Old 10-06-2012, 07:57 AM   #1
greenbeast08
Member#: 325634
Default dominator 1.5, 2012 STI low numbers ????
yesterday i just went and got my car tuned with my new dominator 1.5 xt-r. it made 344 whp. its a 2012 STI sedan
it was a mustang dyno.
elevation 1850 ft.
60 degrees f
my other mods.
900cc injectors
perrin fmic
dw65 fuel pump
invidia catless dp
magnaflow 3 in exhaust
grimm speed ebcs
agency power CAI
turbo smart recirc/blow off valve
tuner was having problems between 2700-3000 rpm. it would go very lean. the car is still having that problem when i drive around. car is hesitating like it hit a wall. anyone have any suggestions ? am i missing some mods ? just seems like the turbo wants to give more. he added more boost but the car went down in hp. need some help lol
greenbeast08 is offline   Reply With Quote
Old 10-06-2012, 08:30 AM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
No offense, but it makes me sad to read stories like this about tuners. If they're worth their weight in **** they should be working with you to meet your power goals. "adding boost" to a stock motor that is already lean sounds like homicide to me.
Not the answer you're looking for obviously, but that's not going to be a cheap motor to rebuild.
Can you log? Does the ecu pull fuel back during those lean spots?
mechatricity is offline   Reply With Quote
Old 10-06-2012, 09:25 AM   #3
greenbeast08
Member#: 325634
i can log it.
he took the boost back down to 21.5. it was when he was trying to get more power out of it. said it was like the turbo was choking. said i need a new inlet and up pipe. im just trying to get another opinion before i go buying more parts.
Old 10-06-2012, 10:03 AM   #4
speedy06STI
Member#: 305309
2007 STI limited
UGM
Basically, what you're problem seems to be IMHO is that you have a really good turbo but half the parts you need to see the power from it. I am surprised you're tuner even tried to tune it as it sits. you have a very restrictive stock up pipe and inlet paired with a big intercooler system and a downpipe. You are replacing a turbo that flows 38lbs per min with one that flows 49 lbs per minute and only replacing half of the parts that the turbo bolts up to.
Get an up pipe, external wastegate, and a perrin turbo inlet. also if you were running a bigger top mount you would see much faster spool with that turbo than with the fmic (i used to run a 1.5xtr). TGV deletes would not hurt either.
if anyone thinks i am off track here let me know
speedy06STI is offline   Reply With Quote
Old 10-06-2012, 10:20 AM   #5
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Its the fuel pressure regulator its a common problem with the newer sti's my friend had the same problem with his 2012 with a 2.5xtr. He installed a 2007 sti fpr kit and agency power parallel rails and lines and no more stumble between 2500-3000 rpm. To bad he fried his rings befor he got the chance to correct the problem. He put in new cp pistons and still had the stumble until he changed out the regulator and bam no more issues he is making 450whp on e85 now.
nate_fisher is offline   Reply With Quote
Old 10-06-2012, 11:00 AM   #6
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
344hp with that turbo on a Mustang dyno is pretty good. Average hp for that turbo on 93 octane at that boost level is around 330.
fastblueufo is offline   Reply With Quote
Old 10-06-2012, 12:23 PM   #7
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
I would tend to agree. That's near the upper 300's on a dynojet, which is pretty good for a pump gas tune on 21psi. Def. get that lean issue sorted out however, or you'll be shopping for a new bottom end.
ByeBye4g63t is offline   Reply With Quote
Old 10-06-2012, 12:46 PM   #8
greenbeast08
Member#: 325634
i appreciate all the replys. thanks for all the help
Old 10-06-2012, 02:02 PM   #9
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
^^^THIS
Alot of good tuners know this already and will use aftermarket or the older sti fuel regulators.
As far as upgrading your uppipe and turbo inlet has nothing to do with running lean but only leaving some HP on the table. I think u need a new tuner that knows what he's doing as he shouldn't have left u in this state with proper knowledge on how to fix your lean condition
trev762 is offline   Reply With Quote
Old 10-06-2012, 02:18 PM   #10
neorex
Member#: 106478
STi 1.5 xt-r
Contact [email protected] for an ingeniously simple solution for the stumble...
EL header, up pipe, and inlet would certainly help with peak numbers....
neorex is offline   Reply With Quote
Old 10-06-2012, 04:12 PM   #11
greenbeast08
Member#: 325634
is that his email address or should i give him a call ?
Old 10-06-2012, 04:45 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
I believe he meant [email protected] correct me if I'm wrong
Old 10-06-2012, 05:05 PM   #13
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
awdorgtfo is offline   Reply With Quote
Old 10-06-2012, 06:36 PM   #14
greenbeast08
Member#: 325634
so this is what they wrote me back lol.
We do not have a joe that works here. I would suggest contacting your tuner about this assuming that the car does not have a boost leak or a vacuum line that is pinched.
Craig-
Old 10-06-2012, 06:37 PM   #15
greenbeast08
Member#: 325634
theres a god speed and a good sped lmao........too many websites with like names. ill emaill goodspeed now hahaha
Old 10-06-2012, 06:44 PM   #16
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It was mentioned earlier, but I just want to reiterate two points.
1) That power is exactly what you should expect with that turbo on that dyno
2) Your stumble is being caused by the factory FPR. Either get an aftermarket FPR or swap in one from the older models. I am not guessing here, and neither are the two people who posted earlier about this problem. This is WELL known and WELL documented, get a new FPR or you'll be needing new pistons soon.
