Old 10-06-2012, 11:11 PM   #1
mash740
Member#: 310419
2002 wrx
Default wheel bearing/hub help
I got a 2002 wrx, and I'm pretty sure my rear passenger wheel bearing is going bad.. There is some movement in the wheel.. also when i go down the highway my steering wheel shakes a little bit.. could that be the front bearing or could the back cause that??.. Also when you replace the wheel bearing should I replace the hub as well??
mash740 is offline   Reply With Quote
Old 10-07-2012, 10:48 AM   #2
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
You generally have to use a press to get the old bearing out of the hub and a press to press the new bearing into the hub.
You could buy a whole new hub, or a remanned one also.
tebriel is offline   Reply With Quote
Old 10-07-2012, 12:31 PM   #3
mash740
Member#: 310419
2002 wrx
Yea I know you have to press them in.. Do you think I should just buy a new hub as well? and just junk the old one
Old 10-07-2012, 12:39 PM   #4
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Absolutely
Old 10-07-2012, 02:12 PM   #5
ojala
Member#: 255441
05 Saabaru
You might look at the hub shark/hub tamer. Hazardous Freight makes a cheap knockoff for $80 that works fine. They call it a FWD bearing adaptor I think. It cuts way down on the time/effort to replace bearings because you dont have to remove the hub and get an alignment. Just remember to lube the bolt, and dont use an impact on it.
ojala is offline   Reply With Quote
Old 10-07-2012, 02:13 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It depends, sometimes the bearing spins on the hub, destroying it, so in that case, yes..
Otherwise its an economics call...
Old 10-07-2012, 05:26 PM   #7
Supraru
Member#: 23313
99' 2.5Rs
black
99 times out of 100 you don't need a new knuckle and would be a complete waste of money. If you're saying there is play in the rear wheel that you think is making noise I'd say go with a new knuckle. I had play in mine years ago and put in a new bearing. Didn't have noise just had a little play. When the new bearing was in the knuckle I still had play. Later down the road I put on a new knuckle and problem was fixed.
Supraru is offline   Reply With Quote
