Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 10-03-2012, 09:47 AM   #1
pghmtnbiker
Member#: 323023
2013 WRX Hatch
Default Aftermarker GPS AUX input connection lost?
All the aftermarket GPS HUs state that the factory AUX input connection will be lost. Does this mean my WRX USB and AUX input will not work if I install a new unit. Is there a way around this?
I searched around but couldn't find this, I'm sure it's been addressed before.
pghmtnbiker is offline   Reply With Quote
Old 10-03-2012, 10:31 AM   #2
blessthekellen
Member#: 273859
MY98
WRX
yes, thats exactly what it means.
what i do in a customers case when they like the factory location of the aux/usb on their vehicles is i will retrofit the aftermarket head units cables to the spot their factory inputs are. isn't that difficult, just takes a little more time than simply dropping these lines into the gloveboxes.
something like this works great for USB, and I have used it before, would reccomend.
http://pac-audio.com/productDetails....&CategoryID=31
blessthekellen is offline   Reply With Quote
Old 10-03-2012, 10:39 AM   #3
pghmtnbiker
Member#: 323023
2013 WRX Hatch
thanks!
Old 10-04-2012, 12:48 AM   #4
jegomes
Member#: 303039
2006 WRX
A trick I like doing is cutting a USB extension and soldering to the back of the factory connector.. just did 2 today for the suby dealer by my shop...
jegomes is offline   Reply With Quote
Old 10-04-2012, 07:58 AM   #5
pghmtnbiker
Member#: 323023
2013 WRX Hatch
I am assuming the same can be done with the AUX?
Old 10-04-2012, 09:11 AM   #6
jegomes
Member#: 303039
2006 WRX
Yes... if you pull the auxiliary plate out you can open it up and pull out the circuit board... from there you can solder directly to it. I usually but the cord I'm going to use and then plug it into the Jack on the board then use my dmm to check for continuity with the pins on the board
Old 10-04-2012, 10:24 AM   #7
pghmtnbiker
Member#: 323023
2013 WRX Hatch
thanks for your help
Old 10-06-2012, 07:18 PM   #8
gunz4me
Member#: 305130
SVXDC makes the aux input harness: http://ae64.com/
Also, I made my own USB connector:
Based on this thread: http://forums.nasioc.com/forums/show....php?t=2379118
gunz4me is offline   Reply With Quote
Old 10-06-2012, 07:28 PM   #9
garudatwo
Member#: 322385
I've used David's USB connector kit, and it works perfectly when I swapped to my single din.
garudatwo is offline   Reply With Quote
