#1 |
Member#: 213428
TXIC
Vehicle:2008 Red STi Hatch Enough pony power |
Getting a meth AEM kit for my 08 sti. I've searched for pictures but, so far no pictures found.
Wondering if anyone has any ideas or experience with mounthing these on a GR STi.
#2 |
Member#: 13815
SCIC
Vehicle:02 GCRally prepped 277TQ 281HP 19PSI |
I just tapped a hole in the bottom of my IC last night. Ill post up pics when I get off of work. Basically just behind the coupler on the tank of the intercooler.
#3 |
Member#: 213428
TXIC
sorry, should have been more specific.
Looking where to mount the tank, where the meth goes. Hatch style is kinda weird in the back. There's no flat surface to mount it onto. |
#4 |
Member#: 68448
NWIC
Vehicle:2008 WRX STi Cobb tunned by Surgeline |
I will get you pics today of my placement. ya the 08's are a pain for tank location. I am looking for a flat 2G tank to sit in the spare tire well with my pump.
#5 | |
Member#: 159745
South East
Vehicle:2007 drunkman tuned mega meth |
Don't do this, it should be placed as close to the throttle body as possible, in the coupler if possible, that way if you want to sell your top mount you can later at a good price. but if you place it further away the atomized droplets will clump together and cause you meth to be less effective |
#6 | |
Member#: 120641
NWIC
Vehicle:05 HTA3586,BB 2.5L CGM |
Where he describes its about 3" from the throttle body and in the perfect spot. |
#7 | |
Member#: 92467
Vehicle:08 STI Silver |
or put the pump here and just drill out a Heineken mini keg can as the tank. That shouldn't take up too much space. |
#8 |
Member#: 71875
Vehicle:98 2.5GT my wheels fit |
also you could use the howerton engineering tank and pump housing:
#9 |
Member#: 213428
TXIC
Thanks for the replys and pictures. i'll get pics of my setup asap.
#10 |
Member#: 89554
Vehicle:2006 EVO SE Black E85 30PSI dd |
#11 |
Member#: 71875
pictures from the three HFS-6 installs I've done (at HB Speed):
http://jamalb.net/gallery/v/HFS6/ I think I have some pictures from an HFS-5 in an 08 somewhere as well. Last edited by jamal; 09-23-2009 at 04:24 AM. |
#12 |
Member#: 89554
Yeah im looking more specifically at the howerton tank, and how it fit in that car.
#13 |
Member#: 122306
South East
Vehicle:2002 Sti PTE 6262sp Interlagos Blue 551/441 |
I did an install in a outback xt not long ago mounted the pump and tank on an aluminum plate and put it in the passenger side fender under where the air filter is. easy to fill location and very hidden.
#14 |
Member#: 137265
Vehicle:2004 SRT4 BLACK |
You can get pretty creative with installs but its an individuals ingenuity that makes thing work or not with hiding things or in making something look like it belongs versus looking like it was slapped or just added on as an afterthought.
If you want to hide things for instance, like the lines, you can install nylon sheathing over the lines and use heat shrink tubing. The same stuff is used by the OEM's on harnesses and hoses. The sky is the limit and most of what can be potentially be done is up to the user. Kits as sold leave open many options of what can be done with some thinking. Most kit makers want pump and tank installed in the trunk to help protect the components. How you mount these to the body can be as fancy just simple bolting them down as is to the use of aluminum stock found at Lowes or Home Depot to make brackets to going with something like a setup from Howerton. As a basic guide for background info, use plastic tanks, taller but yet have sufficient total volume is better then shorter and more squat. Have the pump inlet lower then the tank outlet supply fitting in the tank and try to avoid any sharp turns in the lines. Mount the tank so that its easy to fill and easy remove. Mount the pump so it has some room around it = do not pack it into a spot that causes problems with service or kinked lines. |
#15 |
Member#: 293354
I'm also installing the arm meth, And I do not want to install it in the rear. I have an 08 hatch and I'm concern about the fumes that meth can produce inside the car! So I installed the tank infront of the washer tank. And the pump also in the same spot. Very thin is properly secure! The only bad thing is that I have to remove my bumper to fill up the meth tank and that sucks! Now I'm trying to find ideas for a neck to add to the tank. I will up load pics tonight!
