Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Vancouver Impreza Club
Old 04-13-2012, 02:40 PM   #26
Member#: 210441
2002 Tarmac SpecC RA
Humbrol brand model paint, color #54 is an exact perfect match to the Brembo gold/brass color with the same metallic spec and all!
It's a bit tough to find since it's from Europe, but I found a model shop online from the U.S. that had it in stock and got a tiny tin of it for under $10 shipped. Awesome way to make a $1500+ set of used brakes look brand new.
rideAC1 is offline   Reply With Quote
Old 04-13-2012, 11:48 PM   #27
Member#: 313558
2011 STi Sedan
This gives me an idea for my "STi branded" brembos....
DIGGYGV8 is offline   Reply With Quote
Old 05-23-2012, 11:14 PM   #28
Member#: 138786
05 obp wrs ^.-
rally time
I will be buying this Humbrol #54 and post pics of the results once I touch up my Brembos
subiewhore is offline   Reply With Quote
Old 10-07-2012, 07:20 PM   #29
Member#: 269076
2012 Wrx
Anymore updates on this?? Just bought a complete 6 speed swap and the brembos are HIT. FastWrx Sells a subaru/brembo gold touch up but couldnt find any results on it.
HonduhPowa is offline   Reply With Quote
Old 10-09-2012, 03:56 PM   #30
Member#: 129503
2002 It's resting
6 > 4?
model paint? really? for ****s sakes.
the VHT high temp gold is pretty close.....take the calipers off, sand them down, prime them, and spray them with proper paint.
some people bitch the color's not perfect with the VHT...if you're fussy find a decent paint store and get them to mix some proper high-temp paint....
Personally I'd just paint them black and get on with my life.....gold brakes are played out, saw them on a neon the other day....
Jeff54 is offline   Reply With Quote
Old 10-24-2013, 12:45 PM   #31
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
actually no need to have hi-temp final color with proper prep.. The shop(s) I work for all use the same process and have done so for years with awesome results.
1. Strip the caliper to bare metal, wash, metal prep, de grease etc.
2. No prime needed take a similar light color, for Gold, Yellow Duplicor caliper paint is a great base. If you are color matching, choose a color close. Blue for Blue-blacks. black for Black or Grey, red for any red or orange etc.
2b. Paint caliper in 3 coats. First is barely a mist coat let totally dry, then #2 is a medium coverage coat. Let it dry until you can leave a small finger print or nail mark, then a final #3 moderate/heavy coat for final coverage and gloss & depth.
3. Let dry at least over-night before handling. a couple days would be ideal.
4. Now take and use a white or grey scotch-brite to open the hi-temp paint up. Spray 2 coats of your final color. 1 coat light to bite the hi-temp base, the 2nd to cover and gloss.
5. Let them dry overnight, longer the better.
TXwrxWagon is offline   Reply With Quote
SoCal: Brembo touchup paint Thran Suspension/Brakes/Handling 2 01-15-2008 03:10 AM
Where do you get the Brembo Gold touchup paint? edmundu Brakes, Steering & Suspension 5 08-04-2005 04:13 PM
STi brembo gold touch up paint gills Brakes, Steering & Suspension 21 04-02-2004 07:55 AM
shade of the touchup paint vs. factory paint pj_cab Interior & Exterior Modification 0 03-17-2003 11:18 AM
A touchup paint or spray paint? whtstr Interior & Exterior Modification 3 06-27-2001 09:42 PM
