Old 09-20-2012, 11:18 PM   #1551
gtasti
Member#: 152036
2004 Sti
Originally Posted by bue car View Post
because you don't have sti rear brakes
What do you mean, the springs sit like oem springs on the perches.
The rears are more cups then perches so the plates sit right in them
gtasti is offline   Reply With Quote
Old 09-20-2012, 11:38 PM   #1552
68Cadillac
Member#: 95901
Sorting through the shed I found an old sin I never weighed properly:
Green Brackets of Death and hardware weight from a 2004 WRX. Whopping 2.130 kg*.
*Yes, I tared out the old sign on which the GBoD sit.
Old 09-22-2012, 11:39 PM   #1553
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Final weight - 6 lbs
shaved 16.5 pounds off
bue car is offline   Reply With Quote
Old 09-23-2012, 02:19 PM   #1554
68Cadillac
Member#: 95901
Nice bue. What is the diameter and wall thickness of the main tube? Mild Steel? DoM?
Old 09-23-2012, 02:48 PM   #1555
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
sheeiittt.... ill have to ask.
Old 09-26-2012, 06:22 PM   #1556
68Cadillac
Member#: 95901
Installed Turn In Concepts Giuyngmyo Fender Cowl Braces.
Giuyngmyo: 758 grams.
OEM: 571 grams. Installing these on a wagon was a bitch. Resorted to taking off both fenders so I could get my big fat hands in there.
Gained 187 grams , but my front's stiff.
Old 09-26-2012, 06:54 PM   #1557
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
i would hate to weight braces. probably 1.5 pounds each LOL
...i should just for ****s n giggles.
Old 09-26-2012, 08:01 PM   #1558
68Cadillac
Member#: 95901
Damn Bue. Those look beefy. 1.5 lb? I'd say 1.5 kilos.
Old 09-26-2012, 08:46 PM   #1559
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I have the TIC fender braces too, if you consider the amount of mud and crap I dug out from behind the lower rear fender liner whilst installing them I'd say they didn't add any weight
JDwhiteWRX is offline   Reply With Quote
Old 10-03-2012, 09:20 PM   #1560
68Cadillac
Member#: 95901
I'm preparing for a local HPDE and wanted to remove a bit more. I plan on taking out the rear seats and the passenger seat for the event.
Rear WRX Wagon 60/40 fold down seats w/o headrests 18.42 kg. Removed for HPDE only, you haters.
Also plan to leave all of the cargo area padding and cover behind. 4.08 kg. I'll put all this back in after HPDE.
The reason I had the seats out was to get at rest of the child safety seat anchors from the Right Rear. 451 grams Removed.
Old 10-03-2012, 11:04 PM   #1561
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
you should have saved all your scrap metal, and smelted it into a mini subaru version of your wagon LOL
Old 10-05-2012, 01:59 PM   #1562
68Cadillac
Member#: 95901
you should have saved all your scrap metal...
You're not far off. I have about 85% of the metal I cut off stored in my shed, labeled, and bagged. I think I've a sickness.
On topic:
OEM WRX Momo Steering Wheel with SRS and cruise control stick: 2938 grams. The extra 22 grams came from other parts.
Bell Works Short Hub 116 for GD Subarus: 285 grams
OMP Corsica Steering Wheel, Smooth Leather, 350mm (OD/1956/N): 1007 grams.
Removed 1.646 kg. The Bell Works Hub and OMP wheel has to be one of the easiest installs I've done in recent memory. I think I was done in 30 minutes. Probably took just as long to take the photos, write this post, add, and store the old parts. Also the OMP wheel is one high quality unit. The leather is perfect and stretched just right around the whole wheel. The stitching and glue: impeccable. I'm also glad I went with the 350mm large diameter and smooth leather. Honestly I wish they made a 375mm or 400mm wheel. The 350mm feels small compared to the OEM.
Old 10-05-2012, 02:03 PM   #1563
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
dude turn that into a mini car LOL
Make a mold from a model car, fill with metal!
Old 10-05-2012, 02:35 PM   #1564
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
VF30 Stage 8 billion
Originally Posted by RRR View Post
What a thread.. Inspired, Ive read the whole thing now (took 1 month, gave me 2 pages of work to do ).
Anyways, there is so much fuzz on these bumper beams, and for the record these appear to be USDM only. European cars dont have them as far as I can tell, checked 2 now (GD).
Anyone with the windscreen washer fluid in the trunk? How do you route it? I suppose the intercooler spray line would work, but I dont have that....
Im quite worried about wheight distribution. These things are 60/40 stock, and 3/4 of the wheight removed in this thread appear to go from the rear... Good excuse for keeping that big rear wing though. Ill also go for the battery in the trunk, I feel those extra oz of wire is worth the slightly better distribution.
