Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Notices
Old 12-04-2009, 12:49 AM   #26
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
^Your ebay projector lights, are they nice??
I was thinking of buying those and doing a retrofit with them.
Smoke is offline   Reply With Quote
Old 12-04-2009, 03:37 PM   #27
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Yes I love them...they really put out and a big difference over stock..my only complaint is there one piece so they don't fit as flush like oem...I also don't really like the all chrome look...they would be sweet with the chrome toned down a tad.
Cbgrandtheftauto is offline   Reply With Quote
Old 12-04-2009, 04:59 PM   #28
gongeuzler
Member#: 16103
GC's
I have the SSAC kit on my 94 WRX swap.
Some trimming was required but nothing to crazy. Tucks away pretty good too!
gongeuzler is offline   Reply With Quote
Old 12-10-2009, 01:08 PM   #29
RexGF8
Member#: 55604
JDM GF8 WRX - sold
JDM GDA WRX
^^ that's a sleeper right there!
RexGF8 is offline   Reply With Quote
Old 12-11-2009, 12:33 PM   #30
dr3w
Member#: 222318
1993 RHD GC8
Just received the one i ordered , for the price I'm very happy with it.
Problems i did have on first inspection thou are:
Welds all look nice, except the bov flange looks like it was welded on by a blind 7 year old.
Also on the bov flange interior weld penetration there's alot of metal shavings hanging on by a thread. I will have to grind them off but if someone wouldn't of noticed it would definitely have done some damage. I've had this issue with every single intercooler kit i have purchased from eBay so it was expected.
and also i received all the proper coupling's except for one. I was given a 2" instead of a 2 1/2". Not really a problem since i believe i have 30+ couplings laying around from other intercooler kits I've purchased.
dr3w is offline   Reply With Quote
Old 12-18-2009, 06:17 PM   #31
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
I did the CX Racing kit. All I had to do was cut two pipes and add couplers, then bead roll it. For the bov, the adaptors for the evo's will work. You'll just need another coupler.
scrappydoo is offline   Reply With Quote
Old 12-18-2009, 07:06 PM   #32
dr3w
Member#: 222318
1993 RHD GC8
^ aw perfect your rhd as well. I was scared that the cold side pipe would hit the master booster but from your photos it doesn't! great
Old 12-18-2009, 09:10 PM   #33
corzy666
Member#: 177840
2000 swapped RS
White 330whp
Which two pipes did you cut? The hot side by the bottom of the fender, and the hotside right after the turbo? I will be doing this install by Christmas and just want to make sure I have enough couplers. Thx
corzy666 is offline   Reply With Quote
Old 12-18-2009, 09:52 PM   #34
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
I think the only problem is that the EJ20G has a different sized intake manifold so things get thrown off a bit. I dont think it's a problem since the couplers give enough bend to make it all work. I never got a whole good kit for mine. I bought a 02+ wrx setup that didnt work but I cant remember what was wrong with it.
Kaymin is offline   Reply With Quote
Old 12-19-2009, 10:57 AM   #35
scrappydoo
Member#: 23630
97 v4 STi RA
Ya, everything fit very well once I cut the pipes. You have to make the cuts anyway, so if you think you need to trim some off to avoid stuff it's no big deal. Btw, you'll really want to have the ends bead rolled. I had the pipes pop off a few times before I finally had it done.
I cut mine once on the top pipe on the hot side and once before the throttlebody. You can see the one on the tb in my previous pic. Here's one of the hotside before I put the pipe on:
Old 10-06-2012, 11:03 PM   #36
lord flashheart
Member#: 240766
2006 Outback 2.5XT
i just bough the CXracing kit for my 95 Legacy. (which should cross over with the GC8 with some modification.
so far, the fitment blows.
can anyone take some really detailed pictures of where the kit goes?
im having alot of issues with the second pipe. (hot side, right before the intercooler.)
so far the best fit for my car is to route it behind the head light and cut the "J" part right before the intercooler.
seriously more pics the better.
anyways here is mine on the dyno.. (as it sits now)
lord flashheart is offline   Reply With Quote
Old 10-07-2012, 10:57 AM   #37
corzy666
Member#: 177840
2000 swapped RS
White 330whp
In my GC8, there are 2 holes in the inside of the engine bay by the fender. Like in this picture that was posted above your post.
I'm not sure if the legacys have those holes there though.
If you do, then route your hotside through them and then to the intercooler core.
FS: Ebay FMIC for 02 WRX -?? fokai Engine/Power/Exhaust 12 02-10-2010 09:49 PM
brake trq specs for 93 gc8 wrx 93typeRA Pre-2002 Factory Turbo Powertrain 3 08-03-2009 01:17 PM
FS: Ebay FMIC for GC chassis Matt Monson RMIC Private Classifieds 1 04-30-2007 10:35 AM
Anyone with an ebay fmic for gc8? sheepdog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-12-2007 05:55 PM
fmic for sale gc8. 4wheelmotion Mid Atlantic Impreza Club -- MAIC 8 04-03-2003 01:35 PM
