Old 09-27-2012, 10:56 AM   #1
Salvation27
Member#: 292403
2012 Legacy
Graphite
Default 2006 Electrical Problem????
Hello,
Quick, weird question- Don't know if this is an electrical problem, or a door sensor problem?
Here's the scenario- a majority of the time, when I take SHARP, RIGHT TURNS ONLY- my interior light comes on (dome in headliner), and so does the "Vehicles Dynamic Control warning light and vehicle dynamics control OFF indicator light. This light illuminates when the vehicle dynamics control OFF switch is pressed"
It's the Red light- where there's like squiggly tire marks underneath the car.
Any assistance would be greatly appreciated!
Salvation27 is offline   Reply With Quote
Old 09-27-2012, 12:20 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The switched ground wire for the dome light might be pinched somewhere or a screw is pearcing the insulation possibly. I don't know how that problem could affect the VDC light but it appears it is. When you the dome light trouble hopefully that problem will clear also. Another possible senario is the two circuits are bridging wires together where they shouldn't be. I would recommend you purchase the factory wiring manual to help you find and solve the problem. Ebay is a good source for them.
Cougar4 is offline   Reply With Quote
Old 09-27-2012, 02:35 PM   #3
Salvation27
Member#: 292403
2012 Legacy
Graphite
Old 09-27-2012, 02:36 PM   #4
Salvation27
Member#: 292403
2012 Legacy
Graphite
Any other suggestions? Also- could it be from when I installed my headunit?
Old 09-27-2012, 02:46 PM   #5
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Did these problems exist before you installed the HU?
VDC = you have an automatic?
Big-E is offline   Reply With Quote
Old 09-27-2012, 02:55 PM   #6
Salvation27
Member#: 292403
2012 Legacy
Graphite
No- it's manual, but thats the light that comes on!
Also, it has NEVER happened until recently, all within the past 2-3 weeks.
I did NOT do the HeadUnit or the LED Gauge conversion within that time frame. I did that almost 8 months ago, and problems just started recently
Old 09-27-2012, 02:55 PM   #7
Salvation27
Member#: 292403
2012 Legacy
Graphite
If it isn't that light, I'll try to get it to happen again- and see which light it is, but I'm almost positive.
Old 09-27-2012, 02:56 PM   #8
Salvation27
Member#: 292403
2012 Legacy
Graphite
Also, let me add, that I DID try to do a bulb conversion in my dashboard/ gauges, but ended up just putting the original bulbs back in. (not the color change, just stronger LEDs)
Old 10-01-2012, 09:45 AM   #9
Salvation27
Member#: 292403
2012 Legacy
Graphite
Bueller?
Old 10-05-2012, 08:29 AM   #10
Salvation27
Member#: 292403
2012 Legacy
Graphite
Ok- edit/bump- NOT the Dynamic Control light, just the "Door Ajar" light comes on with the dome light, but why? I've slammed all the doors, sensors seem to be ok for each door, yet when making Right Turns ONLY- it still happens?
Old 10-05-2012, 11:14 AM   #11
Big-E
Member#: 123843
2006 WRX Sedan SGM
Start with the interior lights.
Remove the inner trim where each door-switch is located and check for crimping of the wiring and related.
Remove each switch and test for continuity. Maybe a switch is bad so even if the door is closed, by the body flexing when you take a corner, this may be just enough movement to cause the switch to close, causing the lights to come on.
Old 10-06-2012, 11:59 AM   #12
Cougar4
Member#: 53443
Winestone
I would start with the door switch in the driver's side door. It might be making contact in the turn. The switch makes a ground connection when the door is opened to turn on the light. Disconnect the switch and see it the problem clears. If it does, you know you have found the trouble.
