Old 10-05-2012, 09:50 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - FP Red on E85 - 456whp!
We tuned this car on 91 about a year ago, so this time around the customer came back for more power on E85. We installed a beautiful set of Defi gauges, ID2000's and complementary fuel system and tuned the beast on E85. The result was a little bit laggier than I'd hope for, but great power all around for a stock location turbo.
Event: Custom Tune/Dyno
Ambient Temp: 104 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2006 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 456whp @ 6250RPM
Peak Torque at RPM: 410ft-lbs @ 5500RPM
Target Boost: 25.5psi
Fuel: E85
Engine/Power Modifications:
Built Shortblock
FP Red Turbo
EQ Tuning FMIC Kit
Tial BOV
Perrin 3" Inlet
TGV Deletes
Perrin EL Headers
Tigwerks EWG UP with Tial 38mm EWG
ID2000cc Injectors
T1 Top Feed Conversion rails
Aeromotive FPR
EQ Tuning Fuel Line Kit
Aeromotive Stealth Fuel Pump (direct wired)
Hallman MBC
Perrin CATTED TBE
EQ Tuning Custom Tune on E85
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 215-220whp
Stock 08-11 STI - 190-200whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
350-360whp - 118-120mph traps
-- Ed
Old 10-05-2012, 10:43 PM   #2
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
Looks like fun... What did it make on 91?
woodys77 is offline   Reply With Quote
Old 10-05-2012, 10:52 PM   #3
Subarusesh
Member#: 288160
2008 Impreza 2.5i
it was at 325WTQ and 360WHP. I am loving the new power/tune. so thankful for ethanol/ EQ tuning!
Subarusesh is offline   Reply With Quote
Old 10-06-2012, 12:45 AM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Do you estimate this car would trap in the low-mid 130's?
Old 10-06-2012, 01:15 AM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Realistically probably in the high 120's with stock weight and a good pass.
-- Ed
Old 10-06-2012, 12:57 PM   #6
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
Great numbers Will! I am glad the motor we built for you did so well. You should really look at some cams at a minimum to get some more power north of 5500. Enjoy it!
bikerboy is offline   Reply With Quote
Old 10-06-2012, 01:12 PM   #7
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
Ed, what does a usual stage 2 + E85 put down on your dyno? Like 250-270whp and around 300torque? That's about what my car did in the 100 degree heat uncorrected. The shop I used had a 1.2 CF, but I've heard CF's only apply to N/A cars....
ByeBye4g63t is offline   Reply With Quote
Old 10-06-2012, 03:53 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Stage 2 STI on 91 usually does 270-280whp. On E85 they get up to 330-340whp.
-- Ed
Old 10-06-2012, 08:12 PM   #9
woodys77
Member#: 192147
2007 STI EfiLogics
Is there anyway for you to post the 91 graph? I really want to go from green to a red and only have access to 91 so I'm real curious.
Old 10-06-2012, 08:53 PM   #10
Subarusesh
Member#: 288160
2008 Impreza 2.5i
here is the link for the thread on the old 91 tune:
http://forums.nasioc.com/forums/show...+tuning+360whp
Old 10-13-2012, 08:15 PM   #11
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Good Job, Ed.
Boosted Tuning is offline   Reply With Quote
Old 10-13-2012, 10:45 PM   #12
wrxhard
Member#: 108091
Is this the OG red or the new bb hta red?
wrxhard is online now   Reply With Quote
