Old 07-15-2012, 04:16 PM   #226
eg33GC
Member#: 206851
56 Belair
Pro Street
I've got a 1994 Ej20g head I'd like to let you use to test
Old 10-05-2012, 02:24 PM   #227
pitcrew
Member#: 45715
1995 2.?L miami vice
Heavy Metal
selling a EJ25 SOHC Big Plenum Short Runner manifold:
http://forums.nasioc.com/forums/show....php?t=2415525
pitcrew is offline   Reply With Quote
Old 10-05-2012, 02:38 PM   #228
WReXd
Member#: 114101
93 Impreza L Swap
Any thoughts on the v5/v6 JDM manifold? Looks a lot different from most other subaru manifolds. Plenum looks significantly larger than the stock GD manifolds, but what disturbs me is the runners look the driver's side look longer than the passenger's... doesn't look like it'd flow evenly to me:
WReXd is offline   Reply With Quote
Old 10-07-2012, 01:08 PM   #229
opey
Member#: 333285
hard to really tell just looking at a pic, but it seems the plenum is offset to one side which is why the runners on one side are flat and the other side humps up, making them equal length
opey is offline   Reply With Quote
Old 10-09-2012, 04:55 PM   #230
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Might be the space for inlet pipe!
M4c0770 is offline   Reply With Quote
Old 11-02-2012, 01:57 PM   #231
Type2
Member#: 200436
2004 Forester XT
I'd really like to know how the Grimmspeed ported intake manifold flows. I have TGV deletes, ported throttle body and a bowl blend/minor port on my heads. Need to keep TMIC
Type2 is offline   Reply With Quote
Old 11-02-2012, 06:23 PM   #232
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
I offered and only response I got was it would be very close to stock and not worth testing
To close to build time now for me to offer again
bswilmington is offline   Reply With Quote
Old 11-20-2012, 08:29 AM   #233
Type2
Member#: 200436
2004 Forester XT
That's a good enough answer for me. If it's not worth testing I think I'll pass and spend my money on something more worth while.
Old 11-20-2012, 12:33 PM   #234
bswilmington
Member#: 217563
Well remember it wasn't tested, so that was an assumption. For me I don't wont to sacrifice spool so I'm sticking with stock one
Old 11-24-2012, 03:15 PM   #235
ISL33P
Member#: 220906
hoping to get flow and dyno results from this shortly
ISL33P is offline   Reply With Quote
Old 11-25-2012, 11:21 PM   #236
kakarot09
Member#: 182375
08 Sti
Wrbm
Are you doing a back to back comparison between intake manifolds or just putting a whole setup together with this and tuning?
kakarot09 is offline   Reply With Quote
Old 11-26-2012, 05:23 AM   #237
ISL33P
Member#: 220906
Back to back...car just went to the track and broke the trans and diff, so I am putting this on and another tune to see what the results are
Old 02-21-2013, 11:12 PM   #238
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Intake manifold test-dyno version is coming!
Stay tuned.
ASF Machine is offline   Reply With Quote
Old 02-22-2013, 12:00 AM   #239
kakarot09
Member#: 182375
08 Sti
Wrbm
How high will the test car rev? What sort of mod list? Just guessing from your work before it will be built heads ported, cams springs, etc and a 75 lb/min or more turbo
Old 02-22-2013, 12:27 AM   #240
Matty_STi
Member#: 333602
2012 STi
Stay tuned.
AWESOME!!!!!
this will be super cool to see!!!
Thanks for doing this
-Matt
Matty_STi is offline   Reply With Quote
Old 02-22-2013, 01:55 PM   #241
reid-o
Member#: 103631
2004 STI
I know that all testing is complete, but if you ever have time, like you don't work hard or anything jk, do you think you could flow test any of the manifolds with the throttle plate horizontal like most reverse manifold setups? It would be interesting to see and have actual data to see delta between cylinders other than to tell people "my car runs fine"
Just a shot in the dark
Old 03-12-2013, 09:16 PM   #242
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Corsa Veloce just got bought by Process West and put out a new manifold. Any data?
Tyrial is offline   Reply With Quote
Old 03-19-2013, 05:26 AM   #243
VIsubi
Member#: 187834
06 2.5i impreza
Red
So in conclusion our 2.5i manifolds not only can hold boost but flow great, which is why I'll stay Supercharged and enjoy all my intake manifold has too offer.
VIsubi is offline   Reply With Quote
Old 03-19-2013, 06:08 AM   #244
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
+12345
Old 04-12-2013, 06:48 PM   #245
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
I just sent ASF Machine an email about trying to get hold of one of these ported 2.5i intake manifolds for my build. I have been wanting to avoid the Cosworth manifold; $1100 for a chunk of cast aluminum that doesn't flow as well as I would think it should. I was told about the 2.5i IM by my tuner and it sounded like a pretty good option. It keeps sounding better and better now that I have learned of ASF Machine's porting work and testing. I figure with the flow numbers they are showing I should be able to put it to good use. We are expecting my setup to run 35+ psi on e85.
Engine:
Sleeved EJ257 done by LA Sleeve
Cosworth pistons
Cosworth rods
Cosworth oil pump
08+ nitrided crank
ACL bearings
MAPerformance H11 head studs
Hand ported/polished heads
Ferrea stock size valves
SuperTech 82lb springs/titanium retainers
GSC S3 282 cams
AMR UEL big tube header
AMS 900x V-band rotated kit
Precision PTE6466
Tial MV-R 44mm EWG
Tial Q 50mm BOV
APS DR525 FMIC
Boomba Racing top feed fuel rails
TiC composite TGV housings
FIC 2150cc injectors
-8 feed fuel line
Aeromotive FPR
Walbro 460lph fuel pump hardwired
Megan Racing catback exhaust
Cusco catch can
Corinator is offline   Reply With Quote
Old 04-16-2013, 03:25 PM   #246
0to115in11
Member#: 140832
Just received mine last week!!!! When I opened the box I was speechless! Can't wait to see how it performs!
0to115in11 is offline   Reply With Quote
Old 04-16-2013, 05:04 PM   #247
wantsti
Member#: 134764
04 sti
java black pearl
Where is that from? ASF?
wantsti is offline   Reply With Quote
Old 04-16-2013, 05:15 PM   #248
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
^this x2
DarkKnightBaku is offline   Reply With Quote
Old 04-16-2013, 05:18 PM   #249
0to115in11
Member#: 140832
Yes, this intake manifold is from ASF
Old 04-16-2013, 05:19 PM   #250
Scargod
Member#: 260314
2008 STI hatch
What the hell is that?
Looks like it is based on a NA intake.
Who's throttle body?
Scargod is offline   Reply With Quote
Subaru Cylinder Head Flow Database ASF Machine Built Motor Discussion 48 08-23-2015 05:05 PM
best flowing OEM intake manifold Gamble_WRX Built Motor Discussion 20 05-25-2010 09:52 AM
WTB high flow intake manifold and internals modusvivendi Private 'Wanted' Classifieds 2 08-06-2009 11:25 PM
'04 Plastic Intake Manifold Flow Numbers SOLUTION Normally Aspirated Powertrain 1 03-14-2006 08:03 PM
AVO high flow intake manifold aspera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-10-2002 09:58 AM
