Old 10-07-2012, 11:00 PM   #1
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Cobb Stage 2 Protune
2011 wrx with Cobb custom dyno stage 2 pro tune at Surgeline. Process West tmic and Cobb catted dp are only mods. This is the 17.5 psi map which has been on car for two weeks or so. Car feels and sounds great. These are 3rd gear pulls on the freeway. Any cause for concern?
https://docs.google.com/open?id=0Byn...2FDanlCR0NoclU
EricInHoodRiver is offline   Reply With Quote
Old 10-07-2012, 11:07 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
both files 404
Old 10-07-2012, 11:12 PM   #3
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Can't get my darn google docs to work...
3 pull 2500-6400 rpm in 3rd
A/F learning is all 0's thru entire pull. DAM all 1's. Feedback knock all 0's. Fine knock learning starts at 0 for several cells, then has 4 cells at -1.05 at 16-18 psi and 3500 to 4100 rpm, then back to 0's until -1.4 for two cells at 6400 rpm and 13.5 psi at very end of pull
Can't figure out what's up with google docs. Put "shared with link" to my files
Old 10-07-2012, 11:20 PM   #4
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Can't get google docs to play nice
Old 10-08-2012, 09:09 AM   #5
Cobb Tuning
Member#: 4803
You can post up the original .csv file over at the cobbforums ("Go Advanced" -> "Manage Attachments").
Bill
Old 10-08-2012, 09:52 AM   #6
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Thanks Bill. Just now attached csv files at Cobb and reposted: Subaru--Subaru Engine Performance--A Little Fine Knock LEarning in Logs--CSV files posted
Obliged if you can take a look
Eric
Old 10-09-2012, 11:41 PM   #7
mikeydrives1
Member#: 262117
From my understanding and continued learning in the tuning field, knock can be generated from a number of things, but the ECU has settings where it combats the knock by pulling timing for small ranges until the knock goes down. Based on atmospheric and fuel conditions, sometimes there will be a little knock ( at least from my experience) from time to time... the ecu manages it though.
The good thing about that logis that the DAM is at 1 and there is no feedback knock, which indicates a healthy operation. It seems to make the neccesary adjustments when the fine knock is triggered, which goes back to 0 when it does.
Maybe someone will see it differently than i do... im just a learner at this point in time. Do some more logging and see if its consistent or varies. This will help give us some better insight.
mikeydrives1 is offline   Reply With Quote
Old 10-10-2012, 11:00 PM   #8
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
I reflashed to my 16 psi protune map three days ago, filled tank yesterday and did three more pulls today. A/F1 is back to all zeros through all pulls, DAM remains at 1, Feedback knock remains at 0. But, on all three logs I have four cells of -2.5 for Fine Knock Learning from 5800 to 6300 rpm. Note that prior to today's logs I never went over 4500 rpm on the recent map reflash, so I can't see how anything could have been learned in that rpm range by the ECU?
Eric
Old 10-11-2012, 09:04 AM   #9
Cobb Tuning
Member#: 4803
Eric
Depends on what the ranges are set to in the tune. There are load and RPM ranges, so you can pass into the RPM range (but not the load range) where the correction is stored and then hit the load range and it pops up, making it appear that it is applied at a higher RPM only, for example, when it was actually learned at a lower RPM and applied across a broader RPM than you think (with corresponding load range).
Bill
Old 10-11-2012, 10:10 AM   #10
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Posted my three 16 psi logs over at Cobb on my thread. I understand what you are saying. Mind taking a look?
Thanks,
Eric
Old 10-12-2012, 08:34 AM   #11
Cobb Tuning
Member#: 4803
Thanks,
Eric
I would go ahead and add the knock sums to the log. Don't worry about the knock sum values themselves (will be higher in cylinder 4 than others - this is normal), but look at when any one of them increments at WOT. That would be a current perceived knock event. I can't make a determination of whether the knock in your logs is current without knowing how the load/RPM ranges for fine knock learning table are set up in the tune. Remember that the decrement is 1.4 deg. for fine knock learning and the increment is 0.35, so when you see a value like -2.45, that is not a current learned event, but a previous -2.8 event that has started to learn back to zero. Regardless, add the knock sum - that will make it easier to determine current knock.
Bill
Old 10-12-2012, 09:30 AM   #12
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Okay. just added Knock Sum Cyl 1 through 4 to default log list. I'll try and get log in soon and send it to the Cobb Forum--I have given up on google docs for now as something is completely fuhbahed since updating to their latest version on my Mac--so files will be directly from the accessport.
Thanks much
I assume I don't need "Knock Active Sw"
Eric
Old 10-12-2012, 09:32 AM   #13
Cobb Tuning
Member#: 4803
Thanks much
Eric
No, the "Knock Active Sw" does not have enough resolution to really be useful (switches too fast to always be picked up by logging).
Bill
