Old 10-04-2012, 05:33 PM   #1
KennyKaozII
Member#: 333257
Default umm?
is the light supposed to come on early ....99 obs http://i1158.photobucket.com/albums/...ps47c12c6a.jpg
KennyKaozII is offline   Reply With Quote
Old 10-05-2012, 05:38 PM   #2
KennyKaozII
Member#: 333257
anyone???
Old 10-05-2012, 06:11 PM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
You bumped in 5 minutes? What is wrong with you?
Old 10-05-2012, 06:25 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Purple
Old 10-05-2012, 06:44 PM   #5
KennyKaozII
Member#: 333257
it has been one day???? not 5min. -_-
Old 10-05-2012, 09:20 PM   #6
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Keep driving. You tell us.
kewlboxer2 is offline   Reply With Quote
Old 10-05-2012, 09:30 PM   #7
Counterfit
Member#: 124254
"The Scoobinator"
Oops.
Old 10-05-2012, 10:44 PM   #8
Special J
Member#: 148045
2006 OBS
Originally Posted by Matt Monson View Post
Purple
You may be on to something there. He's neither moving closer to (which would induce what's known as a "blueshift" to astrophysicists) or farther from (inducing "redshift") empty, but has somehow gone light years at a 90 degree angle to empty, thereby causing the first documented proof of "purpleshift", and a wicked case of parallax error on the gauge.
SCIENCE!
Special J is offline   Reply With Quote
Old 10-05-2012, 10:51 PM   #9
Counterfit
Member#: 124254
"The Scoobinator"
Where do you guys see purple?
Old 10-05-2012, 11:35 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I like thread subject lines that are completely worthless.
And the answer is NO, the light is not supposed to come on until you run out of gas.
Patrick Olsen is online now   Reply With Quote
Old 10-05-2012, 11:48 PM   #11
Special J
Member#: 148045
2006 OBS
It was here yesterday. You completely missed it.
Old 10-06-2012, 12:25 AM   #12
KennyKaozII
Member#: 333257
how do i fix it
Old 10-06-2012, 12:59 AM   #13
Counterfit
Member#: 124254
"The Scoobinator"
The same way anything else gets fixed: duct tape and/or BFH
Old 10-06-2012, 01:03 AM   #14
mkanctil
Member#: 284407
2006 2.5i Sedan
San Remo Red
Originally Posted by Special J View Post
You may be on to something there. He's neither moving closer to (which would induce what's known as a "buleshift" to astrophysicists) or farther from (inducing "redshift") empty, but has somehow gone light years at a 90 degree angle to empty, thereby causing the first documented proof of "purpleshift", and a wicked case of parallax error on the gauge.
SCIENCE!
mind = blown
mkanctil is offline   Reply With Quote
Old 10-06-2012, 01:44 AM   #15
Special J
Member#: 148045
2006 OBS
Originally Posted by mkanctil View Post
mind = blown
mission = accomplished
Old 10-06-2012, 01:47 AM   #16
Counterfit
Member#: 124254
"The Scoobinator"
Donuts = delicious
What?
Old 10-06-2012, 06:50 AM   #17
James2.5i
Member#: 305063
2010 Storm Trooper
Hmmmmmmmm... Donuts.......... Hmmmmmmmmm....
James2.5i is offline   Reply With Quote
Old 10-06-2012, 03:37 PM   #18
EM101
Member#: 324428
2013 Impreza
Marine Blue Pearl
On a serious note, while the light may be on a bit early according to the fuel gauge level, it is not too far out of range. The car I currently have, while waiting for my ordered 2013 Impreza, has the low fuel light come on when the fuel level is about 3 gallons left on the tank.
EM101 is offline   Reply With Quote
Old 10-06-2012, 04:27 PM   #19
KennyKaozII
Member#: 333257
could the light be right (indicating low fuel) and the gauge be wrong (indicating 1/4 tank??
Old 10-06-2012, 04:33 PM   #20
Counterfit
Member#: 124254
"The Scoobinator"
I think they come from the same sensor.
Old 10-06-2012, 09:16 PM   #21
EM101
Member#: 324428
2013 Impreza
Marine Blue Pearl
I think I would trust the light more than the gauge. Normal fuel gauge will show full for a while before it drops down.
My wife says read the manual and if you don't find an answer go see the dealer.
Old 10-07-2012, 10:17 AM   #22
KennyKaozII
Member#: 333257
Thanks guys. I am gona read the manual to see about the same sensor thing. I do trust rhe light more than the gauge bc my gauge doesnt reset wen i turn the car off/on like my others (temp, tacho, ect.)
Old 10-07-2012, 10:19 AM   #23
Counterfit
Member#: 124254
"The Scoobinator"
The fuel gauge doesn't do that.
Old 10-07-2012, 03:00 PM   #24
KennyKaozII
Member#: 333257
Only subaru?
Old 10-07-2012, 03:08 PM   #25
Counterfit
Member#: 124254
"The Scoobinator"
Subaru's fuel gauges move super slow. I'm not sure if the point is to get rid of the Wild swings from going up and down hills but it definitely works that way.
Message Board Statistics All times are GMT -4. The time now is 10:42 AM.
