Old 07-19-2011, 01:16 AM   #1
Jackie
Member#: 81608
Default Computer help: laptop won't boot.
Pardon me for asking here, I just don't feel like finding and signing up for some sort of PC help board; and I know a lot of people here are tech gurus...
About two weeks ago, my Toshiba A305 laptop would not boot after I restarted it (er, attempted to). Power lights came on, fans turned on, CD drive fired up, the "drive" light came on for a few seconds, then back off; then nothing. Nothing displayed on the screen, power light on, fans running. CD drive still works (ie. you open and close it and it will read), but no hard drive activity whatsoever.
I tried taking out the battery and holding down the power button for ~2 minutes and plugging it back into power, with no luck. Also tried holding down various buttons while turning it on.
So after screwing with it I left the laptop plugged in with no battery while I browsed on my desktop, and lo and behold after about 15 minutes the laptop booted up normally on its own .
When Windows loaded it installed a few updates, and I figured it was just some weird glitch. Been functioning perfectly for the last ~2 weeks or so (haven't turned it off since).
Well, I went about cleaning my computer today and went to reboot it, and now it's doing the exact same thing it was before . Hard drive won't boot.
After doing some research, it sounds like symptoms of a bad motherboard; but if that were the case, would it have randomly booted on its own before? And then worked perfectly for 2 weeks?
Wouldn't the motherboard be toasted, or not?
Could it just be a loose internal connection or something?
Any opinions/suggestions/info would be greatly appreciated.
Jackie is offline   Reply With Quote
Old 07-19-2011, 01:32 AM   #2
Cartmans 03_Wagon
Member#: 222833
. Guess who's
back. Back again.
should have got a mac.
Cartmans 03_Wagon is offline   Reply With Quote
Old 07-19-2011, 01:34 AM   #3
skywaffles
Member#: 82470
I am more humble
than you can understand.
I'd make sure the HDD wasn't defective and the cable is properly seated.
skywaffles is offline   Reply With Quote
Old 07-19-2011, 01:36 AM   #4
KidCorporate
Member#: 199947
Then who was computer!?
KidCorporate is offline   Reply With Quote
Old 10-07-2012, 02:57 PM   #5
Jackie
Member#: 81608
So, I figured out that if I hold the computer up on the front left side and tap near the mouse buttons a few times, the hard drive will boot
But now, I'm having more issues...
It refused to boot past the loading bar "Microsoft Corporation" screen a few weeks ago; wouldn't even boot in safe mode. I was finally somehow able to get it to boot after running chkdsk, boot CD etc., so I backed up all my files and reinstalled Windows with the Toshiba Recovery Disk.
Worked fine for a week or two, and now it's doing the same damn thing
Everything seems to work fine except the hard drive won't load. I can get into BIOS and mess around and everything.
Would replacing the hard drive be a logical step?
If so, if I already have all my files backed up, do I have to prepare for installing a new hard drive in any way?
Any recommendations for a new hard drive? The current one is a 320gb 5400rpm, MK3252GSX.
(sorry I'm potato with computers)
Old 10-07-2012, 03:18 PM   #6
kilowhisky
Member#: 134144
Wait, you've been trying to fix a Toshiba for over a year? suck it up and buy something that works.
kilowhisky is offline   Reply With Quote
Old 10-07-2012, 03:25 PM   #7
Jackie
Member#: 81608
No, its been working fine in the interim. Just started having more issues, and if I can have a working laptop by spending $60 on a new HDD rather than several hundred on a new laptop, I'm going to.
Old 10-07-2012, 03:44 PM   #8
foothill
Member#: 292246
2010 Badge Snob
2012 Slow Ford
Try sticking it in the freezer for an hour or so. Toshibas are known to react well to this trick.
foothill is offline   Reply With Quote
Old 10-07-2012, 04:02 PM   #9
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Craigslist.
I hear it is the solution to everything.
Old 10-07-2012, 05:43 PM   #10
Jackie
Member#: 81608
Old 10-07-2012, 05:56 PM   #11
87blackstar
Member#: 257057
1987 Mitsubishi
Starion GSR-VR
Originally Posted by Jack ffr1846 View Post
http://massachusetts.backpage.com/adult/
Fixed....
87blackstar is offline   Reply With Quote
Old 10-07-2012, 07:11 PM   #12
LastWS6
Member#: 30781
2008 TBSS
Red
I had that problem with two computers at home. It was a vista-sleep mode- motherboard conflict. I took the system battery out waited 5 minutes and put it back in. Had to reset the time and disable sleep mode.
Worked for my PCs might give it a try.
LastWS6 is offline   Reply With Quote
Old 10-07-2012, 08:01 PM   #13
try that with a laptop.....
go ahead....we'll wait.............................................. ..............
Old 10-07-2012, 08:13 PM   #14
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I would guess it is a hard disk problem. By the sound of you having to "tap near the mousepad" I would guess that it is a connection problem,rather than a failing HDD. A failing HDD typically will cause blue screens and other issues, in addition to boot problems. I would take it apart and make sure the HDD cable connections are sound.
bcblues is online now   Reply With Quote
Old 10-07-2012, 09:41 PM   #15
Jackie
Member#: 81608
Got it to boot somehow. Running fine, just very slow. Constant updates since I re-installed Windows
I dunno, I think I'm gonna pick up a new HDD tomorrow. I found a 90gb SSD one for $60. Pretty cheap, seems worth a try.
Old 10-07-2012, 10:07 PM   #16
bcblues
Member#: 17256
04 STi
Sheez! Look at Newegg.com,unless you absolutely have to have it overnight. Have you tried resetting the cables?
Old 10-08-2012, 01:27 PM   #17
Jackie
Member#: 81608
Strangely enough, a local place actually has the same price as the cheapest I could find online, and no shipping to deal with... some kind of sorcery.
Old 10-08-2012, 02:55 PM   #18
LastWS6
Member#: 30781
2008 TBSS
Red
never had a lap top.
I see now. It has a cmos battery but is a permanent battery.
STEP 22
Remove two screws securing the wireless card.
Remove the wireless card if you didn't do it before.
NOTE: The RTC (CMOS) battery is permanently soldered to the motherboard
My bad i apologize.
http://www.google.com/imgres?imgurl=...%3Disch&itbs=1
Old 10-09-2012, 02:10 AM   #19
Jackie
Member#: 81608
Well I replaced the HDD with a 90gb SSD and did a clean Vista install.
Computer is FLYING. Took my WEI score from a 1.0 to a 4.0, and everything is SO much faster.
We'll see if the problems return, but damn, what a good way to spend $60. It's like a whole new computer.
OT computer peeps: Vista won't boot. halp? Gerkins31 Off-Topic 17 10-21-2010 11:00 AM
XP help: Laptop won't boot Reciprocity Off-Topic 14 02-16-2010 11:14 AM
Laptop won't boot up. Help. JEEENKINNNS Off-Topic 12 11-24-2009 10:28 AM
Laptop won't boot! (even in safe mode) imprezive Off-Topic 45 06-10-2009 06:36 PM
Computer help: cant access eBay with certain computer Mr. Fancypants Off-Topic 4 12-04-2004 01:15 AM
