Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 10-05-2012, 09:41 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
Default EQ - Borg Warner EFR 8374 Build, Prelim Tune - 500whp with a lot more to go!
This car has been in the works for quite some time now. We finally got it running and got some break-in miles on it, so I spent a couple hours with it on the dyno to start making some power. We ended up cracking 500whp with just 24psi but ran into fueling issues so kept it there while we re-wire the dual pumps. Either way, this car is FAST and spool feels amazing on the street. The block is built to hold over 30psi and 8000RPM, so we have a lot left to go
Event: Custom Tune/Dyno
Ambient Temp: 102 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2006 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 503whp @ 7050RPM
Peak Torque at RPM: 465ft-lbs @ 5150RPM
Target Boost: 24psi peak
Fuel: E85
Engine/Power Modifications:
EQ Stage 3 Shortblock (Darton Sleeves, CP Pistons, Manley I-Beam Rods)
EQ Stage 3 Heads (Supertech +1mm Valvetrain, Cosworth S2 Cams, Full P&P)
Borg Warner EFR 8374 T4 1.05a/r Twin Scroll Turbo
Full Race Twin Scroll Header, UP, DP
Dual Tial EWG's
Cosworth Intake Manifold
EQ Tuning FMIC
EQ Tuning Intake
EQ Tuning Catch Can
EQ Tuning Custom Coolant Reserviour
ID2000cc Injectors
Aeromotive Fuel Rails with EQ Line Kit
Aeromotive FPR
Dual Aeromotive 340lph pumps
Tuned with Cobb Speed Density
Invidia Q300 Catback (biggest restriction)
We still have a lot of room left in this thing, so look for updates over the next few weeks
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 215-220whp
Stock 08-11 STI - 190-200whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
350-360whp - 118-120mph traps
-- Ed
Old 10-06-2012, 12:53 AM   #2
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
jus curious as to why 04-07 sti's make more power than thd 08-11?
dumpstercrusher is offline   Reply With Quote
Old 10-06-2012, 12:57 AM   #3
cpturbo
Member#: 49175
2004 STI
It's about time someone has tuned an 8374! Thank you for posting. Power band looks very nice.
cpturbo is offline   Reply With Quote
Old 10-06-2012, 01:13 AM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
The stock tune is just worse. Once tuned they make about the same power if not more.
-- Ed
Old 10-06-2012, 01:14 AM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
The spool and drivability on the street is really amazing for a turbo this size. We barely got this thing spinning so far. Lot more to go
-- Ed
Old 10-07-2012, 08:57 PM   #6
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Q300 is very restrictive ? how about G200?
Bariga is online now   Reply With Quote
Old 10-07-2012, 09:49 PM   #7
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
Great job guys! I always enjoy seeing your post. However, I know the BW turbos tend to be on the large "body" size, but with only a 62.6 mm inducer this thing seems to be a lag monster. I thought that the EFR series was supposed to offer an advantage as far as spool.?
2006whitesti is online now   Reply With Quote
Old 10-07-2012, 11:22 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
The G200 would be better but the customer is going for a relatively stealthy appearance. We'll probably do a couple pulls with the axle back off the car once we have it turned up all the way.
BTW, remember we're running a .85 correction factor on our Dynocom dyno. This would be roughly 590whp on other Dynocom's.
-- Ed
Old 10-07-2012, 11:25 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
This is a large turbo capable of nearly 800bhp. I don't think it's laggy at all for the size. Also remember we're running cams and heavily ported heads which shift the powerband to the right. On the street the boost threshold is excellent and transient response is even more impressive. Once we're all set I'll do some street pulls to show real world spool.
- Ed
Old 10-08-2012, 01:14 AM   #10
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
what pressure do you get at 4k?
Old 10-08-2012, 02:02 AM   #11
Jdub.csu
Member#: 283784
2013 EVO X GSR
subscribed
Jdub.csu is offline   Reply With Quote
Old 10-08-2012, 07:05 AM   #12
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
All on Stock computer! Go Ed!
Old 10-08-2012, 05:48 PM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
Oh yea.. the stock ECU with SD does great with these power levels. We're still using the MAF for idle and out of boost drivability and switch to SD in boost.
-- Ed
Old 10-08-2012, 06:00 PM   #14
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
What size intake are you guys using?
Looks good, how far does the owner plan to push the turbo?
project_skyline is offline   Reply With Quote
Old 10-08-2012, 08:56 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
4" shorty intake
We're going to get it up to at least 30psi
-- Ed
Old 10-08-2012, 09:01 PM   #16
renosubby
Member#: 152576
2006 STI 10.8@ 129
www.Mayhemtuning.com
doing work Ed!
I'm happy to finally see one of these turbos put to the test!
Old 10-08-2012, 09:56 PM   #17
2006whitesti
Member#: 124311
- Ed
Look forward to seeing it.
Old 10-08-2012, 09:58 PM   #18
Jdub.csu
Member#: 283784
2013 EVO X GSR
4" shorty intake
-- Ed
Woot excited to finally see real world testing of these
Old 10-09-2012, 11:47 AM   #19
Subarusesh
Member#: 288160
2008 Impreza 2.5i
can't.wait.for.a.ride.
Subarusesh is offline   Reply With Quote
Old 10-10-2012, 11:29 PM   #20
Spike_916
Member#: 170007
2006 STi
Obsidian Black Pearl
Don't worry, you will get a ride. Ed did an amazing job on the performance of this car.
Spike_916 is online now   Reply With Quote
Old 10-19-2012, 06:05 PM   #21
Spike_916
Member#: 170007
2006 STi
Hopefully soon
Old 11-28-2012, 12:17 PM   #22
GA scooby
Member#: 229518
2011 STi
Any updates on this at all? Pictures of the engine bay?
GA scooby is offline   Reply With Quote
Old 11-29-2012, 03:36 AM   #23
Spike_916
Member#: 170007
2006 STi
Finished all the virtual gauges about two weeks ago and dropped it off at Ed's. Thanksgiving and his vacation, he hasn't had time. When he gets back he should be finishing it up.
Old 11-29-2012, 01:28 PM   #24
GA scooby
Member#: 229518
2011 STi
Awesome! Great build man. I look forward to your results. If you've driven it much. How is drivability?
Old 11-29-2012, 01:37 PM   #25
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Nice.
wrxsubiemod is offline   Reply With Quote
