Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-06-2012, 11:49 AM   #1
abxx49
Member#: 218321
Default boost/vacuum issues 2011 WRX
Hi everyone. I put some ELH on my car last night along with a tial 38mm ewg, and GS uppipe. I was running this off of spring pressure and have a tune coming soon, however, something happened today while driving.
The car threw 2 codes P0108 (MAP) and P0244 (Wastegate). Reset them and the car never shot them back.
I was building boost just fine and the EWG opened as usual. However, this time it just cut out. My AEM boost gauge is now reading 0. No vacuum, no boost. When I do drive it I can hear the turbo spinning, but when I let off it almost sounds like compressor surge? I've also seen the term BOV flutter tossed around, but I'm not sure on that.
The car has a full exhaust on it, CAI, EBCS, ewg, and forge BPV.
I assumed as soon as it happened that I blew a line off of something, but upon inspection I couldn't find any. Any suggestions would be great.
Thanks,
Ryan
abxx49 is offline   Reply With Quote
Old 10-06-2012, 12:29 PM   #2
jvf4
Member#: 274088
Check the intercooler. The one on my 2011 wrx split. I thought it was a vacuum line on mine as well.
jvf4 is offline   Reply With Quote
Old 10-06-2012, 12:30 PM   #3
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
12 seconds at a time
You have all that installed and no tuning done and your are out boosting... Wow.
wrxlaunch is offline   Reply With Quote
Old 10-06-2012, 02:01 PM   #4
nate_fisher
Member#: 270482
2011 forester xt
corn fed td06 20g 8cm
maxed out map sensor need to raise the value i would get a tune asap.
nate_fisher is offline   Reply With Quote
Old 10-06-2012, 02:04 PM   #5
abxx49
Member#: 218321
Actually I am tuned. Just not for the EWG, which my tuner said would be fine as long as I was running off of spring pressure.
Old 10-06-2012, 02:05 PM   #6
abxx49
Member#: 218321
I was wondering this. Is the car going to stay in this "mode" until it's tuned? I was going to wait until next weekend, but I may have to make a trip on Monday or Tuesday now.
Old 10-06-2012, 02:06 PM   #7
abxx49
Member#: 218321
Wouldn't I hear a whistling under the hood or something if that cracked?
EDIT: I suppose it is possible, but I'm only running 16psi on this tune...I don't feel that it is enough to crack it? I certainly could be wrong though.
Old 10-06-2012, 02:22 PM   #8
nate_fisher
Member#: 270482
2011 forester xt
No just need a tune it for it or you will continue to throw these codes your map sensor is probly set at 400 and you need it at 500 esp now that its getting colder out there is more chance for boost spikes.
