Old 09-22-2012, 04:42 PM   #1
garinhash
Member#: 149670
2002 impreza wrx
blue
Default 02 wrx "randomly" stalling when coming to stop
this issue started a few months back, the car is a stock 02 wrx wagon, i have not done anything to the engine, most that i have ever done (myself) to the car is change the oil/filter, ect...
when coming to a stop i let in the clutch and apply breaks, before coming to a complete stop the idle will drop to 0.
first time was maybe 3 months ago, second was maybe last month, but in the last 2 weeks it hss done this 4 times maybe, today i was driving for less than 45 min and it stalled twice.
i was sitting at a drive through for several minutes and it was fine, got my food drove off, at the very first stop i came to i did the same thing, pushed in clutch and applied breaks then it stalled out.
i tried to restart it again before coming to a full stop by pushing the clutch in all they way and turned the key, and then i heard the starter making a very unpleasant grinding noise.... so i came to a full stop, and shut the car off completely (no one was behind me), then turned the key and the car started right up.
any ideas what this could be? i am becoming worried because it seems to be getting progressively worse
edit:
also when the car stalled i do remember seeing the check engine light come on, but once the car started up again the light was gone.
i just used my code reader and it said 0 codes :/
garinhash is offline   Reply With Quote
Old 09-22-2012, 05:02 PM   #2
WhiteRex757
Member#: 323600
This was happening on the previous car I owned. Turned out to be a bad maf sensor.
WhiteRex757 is online now   Reply With Quote
Old 09-22-2012, 06:36 PM   #3
garinhash
Member#: 149670
2002 impreza wrx
blue
is there anywy i can test to see if that could be my issue?
Old 09-22-2012, 07:03 PM   #4
hoffmanEstates
Member#: 122043
04 wagonier
psm
Buy a cleaner for maf. Then if no change swap with a local guy. And drive any leaks on the bov?
hoffmanEstates is offline   Reply With Quote
Old 09-22-2012, 08:33 PM   #5
garinhash
Member#: 149670
2002 impreza wrx
blue
i believe i just have a CBV, not a BOV, i think thats what the stock wrx wagons have
Old 09-22-2012, 08:50 PM   #6
Bansheeboy11
Member#: 182415
1999 RS
Do you have an actual blow off valve? or still the stock bpv. Both of my buddies who had BOVs were untuned and had the exact same problems.
Bansheeboy11 is offline   Reply With Quote
Old 09-22-2012, 09:45 PM   #7
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Yes stay away from the damn Bovs too.. my car doesn't start sometimes because of the Bov, the previous owner put on. I am actually about to order the stock one...now!
Fir3Fighter is offline   Reply With Quote
Old 09-22-2012, 10:22 PM   #8
garinhash
Member#: 149670
2002 impreza wrx
blue
it seems like this issue is caused by a vacuum leak, or something air related?
Old 09-22-2012, 10:43 PM   #9
Pinoy_Flip
Member#: 259802
2002 Bugeye
Blaze Yellow
Or iacv?
Pinoy_Flip is offline   Reply With Quote
Old 09-23-2012, 12:49 AM   #10
svxninja
Member#: 279510
02 Wrx
Icav .........
svxninja is offline   Reply With Quote
Old 09-23-2012, 12:52 AM   #11
Jacobs11
Member#: 268948
04 WRX
PSM Sold :(
Same thing happened to me... clean your IACV
Jacobs11 is offline   Reply With Quote
Old 09-23-2012, 01:06 AM   #12
TwoFifty
Member#: 261764
2003 Impreza WRX
Just to clear a few things up,
That funny noise your starter made when trying to engage it while the vehicle was still moving... that's the gear in the starter trying to engage onto an already turning flywheel, NOT a good idea.
The check engine light comes on whenever you turn the key to the 'ON' position, this is a bulb check, happens in every car. When the car stalls out the ignition is left in the 'ON' position. So therefore the check engine light will be on until the ignition is turned off or vehicle is restarted. This is not a code setting.
TwoFifty is offline   Reply With Quote
Old 09-23-2012, 01:43 AM   #13
garinhash
Member#: 149670
2002 impreza wrx
blue
well that makes sense, i stopped turning the key immediately when i head the grinding then waited till i came to a stop. :/
i had a feeling that was why the check engine light was on, i figured i would check though.
i will try cleaning the IACV.
i will search for a way to clean a IACV for a 02 WRX, unless someone knows a guide or maybe a video to link
Old 09-23-2012, 02:05 AM   #14
corvallisbattery
Member#: 333030
'05 WRX
def clean the IAVC and replace the gasket, most dealers stock this. Get a stock BPV and clean the MAF
corvallisbattery is offline   Reply With Quote
Old 09-23-2012, 02:16 AM   #15
TwoFifty
Member#: 261764
2003 Impreza WRX
Always better to check and be sure.
I believe there is a really good thread that walks you through cleaning the IACV somewhere on this forum, you'd have to search it up though.
Old 09-23-2012, 02:44 AM   #16
garinhash
Member#: 149670
2002 impreza wrx
blue
how much would this gasket go for?
i also found this guide for the IACV cleaning:
also i found http://forums.nasioc.com/forums/showthread.php?t=781242
hopefully this is all i need
Old 09-23-2012, 05:38 AM   #17
pghana66
Member#: 302066
that is the thread i followed to clean my iacv back in july. it is a really helpful write up. the gasket is about 8 bucks from dealer if i recall correctly. if that valve is ur problem the cleaning should do the trick.
pghana66 is offline   Reply With Quote
Old 09-24-2012, 11:18 PM   #18
garinhash
Member#: 149670
2002 impreza wrx
blue
going to go the the parts department on my local Subie dealer, i have had no issues for the last 2 days, i have been watching my rpms like a hawk at every stop i come to.
Old 10-03-2012, 07:34 PM   #19
garinhash
Member#: 149670
2002 impreza wrx
blue
update:
i had the day off so i removed the IACV, cleaned it using WD-40, replaced the gasket, ect...
i am hoping i wont have anymore stall's at stops now (fingers crossed)
Old 10-04-2012, 08:10 AM   #20
Blind250
Member#: 334120
I have a 2004 Sti with the same problem, I have checked almost everything but iacv
Blind250 is offline   Reply With Quote
Old 10-05-2012, 10:01 PM   #21
Rucd8
Member#: 291028
2nd on the maf being the problem
Rucd8 is offline   Reply With Quote
Old 10-07-2012, 04:53 PM   #22
purdyclevur
Member#: 288781
2004 Impreza WRX
Red
what about the o2 sensor
purdyclevur is offline   Reply With Quote
Old 10-08-2012, 06:15 PM   #23
garinhash
Member#: 149670
2002 impreza wrx
blue
so far i have not had any issues, no stalling or anything, fingers are still crossed
Old 10-31-2012, 10:21 AM   #24
Bryan T
Member#: 17948
My stock '02 WRX wagon does this, too. The issue seems to come and go, but it is always when I'm braking with the clutch pedal in.
Bryan T is offline   Reply With Quote
Old 11-02-2012, 12:24 AM   #25
Alann314
Member#: 319350
2005 Impreza WRX
Could be your IAC(Idle Air Control valve) a bad MAF sensor or if you have a intake with a big MAF it really messes with your car I had a short ram Perrin and my car wouldn't stall but it would drop extremely low in RPM's and shoot right back up to idle.
Alann314 is offline   Reply With Quote
