Old 08-31-2012, 08:46 PM   #1
rotheee
Member#: 291964
Question 03 Bugeye - My Issue with limp mode
My 03 WRX is currently sitting in limp mode. Had for awhile now, been looking it over reading this forum, getting help from a few buddies. Can't figure it out. I just picked my car up from IPS Motorsports here in Columbus, Ohio after it was sitting there for a month getting worked on on and off. Basically they told me there lost in fixing it and i just gave up on them and picked it up. When they run diag on it they are getting a boost leak @7psi they said. Can't find it, tested the system to 30psi and can't find a single leak. My IAM drops to like 8 sometimes, but only when i get into boost(So i'm getting knock from something). And i get instant Limp mode once i hit like 13-14psi(Tuned for 21psi)
So i'm asking everyone what could it be?
DW 650cc injectors
Invidia Full Exhaust
VF39
Perrin Turbo Inlet
FMIC
Grimmspeed BCS - Brand new (IPS Swapped it out from my ProDrive)
HKS SSQV 4
255 Fuel Pump
Fidanza Lightened Flywheel
ACT Extreme Performance Street Clutch
rotheee is offline   Reply With Quote
Old 08-31-2012, 08:47 PM   #2
rotheee
Member#: 291964
Maybe a bad intake manifold gasket?
Old 09-02-2012, 11:57 AM   #3
rotheee
Member#: 291964
Seriously no one has anything to say or comment on? 65+ views, 0 Replies. At least im not getting any bashing. hahah
Old 09-02-2012, 12:08 PM   #4
DannyMph
Member#: 287277
2003 Impreza WRX
For those reading in and out, that might not know to what he's referring to: http://www.grego.ca/limp.htm
I personally am not sure what can be wrong. Might just need to replace the computer. Sounds like you should contact Subaru.
DannyMph is offline   Reply With Quote
Old 09-02-2012, 02:21 PM   #5
10MTN-bugeye
Member#: 288093
2002 Bugeye
PSM and parking lot scars
What is the MAP reporting with the engine off? At idle? Did the motorsports guys check you manifold harness? It carries all of the signals from the sensors to the computer. My car had a "map sensor high circuit" CEL and would cut fuel and timing every time I hit wastegate spring pressure, after my first turbo swap. I spent weeks ordering sensors, cleaning grounds and checking for boost/vacuum leaks. Eventually, I got ahold of a use engine harness from another member. After I installed it, the problem disappeared.
10MTN-bugeye is offline   Reply With Quote
Old 09-02-2012, 10:24 PM   #6
rotheee
Member#: 291964
I honestly don't know what the MAP was reporting when the engine is off and at idle. They said they were getting crazy readings from it and i suppose they fixed the problem. CHecking the harness i really highly doubt they did. Hey would you go about checking it and what would i be looking for? ( i know pike pinched or broken wires, but anything else?)
Old 09-03-2012, 08:12 AM   #7
quazimoto
Member#: 70395
Posting datalogs would probably be a wise idea. It's not like we can see your car in person or ride in it. Take the car to a different shop.
Old 09-03-2012, 01:53 PM   #8
rotheee
Member#: 291964
Yeah ill try to get on that asap. Going to have to burrow a friends laptop cause mine won't open the logger and the g/f has a mac
Old 09-03-2012, 01:54 PM   #9
rotheee
Member#: 291964
Anything in particular you would like me to log?
Old 10-05-2012, 10:46 PM   #10
cantA4dit
Member#: 334258
ive been tryin to help him with his heap a little lately, i can email anyone the log after the ecu had been reset, 3rd gear pull from around 2500 to 6000, you can see half way through where the IAM drops from 16 to 12 to 8 relatively quickly. I am new to data logging and tuning theory but i am now aware that IAM isnt affected by FLKC. will do some more logs with different parameters asap
cantA4dit is offline   Reply With Quote
