Old 10-06-2012, 02:39 PM   #1
timbrooks
Member#: 334307
Default upgrading?!
hey everybody.
ive recently bought a 02 wrx and i just wanted to ask around and see what should be my first upgrade after i tune it up and make sure everything is running good.
however i do have a budget. i'm only 20 plus im a full time student and work full time.
ive heard of installing a short ram or cold air intake, switching to 3" piping, and switching to high performance spark plugs, but im new to all of this so i wanted advice from ppl who actually owns a wrx.
any advice would be greatly appreciated!!
timbrooks is offline   Reply With Quote
Old 10-06-2012, 02:41 PM   #2
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Make sure you get a tune for your mods.
Read Unibomber's Manifesto. It'll answer all the questions you have. We don't hand out answers like that. Welcome and Grats on the car!
Navendra94 is offline   Reply With Quote
Old 10-06-2012, 02:49 PM   #3
timbrooks
Member#: 334307
Thank you, Much obliged!!
Old 10-06-2012, 03:46 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Stock spark plugs, no intake. Downpipe and a tune.
Old 10-07-2012, 01:56 AM   #5
Hell015
Member#: 330086
2004 WRX Wagon
If you would like a little more power and peace of mind, you could swap out the stock up pipe for a catless one.
Hell015 is offline   Reply With Quote
Old 10-07-2012, 03:45 AM   #6
sc00by4life
Member#: 97135
the best mods on a budget is called maintenence.
keep up on it.
if you have a limited budget, and something breaks, you might not be able to fix it.
Old 10-07-2012, 04:10 AM   #7
rob1n1
Member#: 276425
2013 335is
Alpine White
You have a 10 year old car and I'm guessing you need it to go to work/school. Spend any money you have on maintaining it.
rob1n1 is offline   Reply With Quote
Old 10-07-2012, 08:53 AM   #8
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
my basic approach is quality and timely maintenance and when things break/wear out install better. i modded to preserve my 100k warranty then phase 2 after.
Regular maintenance like wax exterior, clean interior, regular oil change, water wetter are not expensive. when things get replaced install better example irridium sparkplugs total $24.
so what else to upgrade? set goals for the car that fit your lifestyle and budget and read nasioc and read again.
mhoerath is offline   Reply With Quote
Old 10-07-2012, 03:51 PM   #9
timbrooks
Member#: 334307
Thank you! I know I'm def going to make sure it's running properly before I make any upgrades! Thank you all though!
Old 10-07-2012, 03:59 PM   #10
paulpat
Member#: 237145
02 WRX
12 FXT
stock intake
stock plugs
These are a must:
DO A TIMING BELT! or else engine will explode!!!
used catless uppipe so your engine doesnt explode!!!
Buy a used dp
If you have money left over then spend it on a downpipe and a tune. By then you will know enough about your car.
paulpat is offline   Reply With Quote
Old 10-07-2012, 05:00 PM   #11
timbrooks
Member#: 334307
Well I had a friend whose a mechanic check the belt and he said its good! But il get a second opinion and the previous owner already installed a invidia uppipe! So then I should just get a down pipe and that would be good for now right?
Old 10-07-2012, 05:51 PM   #12
TwoFifty
Member#: 261764
2003 Impreza WRX
How many K's are on the car? There is a spec for when the timing belt should be replaced, it's there for a reason, do it then, not before and not after.
Maintenance is key, there's no point in spending all this money on aftermarket parts and then never changing the oil on the car, or brakes and so on.
Just buy the regular recommended spark plugs for your car, search Unabombers manifesto, there is a thread in there to do with the plugs that are supposed to be used in our cars. Don't waste your time or money with "high performance plugs"
TwoFifty is offline   Reply With Quote
Old 10-07-2012, 07:05 PM   #13
Tdaz250
Member#: 310744
02 WRX
Once all the maintenance is done definitely change the stock uppipe to a catless so your turbo doesn't eat the cat. Then when you have the money get a downpipe and a tune at the same time. Also an intake at the same time as the tune if you want one.
Tdaz250 is offline   Reply With Quote
Old 10-07-2012, 09:19 PM   #14
socalflat4
Member#: 330562
2002 WRX Wagon
Another vote for the catless up pipe and miantenance, that's where i'm at as well with my recent purchase
socalflat4 is offline   Reply With Quote
Old 10-07-2012, 11:06 PM   #15
TwoFifty
Member#: 261764
2003 Impreza WRX
Lol Apparently nobody reads threads anymore. About 4 posts up the OP states that the previous owner installed an Invidia Up pipe into the vehicle already.
