Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 09-20-2012, 10:17 AM   #201
omiotek
Member#: 272090
now the reason i didnt post any pictures after i primered it was because 1. i forgot to take them and 2. i masked the car up the next day to get the engine bay prepped and didnt want to take off the plastic. so heres the engine bay pics. theres no finished pics of it BUT it is shot. the por15 is glossy until it dries fully so i didnt take pics as i want a real representation of what it will look like.
omiotek is offline   Reply With Quote
Old 09-20-2012, 10:17 AM   #202
omiotek
Member#: 272090
Old 09-24-2012, 01:32 PM   #203
Swagon_Wagon
Member#: 294424
2006 Spec B. #41
specb silver
Are you not test fitting everything and marking the holes and what not you can remove/cover/shave?
Swagon_Wagon is offline   Reply With Quote
Old 09-24-2012, 08:28 PM   #204
omiotek
Member#: 272090
as far as what? all the panels were test fit before welding with all other panels that ligne up to them. and what not. nothings being shaved except the antenna whole.
i just removed the trunk and everything else for transportation of the vehicle. theres been a lot going on so i havent taken pics of literally EVERY single thing ive done. just befores and afters and some inbetweens.
Old 09-24-2012, 08:36 PM   #205
omiotek
Member#: 272090
tonights update
cars FINALLY back at my place.
on the trailer
floating subaru
back on jack stands. some of the por15 engine bay.... mind the dust all over it.
Old 09-24-2012, 08:36 PM   #206
omiotek
Member#: 272090
heres the primered pics
before and after blasting some of the interior non sense.
Old 09-24-2012, 08:46 PM   #207
lavid2002
Member#: 226864
2005 PSM WRX
18.5lb. 93 oct, DP, UP
That garage is so epic! Holy crap @ the size of that tire in the background!
lavid2002 is offline   Reply With Quote
Old 09-24-2012, 09:06 PM   #208
omiotek
Member#: 272090
thanks! its a shop but the back halfs my "garage/shop area"
monster truck tires...hard to tell but theres 4 of them
Old 09-27-2012, 06:48 PM   #209
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Wow you really have that thing stripped down! It's gonna take some time to get it all back together haha. If you're using plastic bags to stay organized then Ziploc should put your bust in front of the corporate office.
PS I hope you plan on cleaning those threads off.
geronimo81 is offline   Reply With Quote
Old 09-27-2012, 07:32 PM   #210
omiotek
Member#: 272090
Yes sir. Everything will be cleaned. Yeah everything's bagged and tagged. The only thing that's not are things that broke and things that are scrap.
Old 10-03-2012, 07:35 PM   #211
omiotek
Member#: 272090
started working on the wiring harness.... did some re-wrapping, heat wrapping and re-taping. came out ok. theres some half done pics and then some on the motor.
picked up a used tsudo header and high flow cat pipe for $200. also came with the o2 sensors and a wide band bung. doesnt have many miles at all
Old 10-03-2012, 07:36 PM   #212
omiotek
Member#: 272090
did the bedliner and pressed in the group n bushings on the trailing arms, shifter stuff, trans mounting brackets and lateral links.
had to cut out one of the sway bar brackets and re weld a nut... PIA
funny story behind this one.... i was tearing down one of our ecotec motors today for a build when lone behind i picked the cam gear i set on the ground up and this was left... hope this is a good sign
Old 10-03-2012, 07:36 PM   #213
omiotek
Member#: 272090
also the latest edition to mine and claudias "little family" lol. there isnt one just her.meet coco
Old 10-04-2012, 11:42 PM   #214
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Wow... awesome build. Only question... why when you we're sand blasting the frame, you didn't get those rust spots on the bottom? Or did those form after your sand blasting and paint?
spyrule is offline   Reply With Quote
Old 10-04-2012, 11:53 PM   #215
omiotek
Member#: 272090
I didn't sand blast the whole frame or underneath. Just certain areas that would be to hard to rid the rust by hand or with a grinder. Everything else will be taken care of shortly.
Old 10-04-2012, 11:59 PM   #216
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Ahh, understood. Can't wait to see this puppy come to life. Such an amazing amount of work. Kudo's to you for taking on an obviously labour intensive project. Most would shy away from this amount of work.
Old 10-05-2012, 03:21 AM   #217
omiotek
Member#: 272090
yes sir. is i was doing a complete restoration where every single thing was going to be perfect then i would of sand blasted it. underneath i just want to wire brush to rid of the little rust under there, ill put some por15 and then bedliner the whole underneath. will be perfectly fine for what i want out of this car.
thanks. its been a long road with still a long road ahead. honestly ive learned a hard lesson with this car and its done listen to a single person when it comes to buying crap and even when your gut tells you its good dont listen to it without the logic behind it. i had not a single clue the car was in that bad of shape when i bought it. i just knew about the motor and the "typical" rust i know that these cars had and when it showed up on a trailer the real problems became more apparent.... gotta love clean car fax, good pics, and a ****ty seller who fails to acknowledge things. no more outta state cars here unless i fly to get them.
moral of it all is i refuse to let a molested car stay molested.
