Old 10-07-2012, 01:31 PM   #1
pooters1075
Member#: 253674
Default oil leak please help
i have a 2003 wrx that has and oil leak. i just cant pin point the problem.
i changed the cam seals crank seal valve cover casket but it still drips from the passenger side rear timing belt cover and drips right onto the headers heat shield, any input will be appreciated
pooters1075 is offline   Reply With Quote
Old 10-07-2012, 04:19 PM   #2
corvallisbattery
Member#: 333030
'05 WRX
Check your oil feed line from the block to the turbo (Solid steel) and the oil return line on the bottom of the turbo (rubber). Those are pretty common leak issues. Best to remove the turbo heat shield to get a good look.
corvallisbattery is offline   Reply With Quote
Old 10-13-2012, 10:19 PM   #3
pooters1075
Member#: 253674
found the problem
Old 10-13-2012, 11:11 PM   #4
04reddragon
Member#: 216553
2006 wrx sti
gray
Wat was it?
04reddragon is offline   Reply With Quote
Old 10-13-2012, 11:56 PM   #5
pooters1075
Member#: 253674
bottom cam seal cap was loose
Old 10-14-2012, 12:27 AM   #6
04reddragon
Member#: 216553
2006 wrx sti
gray
Nice!
