Old 07-26-2012, 12:24 AM   #51
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
It is coming together nicely. Once the Tigwerks build is finished I can fit the engine and build the mounts into the frame. Then its tube bending time. Stay tuned.
RSti_Spyder is offline   Reply With Quote
Old 08-14-2012, 05:58 PM   #52
motoryder
Member#: 111268
.... MLTMFA2
How is this build coming along? I have a turbo vw powered manx and have been contemplating doing a swap for a few years now.
-Mike
motoryder is offline   Reply With Quote
Old 08-15-2012, 01:05 AM   #53
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
We should be showing the new header/turbo/intercooler/intake manifold in the next couple weeks. It will be very nice. But until it is done the rest of the car chassis is on hold until we can test fit the engine/transmission. The wait is at the painful stage now...
Old 08-15-2012, 01:23 AM   #54
motoryder
Member#: 111268
.... MLTMFA2
Nice, keep the pics coming! I may have missed it, but where are you mounting the radiator? I've seen front mounted setups with long coolant tubes and some mounted towards the rear on roll bar supports. I'd like to see which you chose.
-Mike
Old 08-15-2012, 08:51 PM   #55
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
I will be using a front mounted purpose built Griffin radiator to AN20 hoses to aluminum tubing running down the right side to AN20 hoses to water pump and water manifold. I am looking at either venting through side wheel wells and/or through hood like Porsche 996RSR. After I cut the hole for the center fill gas cap I probably will feel easier about cutting vents. It will depend also on what we have once Mendeola front suspension is welded on. Hoping that will be next week.
Old 08-16-2012, 12:16 PM   #56
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
MOAR Pls!
Gr3en is offline   Reply With Quote
Old 08-16-2012, 11:24 PM   #57
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Started pulling out the different systems and checking what is needed like hoses, bolts etc.
Did Steering and Brakes today.
Porsche 997 GT3RSR right hand drive TRW power steering flipped over for rear arm front spindles (Porsche are front arms), RSR Momo Steering wheel, RSR TRW electric power steering pump, Rennline Steering wheel quick release
Old 08-18-2012, 05:23 PM   #58
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
And the brake system.
Ordering the AN fittings and hoses is crazy expensive. Using all Startlite for cooling and oil hoses and wow what a bill so far.
Old 09-15-2012, 01:46 AM   #59
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Ciper you planted a seed. After we spent many hours on the phone talking with Bell about Air to Air intercoolers, I agreed with them to use a Water to Air intercooler. So dial a few more delays into the system, but I think it will be awesome. Kelly is working away on an ever changing system where he is shipping almost as many unused parts back as we are using. So as it stands now it is the great 935 style header to the Blouch 20G-xtr, direct into the water intercooler, direct into the Boomba throttle body on the heavily modified reversed STi manifold. Please let this happen soon as everything else now waits on the fitting of the engine and trans to build the chassis/cage. The thoughts are to have two side mounted intercooler coolant radiators like on the Ariel Atom 500.
Old 10-02-2012, 11:09 AM   #60
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Tigwerks sent me these shots of the turbo outlet to V Band flange. Blouch 20g-xtr is SwainTech White Lightning ceramic coated on the hot section.
Hopefully more pictures soon...
Old 10-06-2012, 12:47 PM   #61
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Building the exhaust side before the AWIC installation.
Old 10-06-2012, 09:52 PM   #62
TIGWERKS
Member#: 256615
TIGWERKS is offline   Reply With Quote
Old 10-08-2012, 03:06 AM   #63
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Tigwerks presents automotive jewelry...
Old 10-08-2012, 09:21 PM   #64
norexyet
Member#: 39149
11 elantra
yea i said elantra
Looks awesome dude. I like what Tigwerks does. Always nice pieces. I wished i welded stainless more often. Almost all my tig is aluminum, chrome-moly, and a little mild steel.
norexyet is offline   Reply With Quote
Old 10-08-2012, 11:53 PM   #65
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Kelly is very good with a Tig and he also understands the problems with making a one off system and the constant changes we go through. I always joke that the Mark 1 is OK but the Mark 2 or Mark 3 is much much better. We are up to Mk3 on most parts and haven't finished building one system yet. Learn as we go...
Old 10-09-2012, 10:49 PM   #66
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Tires mounted on TR Motorsport rims. TR is Tire Rack and last fall they closed these out for a set of four forged rims shipped for under $300. !!
Falken Azenis RT-615K tires, front 275/35R18 on a 10 inch rim and the rear 315/30R18 on a 12 inch rim.
A lot of good deals have helped me build this car. It's a Franken-Steeen (cue Gene Wilder) of bits and pieces...
Old 10-09-2012, 10:55 PM   #67
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Holy crap, that's a helluva deal - and nice looking wheels, too! Wish I had seen that deal.
Old 10-09-2012, 10:57 PM   #68
TIGWERKS
Member#: 256615
I think you need a bigger turbo for those tires
Old 10-10-2012, 03:19 PM   #69
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Patrick they sold the fronts, which are Porsche rears, for $49 each! And the rears for $79 each! As Damon at Tire Rack said we are selling what were $500 wheels for about the price of the aluminum. As far as I know he only posted the sale on Rennlist.
Kelly I think we are OK for now, but you see why I added electric power steering...
Old 10-13-2012, 10:06 PM   #70
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Welded manifold with Boomba Racing throttle body. Now on to the intercooler.
Old 10-14-2012, 01:18 PM   #71
TIGWERKS
Member#: 256615
sexay time!
Old 10-14-2012, 04:31 PM   #72
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Side shot of the manifold extension.
Old 10-15-2012, 01:39 PM   #73
Stangy
Member#: 329676
1999 GC8 R-STI
My god. Love it
Stangy is offline   Reply With Quote
Old 10-15-2012, 02:19 PM   #74
WRXChops
Member#: 207179
2015 WRX Limited
WRB 6MT
Lightbulb
I like your taste, Porsche and Subaru. Can't go wrong with that Son! GLWTB!
WRXChops is offline   Reply With Quote
Old 10-20-2012, 12:37 AM   #75
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Maybe this weekend can provide time for great progress...
WRXChops I could not think of a better marriage. When you look at the STi engine one gets the feeling Porsche Design has already been there!
sti motor build bbarnett83 Built Motor Discussion 1 10-12-2007 03:30 PM
sti motor build bbarnett83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-11-2007 10:59 AM
Wrx-Sti Impreza build swilcox01 Subaru Conversions 5 11-05-2006 08:48 PM
WRB STi - Office building near Woodfield, on Golf Rd. JM530 Mid West Subaru Owners Club Forum -- MWSOC 7 01-21-2006 06:00 PM
Meyers Manx with WRX engine... tee_rexx General Community 18 06-24-2005 09:25 PM
