Old 10-08-2012, 02:11 AM   #1
Freebs
Member#: 168740
2010 R8 V10
Default 2009 WRX Rear Diff Fluid - Amsoil 75W-90 Gear Lube?
I had used Amsoil 75W-90 Gear oil in my girl friends 2009 WRX Transmission and I still have a bunch left over. Is this fluid ok to use in her rear differential also? I searched a bit and I am 99.9% confident that it is ok to use but I just wanted to confirm before I go putting it in and causing an issue.
Here is the stuff I have.
Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG)
Formulated specifically for demanding manual transmission and transaxle applications
http://www.amsoil.com/storefront/mtg.aspx
Freebs is offline   Reply With Quote
Old 10-08-2012, 09:37 AM   #2
bluesubie
Member#: 767
04 FXT
This is not good for the rear diff nor the transmission as they both spec GL-5. Shifting my feel fine, in fact it may feel much better, but a GL-5 oil contains 30-50% more Extreme Pressure/Anti-wear additives than this GL-4.
-Dennis
Old 10-08-2012, 04:28 PM   #3
Freebs
Member#: 168740
2010 R8 V10
-Dennis
It says its approved by Subaru though? This car is hardly driven hard at all... When she consistently gets 550-600km to a tank of gas 100% inner city driving, that should give you am idea as to how hard this car gets driven
Old 10-08-2012, 05:55 PM   #4
aod12
Member#: 282701
2008 FXT
It says it meets GL4 specifications for Subaru.
But if your car calls for GL5 then it's not going to meet specifications for YOUR car.
Also, stop and go traffic found in inner city driving is going to cause a lot of wear since you're shifting constantly.
aod12 is offline   Reply With Quote
Old 10-08-2012, 06:50 PM   #5
Freebs
Member#: 168740
2010 R8 V10
So than if I bought This stuff, I could put it in the transmission and rear diff?
Old 10-08-2012, 06:53 PM   #6
bluesubie
Member#: 767
04 FXT
Yes.
-Dennis
Old 10-08-2012, 09:02 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I need a drink Dennis....
