Old 10-06-2012, 11:52 AM   #1
kev20
Member#: 314303
Question sti 2007 rough start/ hesitation
Hi!
I search to find my problem but not find
The problem begin after i got tuned
Im not sure but im think its a scaling issue
modification
cobb sf intake
turboback
header
injector 650cc dw
fuel pump dw
ecutek
The car start fine at cold but when i come to start when the car is hot, the car shake a lot and run really rich 11:1-11.5:1 afr
If i give a little gaz . the car come back to normal 14:5:1afr
The car have alose a little hesitation between 2000-3000rpm BUt not Always
And i can read lean on this spot (15-16:1afr)
But at wot, the car have not hesitation
its like a bad o2 sensor, but i change it 800mile ago
please if you can help me...
kev20 is offline   Reply With Quote
Old 10-06-2012, 01:44 PM   #2
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
go back and talk to your tuner, this isn't a simple fix for a board...more a touch, feel and see type of thing.
-Mark
APM Tuned is offline   Reply With Quote
Old 10-06-2012, 02:17 PM   #3
kev20
Member#: 314303
Yes i know, The tuner is has more than 7 hours of road, that why i wanna know if its really in the tune
Old 10-06-2012, 03:54 PM   #4
tekfoc
Member#: 21392
2007 IMPREZA WRX STI
urban gray
its ether the tune or bad dw injectors .
tekfoc is offline   Reply With Quote
Old 10-06-2012, 05:35 PM   #5
kev20
Member#: 314303
There is someone who had some trouble with deatchswerks injectors?
Old 10-06-2012, 06:47 PM   #6
tekfoc
Member#: 21392
urban gray
You have to remember that dw are just modified stock used injectors.
Yes their are people out there who has had problems with dw's .
This is my choice I suggest new injectors like ID OR PE INJECTORS .
Bring it back to your tuner let him look over the map .
He should easly be able to see if its his mistake or possible bad injectors .
Old 10-06-2012, 07:43 PM   #7
kev20
Member#: 314303
good to know thx, but If the injectors is bad, i dont know why the car start well on cold start
Old 10-06-2012, 09:28 PM   #8
tekfoc
Member#: 21392
urban gray
[quote=kev20;38212658]good to know thx, but If the injectors is bad, i dont know why the car start well on cold start[/quote
Don't want to speculate .
Let the tuner look at the tables and scalings.
A good tuner is your friend.
Good luck
Message Board Statistics All times are GMT -4. The time now is 08:08 AM.