Old 10-06-2012, 10:44 PM   #218
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Originally Posted by omiotek View Post
on the body dolly
Did you have any worries about the car flexing while one the dolly? I've noticed when my car is on jack stands at those points the doors are a little misaligned. I need to replace my quarter panels as well and am debating welding in some temporary bracing while I do the work.
Crazy_pilot is offline   Reply With Quote
Old 10-07-2012, 04:23 PM   #219
omiotek
Member#: 272090
i didnt do the body work on that dolly. i just used it for transportation. realistically if i had a perfect place to do it i would of did the whole panel on a laser aligning frame rack but idont work in a body shop anymore.
so what i did was i used 4 jack stands at even heights leveled the car out and i have metal 2x4 beams across the pinch welds from side to side.
none the less my doors were fine on the dolly.... the goal is to get it perfect which is VERY hard.
Old 10-21-2012, 05:01 PM   #220
omiotek
Member#: 272090
so anyways heres a SMALL but BIG update.......
1. i sent the coilovers out to tein for a rebuild finally. i bought all my brake hardware and new parking brake shoes for the rears so i could get them all back together.
2. i started getting the remaining 2 hubs blasted and ready for paint. after those 2 i will install wheel bearings, seals etc etc and that will wrap up ALL the hubs.
3. heres the ****ty thing that happened to me......well i understand this is an old car BUT i took apart my entire rear end with no issues. well blasted, painted the whole 9 hards. upon reassembly i was re-shimming one of the sides and i put the retainers in. well i theaded all the bolts in as far as they would go by hand. all of them went about 3 quarters of the way. got 4 of the 5 done and torqued to spec..... number 5 comes the second i touch it with a ratchet to start snugging it up. the bolt snaps...... start to drill it and use an easy out.....well that snapped too....FML RIGHT
well these cars have a VLSD and the diff and everything else is fine, the housing is the problem. with a hardened easy out in there i wasent going to even attempt drilling it out. option 2 would be to drill TINY holes around the broken bolt, extract that entire piece out and weld it, drill it, tap it and back to normal but thats a HUGE headache. option 3 was find a whole new diff case.
well after doing some searching a local just totaled his RSTI. well upon talking to him i found out he had a low miles diff in his garage.. turns out its got like 12k on it from an original 01rs. OMFG score........ best part about it.... he understood my pain with this whole car and sold it to me for $50.00 and meet half way(25 minutes).big life saver and honestly i can salvage a good diff and parts and toss my old case. for $50 it was a headache and royal pain in the ass saved.
Old Rear end(both are from an 01) amazing difference
NEW VLSD Rear 4.11
4. tried out a new technique to fixed the age look of the white resovoir plastic... didnt wanna buy new do i made up a old remedy here. pm me if anyone wants to know it. none of these pics are photoshopped. i did the smallest thing possible incase it didnt work i wouldnt have to spend more money on the expensive resovoirs.
before
after
Old 10-21-2012, 05:01 PM   #221
omiotek
Member#: 272090
also got my fuel cell ice box thing in.....$80 off ebay never used.
well thats it for now....more to come.
Old 10-22-2012, 07:23 PM   #222
eastwoodsn352
Member#: 334442
2008 WRX STI
Coming along nicely! I can't wait to hear this thing!
eastwoodsn352 is offline   Reply With Quote
Old 10-22-2012, 08:16 PM   #223
3mlwhly
Member#: 217648
01 2.5rs
looks good!
3mlwhly is offline   Reply With Quote
Old 10-22-2012, 11:30 PM   #224
omiotek
Member#: 272090
Thanks everyone. Progress is slow but its getting there
Old 10-25-2012, 05:47 PM   #225
Hondaslayer
think you
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
And the secret technique to restoring plastic is?
My Supercharger Build Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 150 09-07-2011 11:40 PM
WTB : Omiotek WTB Thread(motor parts) omiotek Private 'Wanted' Classifieds 3 09-06-2011 12:46 PM
VIsubi's Raptor Supercharger build LetItSnow Normally Aspirated with bolt-on Forced Induction Powertrain 57 02-12-2011 07:11 PM
A supercharger build with actual power(Not Mine) ToneWrx02 Normally Aspirated with bolt-on Forced Induction Powertrain 15 01-31-2011 03:09 PM
What's needed to tune supercharge build on a 2.2L? NC_OBS Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-06-2009 02:00 PM