Old 10-07-2012, 11:54 PM   #16
luvless2620
Member#: 190566
Window tint is always a nice cost effective first upgrade.
luvless2620 is offline   Reply With Quote
Old 10-08-2012, 12:04 AM   #17
timbrooks
Member#: 334307
Currently there is a 120k! Im trying to get the tune up this week and then il go from there with all the advice you guys said!
Old 10-08-2012, 12:08 AM   #18
sc00by4life
Member#: 97135
sounds like time for timing belt, tensioner, pulleys, and water pump if they haven't been done.
Old 10-08-2012, 12:37 AM   #19
timbrooks
Member#: 334307
See that's how new I am to this bro! Lol I've heard about everything else but never about a tensioner thing!
Old 10-12-2012, 01:48 AM   #20
Tdaz250
Member#: 310744
02 WRX
Look for a gates timing belt kit. Comes with the belt, water pump and timing belt tensioner. Cant remember how much mine was but i wanna say like 250.
This isnt the one for your car but look for something like this.
http://www.ebay.com/itm/Gates-TCKWP3...751938&vxp=mtr
Get that done...change your trans and rear end fluid...you'll end up changing your coolant when you do the timing belt change. Then go from there. Spark plugs too, i'd recommend NGK iridium plugs...dont do one step colder. Defiantly do this stuff first and you'll be golden.
And yes once you do that stuff i'd say get a catless downpipe and a stage 2 tune from a reputable shop nearby.
Old 10-14-2012, 12:59 PM   #21
timbrooks
Member#: 334307
Ok thank you!! il look into that immediately!
Old 10-14-2012, 08:42 PM   #22
jimbosv650
Member#: 261307
04 wrx wagon
I don't know if you already have one, but a boost gauge is a must. Every turbocharged vehicle should have one, even stock ones.
jimbosv650 is offline   Reply With Quote
Old 10-14-2012, 08:46 PM   #23
cvananden
Member#: 326698
2006 WRX Ltd.
San Remo Red
Timing belt and a catless uppipe are a plus...but I don't personally believe in buying a used downpipe, at least if you're going to stick with a catted one. If you go catless, that's another story.
also, EXPLODE!!!
Originally Posted by paulpat View Post
stock intake
stock plugs
These are a must:
Buy a used dp
cvananden is offline   Reply With Quote
Old 10-15-2012, 10:21 AM   #24
DoogieSTi
Member#: 247023
2007 STi
I got my Gates timing belt kit with water pump for $300ish. They shipped it to Italy in about 6 days, which is very fast. Good luck with the work. Look up Meatys timing belt thread...there are videos!?!!
DoogieSTi is offline   Reply With Quote
Old 10-15-2012, 11:19 AM   #25
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
OP Welcome to NASIOC! I also started with an 02 WRX, great car! Lots of love for the bugeye.
stock intake
stock plugs
These are a must:
Buy a used dp
Great advice right there. Don't forget to do the water pump when you go in there and do the timing belt. On my 02 the coil packs started to have issues at that mileage also. Also, what tires on the vehicle? If they are crap, replace them before modifying.
As for modifications, because you are starting on a vehicle that is high in mileage I'd inspect first what needs attention and go from there. For instance, you don't want to make more horsepower if your suspension and or brakes are in bad shape.
If the brakes are in great shape and the suspension is nice and tight then start with some used exhaust bits. I don't recommend going used with everything, but a pipe is a pipe new or used. Just make sure it's not rusted, dented or in abnormally rough shape in any other way. Uppipe, downpipe and the rest of the exhaust and also pick up a used V2 AccessPort. I would also highly recommend either DEI thermal wrapping the uppipe and downpipe sections or sending them out to get ceramic coated. Goes a long way in turbo spool (not that a TD04 needs much help ) and under hood temps.
This would put you pretty much on par with a stock STI. Plenty of street power and lightning fast spool. From here I'd focus on suspension (coilovers or a nice spring/strut combo...maybe some endlinks and swaybars, etc.) Good luck and enjoy the car
Steve.804 is offline   Reply With Quote
