Old 10-06-2012, 08:20 PM   #51
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Originally Posted by UKscooby View Post
Hmm that gas has been in there for years with stabil added. However the boat has been doing this for a lot longer than the age of that gas. It was given to me because of this issue.
Haven't checked the difference honestly as I only got to run it for about 15 minutes. I do know that a 1/4 turn will now make a difference whereas before it was a good turn before I could detect a change. Starting is much easier too.
Change your fuel, but I'm also starting to wonder about the possibility of an intake leak. If you have to go almost full rich on your idle screw to get it to run, then you could still not be getting enough fuel to it under tip in even with the accelerator pump working.
VpointVick is offline   Reply With Quote
Old 10-06-2012, 08:35 PM   #52
UKscooby
Member#: 33287
RIP Nik
I will always miss you
Idle screws in = rich? It runs rough if they are all the way in.
UKscooby is offline   Reply With Quote
Old 10-06-2012, 08:37 PM   #53
UKscooby
Member#: 33287
RIP Nik
I have some starter fluid which I can use to check for leaks.
Old 10-06-2012, 09:03 PM   #54
VpointVick
Member#: 93193
'03 325iT
Mysticblau
The screws control fuel flow, so, turning them in leans it out.
Old 10-06-2012, 09:17 PM   #55
UKscooby
Member#: 33287
RIP Nik
Spec says anywhere from 2 to 7 turns with a turn difference between screws. Its easily within spec and is probably 3.5 turns out each.
Old 10-06-2012, 09:23 PM   #56
VpointVick
Member#: 93193
'03 325iT
Mysticblau
This has some tips about using a combo square to make some of the static adjustments.
Do the rebuild kits still come with the useless plastic square and the measurement charts that nobody ever bothers with?
Old 10-06-2012, 09:33 PM   #57
hkerekes
Member#: 66310
2015 korean muscle
Have you checked fuel pressure and or the ignition system?
Low fuel pressure = leansauce
It still will run but just like **** and it might squirt some but not enough.
A worn cap / rotor will also make it run crappy.
hkerekes is offline   Reply With Quote
Old 10-06-2012, 09:38 PM   #58
VpointVick
Member#: 93193
'03 325iT
Mysticblau
I agree that it'd be a good idea to check fuel pressure, but the backfire at tip in is pretty telling of a lean out. He says that it'll run strong on top if he gets it there gradually, so I doubt the ignition system's the culprit.
Old 10-06-2012, 11:46 PM   #59
Matt K
Member#: 45204
16 you don't
respond to danger
It might not be the issue, but trying to diagnose and tune a carb on old gas is bad juju. Put fresh gas in it even if you don't thi.k thats the problem. I like to drain the tank and put the old gas in my fiancee's car, since modern fi engines rarely give a ****.
It still sounds like its lean on tip in. 2 things i might try (although they are sort of bandaid fixes) would.be backing the screws out a turn or 2, and/or raising the float in the primary bowl. Both will ricken up the mixture a bit (the screws at idle and the float across the board), maybe enough to get by.
Might also take apart and clean the pump again, and the sqirter nozzle. Sometimes when amateurs like us rebuild a carb we knock gunk loose from one place.and it gets.stuck in a new place...
Matt K is offline   Reply With Quote
Old 10-06-2012, 11:50 PM   #60
UKscooby
Member#: 33287
RIP Nik
Brand new cap, rotor, condenser, wires, plugs and coil. I haven't checked fuel pressure but it will run up to wot if you take about 5+ seconds to do it. If you "floor it" at anything above 3000ish rpms it does not bog, hesitate or shoot flames.
If it stops raining tomorrow I'll see.if I can take some video.
Old 10-06-2012, 11:54 PM   #61
noise boy
Member#: 190706
2015 Ford Fiesta ST
Might need a bigger squirter for the accelerator pump, if you can do the 3000rpm and up mash it you are already through the pump stroke at that point and solidly in the secondaries.
noise boy is offline   Reply With Quote
Old 10-06-2012, 11:57 PM   #62
UKscooby
Member#: 33287
RIP Nik
I hear you Matt. In all honesty this thing looked very very good inside. No dirt and very minimal scale buildup in the bottom of the float chamber. I cleaned everything out with carb cleaner and then blew it out with 120psi shop air.
