
joeyb504
Member#: 171586
2004 Wrx
Wouldn't I hear that all the time then. Even at idle. Or just under acceleration?
Old 10-06-2012, 05:33 PM   #21
Coldcutt
Member#: 280459
2002 WRX w/ej207 v7
its likely your rear differential, does the noise happen right around 58-65mph?
Coldcutt is offline   Reply With Quote
Old 10-06-2012, 05:47 PM   #22
jerrywayne
Member#: 295261
2008 WRX Stg II
Pearl White
I had the exact same thing happen in my 08 wrx in 5th gear. Happened to be the center diff, and 4,000$ of warranty work later.
jerrywayne is online now   Reply With Quote
Old 10-06-2012, 07:48 PM   #23
joeyb504
Member#: 171586
2004 Wrx
ya i noticed it in 5th gear happens in all gears to be honest its very faint would go away when i took my foot off the pedal
Old 10-06-2012, 10:20 PM   #24
joeyb504
Member#: 171586
2004 Wrx
if was a diff wouldn't it make a clunking noise while turning?
Old 10-07-2012, 12:37 AM   #25
Coldcutt
Member#: 280459
2002 WRX w/ej207 v7
If it were the differential gears. The ring gear may be worn, or out of true.
Message Board Statistics All times are GMT -4. The time now is 02:03 PM.
