Old 09-06-2012, 08:58 AM   #3601
jockeygolfs
Member#: 260868
2011 STI
Originally Posted by Mike Costin
Hi Richard,
I have the Spec C tank in the trunk with an aluminum firewall between trunk and cabin. Additionally NASA CCR requires braided stainless steel lines for any alcohol mix passing thru the cabin. I don't want to run the line under the chassis which would require a different type of line anyway.
One idea is -4 A.N. braided hose. But that would require sourcing something like a -4 A.N. threaded compression fitting for 6mm tube or a BSPP - A.N. adapter.
Another idea is sheathing the existing line.
Ideas?
I just converted all my nylon hoses to braided lines with -4AN fittings. I also have a no drip quick disconnect right after my tank. I use the Howerton (2) 1 Gallon tank unit. I have a build thread with pics of the lines in it.
Jeff Howerton was great at helping me put this system together. He also helped a lot with setting up my system.
jockeygolfs is offline   Reply With Quote
Old 09-06-2012, 07:58 PM   #3602
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Originally Posted by Mike Costin View Post
Hi Richard,
Ideas?
I have little experience with braided lines. Jeff at Howerton Engineering is the person to help you. He has the BSPP to AN fitting adaptors.
Aquamist is offline   Reply With Quote
Old 09-06-2012, 07:59 PM   #3603
Aquamist
NASIOC Manufacturer
Member#: 110029
Ooops, double replied.
Old 09-06-2012, 09:11 PM   #3604
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Thanks gents
I've ordered from Jeff before, I'll shoot him an email
I've got one of his tanks/enclosures in my XR4Ti, I love it
Awesome build BTW
Mike Costin is offline   Reply With Quote
Old 09-06-2012, 09:33 PM   #3605
jockeygolfs
Member#: 260868
2011 STI
Thanks man. If you can put AN lines together on your own it is pretty easy. I have never done them so I left it to an expert. I mapped out everything I wanted and sent it to Jeff. He double checked to make sure it all worked out fittings wise and assembled them. He also pressure tested them.
If anything, I wish I would have made my lines at the intercooler shorter and put 90's at the tee. Otherwise it all worked out really well. I could have used a shorter line out the back of the tank system as well.
Old 09-15-2012, 03:19 PM   #3606
Billboard2001
Member#: 210085
2005 wrx sti
WRBlue
I've got a general question that I tried researching with no luck. I'd like to install an aquamist kit myself, but the closest tuner is 6 hours away from me. Would I be able to install the kit and drive the car? Is there a way to turn it off until I was able to get to the tuner so that it would drive like normal? Or should I just pay to have them install it once the car arrives at the shop?
Billboard2001 is offline   Reply With Quote
Old 09-16-2012, 03:32 PM   #3607
Aquamist
NASIOC Manufacturer
Member#: 110029
If you can put up a shelf, you are more than capable to install an Aquamist. I am available to help with any problem. The wiring is straight forward, mostly plug and play.
You can install and test the system before making the drive. Let me know when the install is completed and I will help you setting it up.
You can either pm, email me from here or on the www.waterinjection.info forum.
Richard
Old 09-20-2012, 08:44 PM   #3608
bigbossin
Member#: 332666
2007 STI
So I just bought my 07 sti had a water spray in it, seems like its not only water inside the container seems like alcohol! Is that bad to be sprayed
bigbossin is offline   Reply With Quote
Old 09-21-2012, 02:26 PM   #3609
Aquamist
NASIOC Manufacturer
Member#: 110029
Is this a IC spraying system?
Old 09-21-2012, 04:18 PM   #3610
bigbossin
Member#: 332666
2007 STI
Yes that's correct
Old 09-22-2012, 03:12 AM   #3611
shaman
Member#: 164259
The tank tap needs a 23mm hole, if I read the manual correctly. Is it possible to get the fitting bigger? For using the fitting to also fill an empty washer pump hole.
shaman is offline   Reply With Quote
Old 09-22-2012, 06:35 PM   #3612
Aquamist
NASIOC Manufacturer
Member#: 110029
What kind of alcohol is it? If it is methanol, it will not be good to breath it in.
Also a chance of corroding the IC fins.
Old 09-22-2012, 06:37 PM   #3613
Aquamist
NASIOC Manufacturer
Member#: 110029
The 22-23mm hole is quite standard for washer parts. How big is the hole?
Old 09-23-2012, 02:50 AM   #3614
shaman
Member#: 164259
he VW 5.5L tank shows it needs a 29mm plug, although the hole might be different. They never came standard in the US, so I can't find alot of info on them.
Old 09-24-2012, 03:49 AM   #3615
Aquamist
NASIOC Manufacturer
Member#: 110029
That is an odd size. We have nothing close to that at all. Sorry.
Old 09-27-2012, 05:12 AM   #3616
bigbossin
Member#: 332666
2007 STI
I went ahead and just cleaned it all out as best I could, methanol dosnt come blue color right?
Old 09-27-2012, 03:06 PM   #3617
Aquamist
NASIOC Manufacturer
Member#: 110029
No. methanol shpould be water clear.
Old 10-06-2012, 04:57 PM   #3618
jockeygolfs
Member#: 260868
2011 STI
If I want to turn the HSF-3 off but not cut to waste gate pressure do I just take the jumper off of DHB?
Old 10-06-2012, 07:38 PM   #3619
Aquamist
NASIOC Manufacturer
Member#: 110029
Yes, that is all you need to do.
Old 10-15-2012, 08:29 AM   #3620
shaman
Member#: 164259
A member on another forum asked, and I wanted to post correct info. For a direct injection engine. IEN54 BMW and MS3, the HFS6 cannot handle the signal (as well as the HFS3), correct?
Old 10-15-2012, 03:39 PM   #3621
Aquamist
NASIOC Manufacturer
Member#: 110029
The HFS-3 's DI signal detection is more advance than the HFS-6. It can detect the lift and duration of the some direct injection signal such as the BMW's current N54 engine.
The HFS-6 just detects the opening duration. It worked very well on some earlier direct-injection engines. It is more advanced on monitoring and re-scaling the fuel rail pressure than the H3.
The H4... has it all, for the time being. The pace of advancement of the automotive industry keeps us very busy.
Old 10-15-2012, 06:34 PM   #3622
shaman
Member#: 164259
On the earlier DI engines, like ones without a common rail, or even a pressure sensor, the HFS-6 would be the better choice, is that what I am understanding?
Old 10-15-2012, 09:16 PM   #3623
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Hi Richard!
Is it possible to "upgrade" the older HFS-5 to the latest version?
djerickd is offline   Reply With Quote
Old 10-16-2012, 03:29 AM   #3624
Aquamist
NASIOC Manufacturer
Member#: 110029
The earlier DI engine generates the high pressure within the injector valve itself rather via common rail arrangement.
You are correct that some don't even have a pressure sensor signal we can use. During those days, almost all makers used their own DI system. For us, it was very difficult to pin them down until recently.
Old 10-16-2012, 03:31 AM   #3625
Aquamist
NASIOC Manufacturer
Member#: 110029
Originally Posted by djerickd View Post
Hi Richard!
There is a big design change between the H5 and the H6, H3 and H4. It is better to sell the H5 as a complete system and purchase the newer systems.
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 08:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 05:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 03:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 04:26 PM
