Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 10-03-2012, 08:02 PM   #76
ABQautoxer
Member#: 198231
2007 Not a Subaru
7400rpm.
ABQautoxer is offline   Reply With Quote
Old 10-03-2012, 08:26 PM   #77
jprice130
Member#: 288225
2013 FR-S
Originally Posted by Scooby South View Post
2nd gear in mine goes to 59.4 mph with my rim/tire package according to my GPS. A tune will raise the redline to 8K and 63.3 mph which is sufficient for 0-60 and most Autocross courses.. The Soft limiter makes the car hard to drive as it gives up for what feels like ever before it re-engages...:/
Bill
I have an automatic BRZ and I hit 63 MPH at the top of 2nd gear. It's the ONLY thing that makes the automatic semi-redeemable. Even still, I'd rather have the manual that tops out at 59 (for many obvious reasons). I ran a manual FR-S at our last local event and it noticeably has more punch coming out of low speed turns due to the shorter gearing.
As others have said, a taller tire and a raised rev limiter should really hit the sweet spot for the manual. I'll just keep driving my silly automatic and hope for more courses that have long run-ups to the timing lights instead of starts that favor launching.
jprice130 is offline   Reply With Quote
Old 10-03-2012, 08:59 PM   #78
Simmons-Racing
Member#: 274179
2013 Subaru BRZ
I have a Perrin Tune coming for the car
Simmons
Simmons-Racing is offline   Reply With Quote
Old 10-04-2012, 10:53 AM   #79
04trailsti
Member#: 179170
Originally Posted by spaceywilly
It is fuel/timing. It just lowers the rev limiter to whatever RPM you want to launch at. They also increased the 2nd gear fuel cutoff to 8000rpms, so that 0-60 doesn't require a shift to 3rd.
Mrt/ bret middleton has a video on youtube that shows adjusting the LC using the cruise control.. Pretty sweet.
04trailsti is offline   Reply With Quote
Old 10-04-2012, 12:55 PM   #80
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Bill
That's what I was getting at, was that Ecutek may be able to change the limiter to a hard limiter instead of the soft limiter. So you can just bang off it and not really affect the car that much. Since they have already implemented launch control it doesn't seem like much of a stretch. Just unplug the clutch switch, set the LC to like 8000 RPM, and drive the car.
They are doing some very cool things with map switching, launch control, etc. controlled via the cruise control stalk. which is part of the RaceRom stuff. It's supposed to be out pretty soon.
dwx is offline   Reply With Quote
Old 10-04-2012, 01:09 PM   #81
ABQautoxer
Member#: 198231
2007 Not a Subaru
This is making it harder and harder not to run STX...
Old 10-04-2012, 02:12 PM   #82
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
the more the merrier...
Scooby South is offline   Reply With Quote
Old 10-04-2012, 06:45 PM   #83
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Originally Posted by Simmons-Racing View Post
I wanted to use the curved wallom, when I built the course. You run out of ideas for course design at that location.
Simmons
Not a knock on the course design at all, just an observation.
PKer is offline   Reply With Quote
Old 10-04-2012, 06:55 PM   #84
Simmons-Racing
Member#: 274179
2013 Subaru BRZ
I knew what you meant.
Thanks,
Old 10-04-2012, 07:05 PM   #85
Simmons-Racing
Member#: 274179
2013 Subaru BRZ
I got the rest of my exhaust today from JSC Speed.
Perrin over pipe, and Perrin front pipe with hight flow cat. Easy to install(with a lift) nice quality parts. I saved 5.51 lbs total. It sounds awesome now. Before with just the Perrin cat-back non res you couldn't realy hear it in the car just outside. Now you can hear it inside(not to loud) and it sounds even better outside.
Simmons
JSC Speed http://www.jscspeed.com/catalog/Subaru/2013_BRZ.html
Old 10-04-2012, 10:12 PM   #86
Simmons-Racing
Member#: 274179
2013 Subaru BRZ
Old 10-05-2012, 10:09 PM   #87
Annihilator817
Member#: 296742
'11 WRX, '96 328i,
'92 Civic SiR, '94 Civic
Sounds like a Honda ;-)
Annihilator817 is offline   Reply With Quote
Old 10-06-2012, 12:56 AM   #88
OrbitalEllipses
Member#: 178811
2013 ****ing ricer
mobile >:(
That Perrin exhaust sounds a bit buzzy, just a bit too high-frequency on the top end for me. Really, I just miss what my WRX sounded like.
OrbitalEllipses is online now   Reply With Quote
Old 10-06-2012, 01:09 AM   #89
ABQautoxer
Member#: 198231
2007 Not a Subaru
I think it could just be the lack of a resonator as videos with it didn't sound that way I don't think.
Old 10-06-2012, 11:06 AM   #90
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
It's not really buzzy, I think it's just the recording, although the non-resonated version is definitely a little higher pitched than the resonated at some times.
I also wish I had a way to make it sound like a real Subaru, but I have resigned myself to that not happening since I don't want to replace the header.
Old 10-06-2012, 11:36 AM   #91
Draken
Member#: 16
1968 Saab
Sonett II V4
I think it sounds awesome. Nice growwwwlllllllllll.
Draken is offline   Reply With Quote
Old 10-08-2012, 12:27 AM   #92
04trailsti
Member#: 179170
I wish I had video of it, but today at NCAC there was a wrb BRZ with custom exhaust. Straight pipe from the cat-back flange to a ~20in. Magnaflow. Then back to a split off to dual tip. One of the best "suby rumbles" that Ive heard. Not a single hint of buzziness at all.
Old 10-09-2012, 10:36 AM   #93
Simmons-Racing
Member#: 274179
2013 Subaru BRZ
Thanks,
My Perrin tune should be here tomorrow, I can't wait.
Simmons
JSCSpeed.com
Old 10-09-2012, 11:34 AM   #94
ABQautoxer
Member#: 198231
2007 Not a Subaru
Very cool. Let us know if the rev limiter behavior has changed and what they set it to along with the rest of your impressions of it.
Old 10-09-2012, 02:42 PM   #95
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
It's not the tune which bricks the ECU is it? AFAIK, they haven't released a fix for that as of yet...
Old 10-09-2012, 05:32 PM   #96
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
^^^ this... thats why I am waiting... GL with it tho.. looking forward to your impressions...
Bill
Old 10-11-2012, 12:09 PM   #97
WRautoXr
Member#: 184071
2013 SWP 13 BRZ
PSM 02 WRX
I know I can't financially run STX next year, but it's not stopping me from prepping my car theoretically
WRautoXr is offline   Reply With Quote
Old 10-11-2012, 06:55 PM   #98
WRXwagon2b
Member#: 23756
04 GGA Power!!!
Asspen White
WRauto, it doesnt mean you cant run in STX for fun. I did that with my stock WRX when I first started. Tried to be mid pack as top pack was always hard due to those modded cars.
WRXwagon2b is offline   Reply With Quote
Old 10-11-2012, 09:20 PM   #99
WRautoXr
Member#: 184071
2013 SWP 13 BRZ
PSM 02 WRX
Thanks for the suggestion! I agree, it's always better to run and have fun that just sit home and not run at all. Unfortunately, I have too much of a competitive personality to run a half prepped car. I'll run CS until it's financially feasible to bump prep levels...
or I'll just find another awesomely prepped car to abus... I mean codrive
Old 10-12-2012, 10:53 PM   #100
Simmons-Racing
Member#: 274179
2013 Subaru BRZ
I got my ECU Tech tuner from Perrin.
I also got whiteline rear frame bushings,
