Old 09-22-2012, 06:36 PM   #1
isabura
Member#: 118818
1995 bk legacy wagon
Default Car still pulls to the left
I got a flat on the front driver side, and had to drive on a donut for 2 weeks. Had to go to work so I ended up driving 100+ miles on it before I had time off to get it fixed. Mr. Tire fixed the tire came back to them a week later, which was yesterday, cause the car pulled left, lit. pulled to the left, to get an alignment. The car still goes left kind of like before the car got a flat.They said they resetted it to the factory specs. My car is a legacy 96 L wago with stock 03 wrx wheels. I'll rotate the tires when I get the new bloody lock nut key. The brakes hasn't been replaced for 4 or 3 years, original owner did them before I bought it from him 3 years ago. What should I do?
isabura is offline   Reply With Quote
Old 09-22-2012, 07:58 PM   #2
gunnshot
Member#: 330970
If it still pulls then the alignment needs to be done again. What is the condition of the remaining three tires? If they are pretty worn compaired to the one new one. Have them put it on the rear of the vehicle when they re-align it.
gunnshot is offline   Reply With Quote
Old 09-22-2012, 08:07 PM   #3
isabura
Member#: 118818
don't do much driving, they're prob 40%-60 left
Old 09-22-2012, 08:19 PM   #4
gunnshot
Member#: 330970
Yeah then the alignment should be redone and I still say more the new tire to the rear of the vehicle so you have equal wear on the front.
Old 09-23-2012, 12:51 PM   #5
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
Check for a seized caliper. That was causing heavy pull that an alignment didn't fix on a friend's car. Replaced the brakes, problem solved.
Rotating the tires is also a good idea.
Wiscon_Mark is offline   Reply With Quote
Old 10-08-2012, 01:40 AM   #6
CCSubaru
Member#: 203376
2013 WRX
I drove on a donut from Boston to Cape Cod one time and then for a few days after that and even after multiple alignments and rotations it always pulled slightly.. It was never the same
CCSubaru is offline   Reply With Quote
Old 10-08-2012, 01:35 PM   #7
jeisen
Member#: 27258
who dat be dat was?
Subaru allows no more than 2/32 difference in tread depth. You should have had the new tire shaved down to the proper depth (Tire Rack does this with new tires only), or replaced all 4. There is a good chance you are still screwing up your diffs.
jeisen is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 09:22 AM.
