Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 10-08-2012, 02:07 AM   #1
44rex
Member#: 238820
13 wrx hatchyyy
ISM
Default Wheel fitment
I wanted to go a little wider with my back wheels. Can I fit 18 x 10 73mm offset on my 06 wrx. Or should I just stick with 17x9.5 68mm offset.
44rex is offline   Reply With Quote
Old 10-08-2012, 02:11 AM   #2
sc00by4life
Member#: 97135
oh god.
NEITHER of those will work. WAY too high.
we have this thing called the "wheel and tire" forum that has 2 threads specifically relating to wheel/tire fitment as well as how to correctly measure and calculate offset.
simply put, with a question like that, its quite obvious you are pretty new to wheel fitment (which is fine), you don't need to be worrying about a wheel wider than 8".
Old 10-08-2012, 08:58 AM   #3
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
I'm no wheel expert by any means but 17x8 35 offset is probably about right without rubbing. Someone correct if I'm wrong
faSTI666 is offline   Reply With Quote
Old 10-08-2012, 09:08 AM   #4
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
That offset will look like this, and I am not kidding.
Old 10-08-2012, 09:09 AM   #5
brentorius
Member#: 263949
2007 Wrx Wagon
Those offsets seem very high - are those measurements the hub bore?
brentorius is offline   Reply With Quote
Old 10-08-2012, 09:10 AM   #6
Wirtz
Member#: 286408
WFC #952
Function:error!
Go look up my posts. I'm not showing you as I am lazy but I've run 17x9 +30 no a 225/45/17 and it fits fine when dumped with appropriate fender work. Those offsets you posted are too high and you won't be able to clear your suspension with that amount of backspacing
Wirtz is offline   Reply With Quote
Old 10-08-2012, 09:13 AM   #7
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
http://img.photobucket.com/albums/v489/xok/DSC03227.jpg
I think you've got that backwards. High offset will cause his tire to hit the strut. The photo you posted has a very low offset.
I agree that the OP is probably looking at hub bore instead of offset.
xluben is online now   Reply With Quote
Old 10-08-2012, 12:31 PM   #8
ABeastinWRX
Member#: 239469
2004 WRX
I know it's the newbie forum but
ABeastinWRX is offline   Reply With Quote
Old 10-08-2012, 12:34 PM   #9
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Yup....you're right. My pic is more like zero offset.