I still do not like the pump operation. I was playing with it again and it doesn't do anything until the throttle has been moved about 25%. It should start as soon as the throttle is moved. I took it all apart and confirmed measurements are correct per that crappy square and the table only I look at. It is an improvement but in no way is it a solid instant instantaneous squirt.
Old 10-07-2012, 12:00 AM   #63
hkerekes
Member#: 66310
2015 korean muscle
I agree that its also likely a vacuum issue now or the carb itself has issues that a rebuild cant fix.
Old 10-07-2012, 12:06 AM   #64
hkerekes
Member#: 66310
2015 korean muscle
Old 10-07-2012, 12:28 AM   #65
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Good advice if it was a Holley 4bbl, but it's a Rochester 2bbl we're talking about.
Old 10-07-2012, 12:27 PM   #66
UKscooby
Member#: 33287
RIP Nik
Crap video close up of the carb. Its in portrait and has a piece of paper tape flapping in the way but it does have flame. You're seeing the choke flap moving.
So, new issues this morning. After a very cold wet night (34 deg F) it started rough this morning and idled for crap. It ran best with both needles turned in full and there are fuel drips from each venturi. I can also see that the accelerator jets are working terribly again.
I'll get better video in a bit when my phone has charged up some more.
Old 10-07-2012, 01:15 PM   #67
hooziewhatsit
Member#: 143938
What's your fuel pressure? Dripping usually means the needle valves aren't shutting completely (crap in the way), or to much fuel pressure. If you pinch off the fuel line do they stop dripping?
hooziewhatsit is offline   Reply With Quote
Old 10-07-2012, 01:32 PM   #68
UKscooby
Member#: 33287
RIP Nik
If they were dripping it'd be running rich and the bogging would be less, right?
I don't know the pressure. I'm guessing its more to do with the needles not seating right.
More video:
http://static.photobucket.com/player...007_131132.mp4
http://static.photobucket.com/player...007_125748.mp4
Old 10-07-2012, 03:55 PM   #69
Matt K
Member#: 45204
16 you don't
respond to danger
i can make my holey drip fuel by raising the floats to high...
if you're not getting fuel from the pump till 1/4 throttle, then that is still probably the problem. You should get fuel almost the instant you breathe on the throttle.
How big a motor and carb are we talking about? My holley 650cfm carb on a ford 351 appears to shoot a good deal more fuel than that (of course that's just based on eyeballing your videos)
If you disconnect the pump from the linkage, can you actuate it manually?
Old 10-07-2012, 04:42 PM   #70
UKscooby
Member#: 33287
RIP Nik
I rebuilt the pump and had it running perfectly for about 5 minutes. Super excited until I looked down at the temp gauge and saw 160 instead of 120. It was then I realized I forgot to turn the hose pipe on. I killed the impeller. Supposedly this ez load trailer is worth about $800. Any takers? Comes with free boat.
Old 10-07-2012, 06:02 PM   #71
L Bo
RIP Brother
Member#: 8739
Did you already drain and replace your fuel before posting that vid? Not familiar with your carb but know dirty fuel can wreak havoc as well dirty or clogged jets.
If you rebuilt the carb and still have issues I would start with new fuel and making sure jets are clean. Thats all I got.
L Bo is offline   Reply With Quote
Old 10-07-2012, 06:44 PM   #72
VpointVick
Member#: 93193
'03 325iT
Mysticblau
They say a boat is a big hole in the water that you throw money into.
Old 10-07-2012, 07:08 PM   #73
UKscooby
Member#: 33287
RIP Nik
I was sick to my stomach. I almost cried. All weekend long I've been telling myself water first engine second.
L bo: fresh fuel and a spotless carb. It runs fine now.
Old 10-07-2012, 08:09 PM   #74
Matt K
Member#: 45204
16 you don't
respond to danger
Hahaha, impeller should be like $30 and 10 minutes to change out, everybody does it once
Congrats on getting it running right!
Old 10-07-2012, 08:57 PM   #75
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Did my original post never make it though the sensors? Or is this a new thread?
bcblues is online now   Reply With Quote
