#1 |
Member#: 300855
MWSOC
Vehicle:2005 Subaru WRX STi Aspen White |
Hey guys checked my oil today, it seems darker than normal, maybe I'm imagining things. I changed it 3000 miles ago, always use Rotella T6 & Mobil 1 filters every 6k. Car has 41,xxx on it. Any thoughts?
Mike
#2 |
Member#: 300855
MWSOC
And I drive it conservatively, stretching her legs every now and again, let it warm up and cool down before and after boosting.
#3 |
Member#: 318521
NWIC
Vehicle:08 WRX sedan WRB |
Every 6 thousand seems like a long time to wait. I hope you check your oil regularly.
#4 |
Member#: 318521
NWIC
Send it in for an analysis and you will get the best answer on how your oil is doing.
#5 |
Member#: 300855
MWSOC
I check it regularly, I've read quite a bit that 5-6k on full synthetic is fine, where can I send it in?
#6 |
Member#: 318521
NWIC
Try this.. Www.Blackstone-labs.com
#7 |
Member#: 300855
MWSOC
thanks dude
#8 |
Member#: 318521
NWIC
Youre welcome
#9 |
Vehicle:OK Houston we have an Uncle |
WIVES TALE ALERT....WIVES TALE ALERT
color of oil is in no way an indicator of its condition...'DARK OIL' MEANS NOTHING!!!!! unless it is well and truely burnt, and then ya got real issues ![]() WIVES TALE ALERT....WIVES TALE ALERT in fact, it may be doing a GREAT job of getting rid of all the garbage left by the PREVIOUS oil used and there are many here who go 8k miles on the t6 with great UOA results |
#10 |
n00b Moderator
Moderator Member#: 140114
MAIC
Vehicle:06 18G Semi Built SGM WRX |
My tires are a slight shade of black LIGHTER then normal, does this mean I need to change them again?
#11 |
Member#: 45076
Tri-State
Vehicle:2004 Stg2 Wagon 4eat Silver |
As said above you should do analysis and confirm your OCI is OK for your driving. Then check your oil level regularly when you have those long intervals.
#12 | |
Member#: 143624
NESIC
Vehicle:'08 STI SSM |
What sour puss said |
#13 |
Big Ron
Moderator Member#: 18062
MAIC
1. Wrong forum.
2. You did not read the sticky threads here or in the right forum. |
