#1 |
Member#: 332366
RMIC
Vehicle:2005 WRX Wagon Silver |
i have 135k on my wrx and i feel soon it will start to grind and all that good stuff. what would be the best route to doing this? should i look for a used tranny? or should i get a rebuild kit? or if you have any better ideas hit me with them!
Thanks Brody.
#2 |
Member#: 200288
BAIC
Vehicle:2002 Impreza WRX World Rally Blue |
Have you considered changing your transmission oil?
#3 |
Member#: 257618
TXIC
Vehicle:2006 wrx aspen white |
If its not broke don't fix it. Change the fluid. If you see any metal shavings then worry about it.
#4 | |
Member#: 97135
NWIC
if theres nothing wrong why spend the money. i have 161k on my tranny, and 0 problems. Changed out the tranny fluid about 10k ago with scotty's cocktail, shifts like when i bought it. |
#5 |
Member#: 332366
RMIC
Ill have to change it. It's harder to get into 2nd snd 4th maybe it's the oil
#6 |
Member#: 200288
BAIC
Be careful of which oil you put in. The stuff most parts stores carry don't mesh well with the 5 sp. The best oil to use is the subaru extra s. You can buy it online in quart bottles, or sometimes the dealer may carry it in drums.
Do you try to shift really fast? |
#7 | |
Member#: 97135
NWIC
#8 |
Member#: 326698
Tri-State
Vehicle:2006 WRX Ltd. San Remo Red |
I've read tons of things on this forum about uncle scotty's cocktail. It seems to come pretty well recommended.
#9 |
Member#: 316278
TXIC
Vehicle:2010 WRX Sedan WRB |
I did 2qt of motul, 1 qt redline shockproof and topped it off with more motul. Feels way better than the stock fluid
#10 | |
Member#: 200288
BAIC
However, I feel more comfortable using something not only designed specifically for my transmission, but a little more homogeneous, compared to dumping a concoction of fluids down the tube. |
#11 |
Big Ron
Moderator Member#: 18062
MAIC
Change your fluid, THEN worry about other options as a fluid swap will likely fix it as long as you use one of the listed fluids.
http://forums.nasioc.com/forums/showthread.php?t=995498 |