![]() ![]() ![]() ![]() Last edited by quierototolive; 10-05-2012 at 09:43 PM. |
#16 | |
Member#: 293354
![]() ![]() ![]() ![]() I still need to wire the controller and run all wires! To fill the tank up I was gono have to take the bumper out ( I did t mind since it takes 2 minutes) But I got a smaller battery and now all I have to do is move it to the side And I can fill up! Last edited by quierototolive; 10-05-2012 at 10:01 PM. |
#17 |
Member#: 78640
NESIC
Vehicle:08 STi SSM |
Wondering if anyone has any trunk mounted tanks in a GR chassis STi or WRX? Really not trying to mount it in the front bumper but haven't seen all that many other solutions.
#18 |
Member#: 88939
Vehicle:2011 WRX STi Hatch World Rally Blue |
Quierototolive, do you find that with this 'behind the bumper' installation that the pump is adequately protected from the elements? It doesn't get wet from road slop, does it?
I also don't want to put the tank in the back of my hatchback, but there are few options (no space) for a complete 'under the hood' installation. Is this working out okay for you? Did you conisder and reject using the windshild washer fluid tank (1.0 gal) for your meth/water solution? If so, why? Thanks for any input.................... Frank |
#19 |
Member#: 318755
South East
Vehicle:2012 Phatbotti Tuned |
Heres Jockeygolfs meth tank in his 2011 STI sedan
#20 | |
Member#: 293354
Hello! Sorry for the late response! I checked last night and where I installed the pump its a good place! It was clean no debris from the weather and everything also seem to be in the correct proper place. (Note; remember I have my fender liner so that covers everything well). I was able to connect everything under the good the pump and tank! Then I ran all my wires to the right side of the car in to the cabin ( that is a little pain in the a..) which is the reason I haven't finish my wiring; I still need to connect the little controller box for the kit. Im thinking I'm goin to install it inside the glove compartment ( will post pics when done). As far as the stock washer tank, I did reject using my washer tank as my meth tank jus for the fact the I use my windshield washer a lot. (Meth will be use more and it is more expensive than washer fluid) And also for warranties purposes! This might sound stupid but I'm trying to keep my car as close to stock as possible! Just so I can cover it under warranties if need it! |
#21 | |
Member#: 92710
Vehicle:2008 STi Obsidian Black Pearl |
#22 |
Member#: 88939
Thank-you so much for your help, Quierototolive and Rube23. I appreciate your efforts on my behalf.
And you've convinced me that this is the way I want to go with my hatchback. I presume that under the bumper cover, behind the headlight, there is sufficient and suitable structure into which holes can be drilled and the pump bolted? Again, thanks.................... Frank |
#23 |
Member#: 171837
NWIC
Vehicle:1999 2.5 RS Orange-Black |
I have 99, but I have the same in bumper placement. My battery is moved to the trunk for space.
http://www.subaru25b.com/2012/10/the...d-to-meth.html |
| Thread Tools | |
| Display Modes | |
| How to check transmission fluid on 08+ sti? | vzezera | Transmission (AT/MT) & Driveline | 2 | 02-22-2009 08:20 PM |
| Parrot kit modules - where to put them in an 08 STi? | cyanb | Car Audio, Video & Security | 0 | 07-07-2008 11:13 AM |
| Where to mount portable nav in 08 WRX? | MrElussive | Interior & Exterior Modification | 0 | 03-19-2008 06:05 PM |
| where to mount extra bung on divorced wastgate downpipe. | fastlanerex | Factory 2.0L Turbo Powertrain | 6 | 06-28-2007 06:09 PM |
| Where to mount hood pins on cf hood | krystek | Newbies & FAQs | 3 | 11-07-2006 01:44 AM |
