Old 10-06-2012, 02:43 PM   #1
ctfjr
Member#: 297540
2011 STI
Default Removing radio trim piece with destroying it
I am about to change th head unit in my 2011 sti. After reading a few posts on various forums I used my fingers & started at the top & gently pulled (well gently but firmly). The top did start to disengage from the clips but then it stopped.
So not wanting to totally destroy it. . . The question is, is this the right way to remove it?
ctfjr is offline   Reply With Quote
Old 10-06-2012, 08:11 PM   #2
dsn112
Member#: 332561
2013 WRX Hatch
No correct way, I just used a plastic pry tool in the lower corner to get it started, then pulled the rest out. It's super simple. You won't destroy it.
Old 10-06-2012, 08:12 PM   #3
garudatwo
Member#: 322385
I've never used a tool of any kind. Just do what you do and if it "stops", move over an inch and repeat.
garudatwo is offline   Reply With Quote
Old 10-06-2012, 08:26 PM   #4
gunz4me
Member#: 305130
I used an expired credit card, to get it started on the right hand side, then my fingers afterward.
gunz4me is offline   Reply With Quote
Old 10-07-2012, 05:41 AM   #5
Autolight
Member#: 311699
Ooooops...
Autolight is offline   Reply With Quote
Old 10-07-2012, 01:15 PM   #6
ctfjr
Member#: 297540
2011 STI
Exactly
When I decided to just keep on it came out easy peasy - even went back in.
UPS is bringing my new HU on Tuesday & will probably try getting everything in after work.
Thanks to all for the reponses!
Message Board Statistics All times are GMT -4. The time now is 07:01 AM.