Trying to take more off the front and as high up is a good plan . A lot of people here have made those comments. Sport Compact Car did a test with a stock 350Z where they removed 600LBS and then retested it maybe someone can find the link ? They windshield washer along with the battery and your other resevoirs for fluid might be able to be relocated to the trunk i would be careful of air in powersteering and radiator resevoirs.
doing that is more like reorginizing the weight. Some might say that the battery should be inside the passenger area on the floor , but i the having it on the trunk would have a greater effect on the front to rear weight ratio which will also help handling.
DamnThatRevLimiter is offline   Reply With Quote
Old 10-05-2012, 02:45 PM   #1565
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Just a few notes from my past experience: These cars are really not heavy. When your car weighs about 3800 without you in it... thats heavy. I just got out of an 06 GTO and stepped back into a subaru and this car is waaaaay more light and agile. My car was a mild bolt on car that did 380/385 and that thing hauled ass even weighing over 400lbs with me in it! I see a lot of people are pulling their interior, taking off door pieces, changing the steering wheel and for what? 30lbs? It doesnt make that much of a difference and for the way the car is slowly getting destroyed, its not really worth it.
You can do a few things to these cars that are key and can save a good amount of weight off the drivetrain - carbon fiber driveshaft, light flywheel, pulley, rotors, and wheels/tires. These should be the main focus.
All4bSpinnin is offline   Reply With Quote
Old 10-07-2012, 10:43 AM   #1566
gtasti
Member#: 152036
2004 Sti
Subarus don't like lighter fly wheels nor pulleys
And most of the stuff caddy took of his car is nothing you even see
If you think saving a few hundred lbs does nothing ur crazy
Old 10-08-2012, 02:35 AM   #1567
0BlueSTi4
Member#: 98955
2011 WRX Hatch
And if you think that it does you are also crazy - or at the very least obsessed. Once your fat friend gets in your car it negates all the work you put into it. So is it really worth it?
Let's face it...you can strip all the creature comforts from your car and get your perfect balance and all that...and in the end a stock GTR will spank you with minimal effort.
0BlueSTi4 is offline   Reply With Quote
Old 10-08-2012, 02:56 AM   #1568
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
you mean all the years i have put into reducing the weight of my cars is negated by my close friends?
Old 10-08-2012, 03:05 AM   #1569
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
pffft.... it's win win if you don't have friends and your girlfriend is tiny.
PleiadesSTi is offline   Reply With Quote
Old 10-08-2012, 07:13 AM   #1570
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'm sure if you spent the $100,000 difference in the cost of the cars you could spank the gtr
then again you don't drive around tracks with your fat friends in the car do you?
and saying that people who think saving hundreds of pounds does a lot are crazy?
you=clueless
Old 10-08-2012, 07:30 AM   #1571
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Very short sighted. Typical. Trolls strolling on through.
Old 10-08-2012, 02:22 PM   #1572
gtasti
Member#: 152036
2004 Sti
Exactly what was said below wasn't aware you race with a fat friend in the car
Also if I had 120 gs to throw away I'd put it in the suby and spank all a$$
And yes in Canada the gtr is 120 gs
Old 10-08-2012, 02:38 PM   #1573
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
http://www.motortrend.com/roadtests/...91&188,shopper
So the GT becomes a GT-R. The world's fastest sub-$100,000 car; $75,000 to $80,000 is the likely price range
3.8L/480-hp/434-lb-ft twin turbo DOHC 24-valve V-6
Curb weight 3836 lb (mfr)
power to weight=7.999999etc.
PERFORMANCE (C/D EST):
Zero to 60 mph: 3.5 sec
Standing -mile: 11.7 sec
http://www.google.com/url?q=http://w...5XZmZhfkLdOO2Q
http://www.google.com/url?q=http://w...AEmjCAQoW7Pctg
http://www.modified.com/features/061...x/viewall.html
You can also youtube time attack of Opera's cars against other tuners , to note that shop doesn't increase power just decrease weight.
You can also do your own math on how to get a subaru to match the GT-R's perfomance and power to weight ratio .
granted not everyone will do that or track there car but this thread is for pro-weight reduction if your anti-weight reduction please use facts and figures at least.
Old 10-08-2012, 09:50 PM   #1574
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
GTR is a heavy and expensive car compared to an Impreza, a guy in our club has one and has to replace a set of $1300 rotors after every track day. Sure its fast, like amazingly quick around the track, but you got to pay if you want to play.
Old 10-08-2012, 10:50 PM   #1575
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
he should have opted for the 50k carbon brakes and saved weight too!
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 01:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 12:02 PM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 11:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 01:53 AM
