![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1376 |
Member#: 329348
Vehicle:2013 Sport Limited ISM |
Hello all,
I am currently awaiting the arrival of a 2013 Impreza Sport Limited. Stock Tires: 205/50 R17 Possible winter tires: Blizzak WS70 Size: 205/65 R16 Wheels: Steel, 5x100, 16x6.5 Offset: 48mm Will I be able to use these wheels/tires on the Impreza? If so, is there anything besides the difference in the speedometer that I should be aware of? Thank you in advance for any assistance anyone may be able to give.
#1377 |
Member#: 124254
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
That will be a BIG difference at the speedo. Nearly 10%
#1378 |
Member#: 97135
#1379 |
Member#: 124254
Oops, I missed the 17" stock wheel. It's more like 5%, still too big.
#1380 | |
Member#: 329348
#1381 |
Member#: 246851
SCIC
Vehicle:2007 UGM 2012 LR |
2012 WRX 5DR
Swift Spec_R Springs (drops .6 inch) 235/40/18 Sumitomo HTRIII 18x8 +40 Axis Wheels Will this fitment be ok under all driving conditions? |
#1382 |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
You should be fine, however if you plan on driving through any moderate snow then you should considering get at least some all-season tires.
#1383 |
Member#: 246851
SCIC
#1384 | |
Member#: 288727
Vehicle:2008 Impreza 2.5i Satin White Pearl |
#1385 |
Member#: 323869
W. Canada
Vehicle:2000 ST-outback White/Grey |
Finally got better pictures.
18x9.5 et25 225/40 ![]() ![]() |
#1386 | |
Member#: 288727
![]() Car looks ![]() |
#1387 |
Member#: 248840
Vehicle:2011 Impreza Satin White Pearl |
There's a great deal on a set of 18x9 +35 G-Forces! Tires are 245/40/18.
I have a 2011 2.5i hatch with Swift springs and stock struts. I know I will have to roll the fenders, but I wanted to know if and what kind of camber kits I would need? Or would it look stupid because I am only lowered an inch? Last edited by trishHUYNH; 10-10-2012 at 11:46 PM. Reason: Tire size. |
#1388 | |
Member#: 268328
BAIC
#1389 |
Member#: 97135
there is no camber bolts for a 2011. you need adjustable LCA's. Maybe whiteline camber kit but idk if that'll give enough adjustment for that much tire.
roll all around too. thats a fairly aggressive fitment with that tire, especially for the narrowbodies. |
#1390 | |
Member#: 268328
BAIC
The front struts have a camber bolt from the factory ![]() |
#1391 | |
Member#: 97135
This is the only other possible solution (aside from LCA's) to gaining rear camber adjustment on the 2008+: http://www.rallysportdirect.com/Whit...8-2011-WRX-STI I believe those only offer about .75* of camber adjustment though. |
#1392 | |
Member#: 248840
I'm waiting to see how well they fit on my car without any aftermarket camber bolts for now. Hopefully down the line I can buy what I need. |
#1393 |
Member#: 97135
you cannot get camber plates for the rear of your car, and there is no stock rear adjustment. you HAVE to get LCA's or the whiteline camber kit....but I doubt the whiteline kit will give you enough adjustment.
you WILL need them in the rear. Thats a pretty aggressive fit for the narrowbody. |
#1394 |
Member#: 202778
International
Vehicle:my98 GC8 WRX Silver |
So many fitments listed, but useless without pics
#1395 | |
Member#: 97135
#1396 |
Member#: 334328
Vehicle:2013 XV Crosstrek Khaki |
Are the Crosstrek wheel specs the same as the base Impreza? I'm waiting on my car now and want to have my winter setup ready to go when it arrives and would like to go with some cheapo steelies.
#1397 |
Member#: 97135
#1398 |
Member#: 329262
International
Vehicle:2003 WRX WRB |
Can you guys help me out? I get confused when talking about wheels and tires for what will fit on my car.
I am planning on getting the sparco assetto gara for my 03 wrx Size: 17x7.5 offset:48 backspacing:6.14 bolt pattern:5x100 I know the bolt pattern will fit my car but will the wheel? will there be any fender rub or any other issues i should be worried about? Was going to get Hankook Ventus V4 ES H105 to go with them. rec. tire size is 225/45-17 and thats what i was going to go with. IF i wanted a wheel with some stretch, not a lot but a little stretch what size of tire would that be for this wheel? If someone could help me out it would be awesome! thank you in advance. |
#1399 |
Member#: 124254
Don't stretch, just don't.
#1400 |
Member#: 329262
International
okay lol
I wasn't really planning on it I was just curious |
| Thread Tools | |
| Display Modes | |
| the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
| the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
| where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
| A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
