Old 10-02-2012, 09:26 PM   #1
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Default car dies coming off throttle..........
car keep stalling and dieing when coming off throttle, mainly if im cruising around 2000-3000 and come off the throttle it dies. Idle is set to 700 and its a newly built longblock with sharp cams and hard springs. would raising the idle correct this or messing with tip in?? thanks ahead of time for the help.
Old 10-04-2012, 10:58 AM   #2
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I'm going to guess that you have a lightweight flywheel also? If your fueling is off with the cams it will cause a stall. If all fueling is good and you have a light flywheel you will need to raise the rpm threshold for cutting the injectors back on once you let off the throttle. You could just have a dirty iacv. Try raising the idle to 1000 rpm. If it doesn't help then one of the above will fix your problem.
fastblueufo is offline   Reply With Quote
Old 10-04-2012, 11:18 AM   #3
the suicidal eggroll
Member#: 51961
2005 STi
I've heard that some DBC cars need to have a small hold drilled in the throttle plate after installing large cams because the IACV just can't flow enough air to catch it properly at idle. Just rumor though. You may also try raising your idle up a couple hundred RPM.
Old 10-05-2012, 09:13 PM   #4
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
You could also tighten the set screw on the throttle to slightly kick open the plate rather than drill it.
