Old 09-21-2012, 02:51 PM   #1
Joshsmiley55
Member#: 297223
95 Impreza Coupe
Green
Default 2.2 na with 2.5 cams and wrx turbo.
any thoughts on compression ratio and maybe some ideas on how to make this work.
the cams will be delta 1500s out of a 2.5l
along side a td04 setup from a wrx.
im going to get aftermarket valves and valvsprings, should i make the valves oversized?
any thoughts on what kind of horsepower and compression would be awsum.
also i have a set of ej22t pistons that could lower the compression ratio.
thanks everyone,
\sorry for party rockin =)
Joshsmiley55 is offline   Reply With Quote
Old 09-21-2012, 03:02 PM   #2
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
what heads?
what car is this going into?
HP is all from the turbo so with a td04 I'd expect 225-250whp or 275whp+ on good gas/maxed out
Filling out your user profile will help also
Old 10-06-2012, 03:13 AM   #3
Joshsmiley55
Member#: 297223
95 Impreza Coupe
Green
ej22e heads.
its all going into a 95 impreza coupe.
Old 10-07-2012, 02:31 AM   #4
AlaskanProtege
Member#: 217112
1998 GC8 modified
black and orange
your going to be about 9.3:1 cr which is pretty high. if you put the 2.2t pistons 8.5~:1
AlaskanProtege is offline   Reply With Quote
Old 10-07-2012, 03:26 AM   #5
Joshsmiley55
Member#: 297223
95 Impreza Coupe
Green
i knew they put out a lower compression i just didnt know what the numbers were. thats why i already bought them. i dont think im going to do the oversized valves... just upgraded valves and valvesprings.
