Old 10-04-2012, 10:51 PM   #1
fabioguc
Member#: 290920
Default Couple questions bout my 2011 wrx
Hi I have a 2011 wrx sedan I and N invidia cattless downpipe Cobb sf intake with box spt cat back and my car is dyno tuned I have read that the factory bpv only hold to about 16psi I'm at 18 am I ok or should I up grade it I'm planing on getting a grimmspeed ebc Perrin top mount and new fuel pump and injectors. Thanks guys
fabioguc is offline   Reply With Quote
Old 10-04-2012, 11:05 PM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
False. Pretty sure the stock bpv holds up to about 21? Not sure exactly but I boost about 18 psi well and mine is holdin up fine.
Old 10-04-2012, 11:12 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The 08+ WRX plastic BPV's are hit or miss. Some will work at 20psi and some will leak at 15psi. It's hard to tell when they're leaking. For the price, I think the Forge is well worth it for a Stage 2 car.
Old 10-04-2012, 11:16 PM   #4
Jdub.csu
Member#: 283784
2013 EVO X GSR
Mine is failing already and I'm 19psi. I only have 7K miles on mine stage 2+ now it makes a really bad noise and won't hold boost. Oh well it's getting replaced.
Jdub.csu is offline   Reply With Quote
Old 10-04-2012, 11:27 PM   #5
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Xlubens right ive seen both i got lucky and mines holding up to 19 atm (crosses fingers)
freddy121389 is offline   Reply With Quote
Old 10-05-2012, 05:52 AM   #6
fabioguc
Member#: 290920
What does te forged one hold to and does it have that loud stupid woosh
Old 10-05-2012, 06:41 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You have done zero research. Go to the top of this forum and you'll see a post titled:
Hey everybody new to the forum: READ THIS!
Now go read the damn thing. Inside is a post titled BOV FAQ.
If you want to futz with your car, this is how you do it:
1. Research.
2. Research.
3. Buy.
If you don't do the first two steps, it could lead you to motor shopping. L E A R N exactly what a BOV and BPV is and then you will know and have knowledge. Do it right or don't do it at all.
Old 10-05-2012, 08:19 AM   #8
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Forge holds 30+ psi. It's one of the quietest valves out there (fully recirculating).
Old 10-05-2012, 03:13 PM   #9
Tripintaz
Member#: 245218
2013 STI Limited
1. Research.
2. Research.
3. Buy.
You should add a grammar FAQ. It drives me nuts to see people post **** using the grammatical abilities of a 3rd grader.
Old 10-05-2012, 04:05 PM   #10
cineris
Member#: 263329
2011 Impreza WRX
There was a sticky about that. I don't remember which one, but basically it was a do's and dont's list for getting along on the forum.
cineris is offline   Reply With Quote
Old 10-05-2012, 06:55 PM   #11
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
16 cent bov mod ftw!!! My plastic stocker holds 24psi with this mod.
nate_fisher is offline   Reply With Quote
Old 10-05-2012, 09:31 PM   #12
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
great valve. ive used mine for about 2 years,no issues.
