Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 10-04-2012, 07:16 PM   #1
Qazyip
Member#: 320809
Default Will 2004 STI cluster fit on 2005 WRX prefectly?
Hi,
I am ready to get one of the 2004 sti cluster for my 2005 wrx,I am wondering will that be fit directly without cutting, clipping , trimming , modding or anything? Please let me know if you guys have the experience .
Thank you!
Qazyip is offline   Reply With Quote
Old 10-04-2012, 07:27 PM   #2
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Yes. 04 STi cluster is your best bet. 0 Modification. The only issue is the Rear Diff temp light will always be on. I opened up my cluster and taped over the light. Temperature will always read 43 degrees or other random degress unless you have an 05 WRX limited aka sun roof version
Jubert69 is online now   Reply With Quote
Old 10-04-2012, 07:51 PM   #3
Qazyip
Member#: 320809
Yes mine is the 2005 wrx limited heat seats sun roof version , it still work prefect right?
Old 10-04-2012, 07:53 PM   #4
emazz104
Member#: 281811
04 WRX
Is there a way to make the temperature work? I have a 04 WRX with the sunroof but no thermometer, I was looking at a 04 STi cluster. I'm assuming it's the same deal as what you are talking about? Can you wire the thermometer? Thanks.
emazz104 is offline   Reply With Quote
Old 10-04-2012, 11:41 PM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Yeah, then you're all set. Again, the Rear Diff light will be on since it's STi only, so if that bothers you, open up your cluster very carefully and tape the bulb from showing light.
IIRC 04 does NOT have auto climate control so the temperature doesn't work. You can get it to work, but it's a bit of a hassle. If you search, there should be a thread on how to install one. 05 had the climate control in the limiteds.
Old 10-05-2012, 01:44 AM   #6
sc00by4life
Member#: 97135
you will need to match the mileage.
Old 10-05-2012, 10:22 PM   #7
Qazyip
Member#: 320809
Yes i finally installed it , it came out almost perfect to me , but I dont know why the ABS light on, is there any way that I can turn it off??
