Old 10-07-2012, 10:58 PM   #1
Onejamasubaru
Member#: 312346
Satin White Pearl Sedan
Default Stage 2 WRX 2012 burning oil normal?
Hey guys, I have tbe with torqued performance's stage 2 tune. Is it normal to burn oil with this tune or any tune I should say? Probably just blow by? Any fixes besides topping off? Thanks
Onejamasubaru is offline   Reply With Quote
Old 10-07-2012, 11:02 PM   #2
sc00by4life
Member#: 97135
all subarus burn oil. you should be checking it at every fill up.
try searching next time.
Old 10-08-2012, 03:23 AM   #3
_davin
Member#: 260501
2003 miata SE
Blurple
No that's not normal.
_davin is offline   Reply With Quote
Old 10-08-2012, 07:21 AM   #4
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Some oil burn is normal, depending on what type of oil (weight, specifically) you are using. While a little bit is not of concern, anything that seems excessive is. Dare I open this can of worms...what kind of oil are you using?
I'm running my 2011 with Rotella T-6 and I don't burn a drop. So, it may be as simple as your oil type. It may be a bigger issue. Give us more info.
Decipher is offline   Reply With Quote
Old 10-08-2012, 08:01 AM   #5
schweezly
Member#: 187013
2013 ST
Yep.
I'd also say it depends how much. The H - L range on your dipstick is only about 1 quart difference.
schweezly is offline   Reply With Quote
Old 10-08-2012, 09:53 PM   #6
neither one of my modded wrx's has burned oil
my 06 goes 7k-8k between changes and i dont and havent ever added oil between changes
somebody is doing something wrong
aint me
Old 10-08-2012, 10:07 PM   #7
sc00by4life
Member#: 97135
aint me
I've averaged a half quart to full quart between oil changes for the last couple of years.
Old 10-08-2012, 11:52 PM   #8
Onejamasubaru
Member#: 312346
Same exact oil sir. When I changed my oil, the level was by the upper circle. Now 3750 miles later its in the middle of H and L..
Old 10-09-2012, 12:24 AM   #9
BeefCurtains64
Member#: 251257
12 WRX
i run MOBIL 1 !!!!!! 0w-40 and i live in texas and its 110 !!!!! every day!!!! and i dont burn a drop !!!!
I got my 99 problems but oil buring isnt one of them. WOOP WOOP
2012 wrx w/ cobb AP, ran 40 viscosity since 2999.02 Didnt burn a drop. At 7578.56 today.
but then again, every car is different, just like everyone is different.
I ran a mobil 1 5w-30 on mistake, and that crap burns oil like bacon !!!! i went thru 12 quarts during my 2.5k miles .... never again.
BeefCurtains64 is offline   Reply With Quote
Old 10-09-2012, 12:51 AM   #10
mrkyle3
Member#: 272675
2004 Miata
I also do not burn anything.
Old 10-09-2012, 06:47 AM   #11
GrumpyPitbull
Member#: 313311
People always say that Subaru's burn oil, and it's normal for them to do this. Yet none of the three WRX's I've owned over the years have ever lost oil between changes. Two of those cars were stage 2+, so it's not a mod issue.
Oil does not magically disappear in an engine simply because it is a Subaru. It is lost either due to a leak, or getting into the combustion chamber somehow where it does not belong and is being burned.
Neither of these two possibilities are "normal" or healthy for any engine regardless of manufacturer.
OP, since your already running 40wt oil, we know that's not the issue. You're only losing about a half quart between changes, which is not alot and could be due to blow-by. You could try an AOS and see if that takes care of it.
Old 10-09-2012, 06:48 AM   #12
WRXLTD
Member#: 136314
2014 Grand Cherokee
At my first oil change at 3000 miles, I added Mobil 1 Extended Performance 5w30, and since day one I've never burned a drop of oil.
(knock on wood)
WRXLTD is offline   Reply With Quote
Old 10-09-2012, 07:17 AM   #13
424wrx
Member#: 171948
08 wrx vf52 swap
best et,[email protected]
ive never used a noticable amount of oil in almost 5 years of owning my wrx. never topped off between oil changes. i guess im lucky. op, ive been running tp maps for 2 years too.
Old 10-09-2012, 07:26 AM   #14
stop_rallytime
Member#: 225515
JUST blow by!.... oh boy I never burned oil unless my motor was ****
stop_rallytime is online now   Reply With Quote
Old 10-09-2012, 04:10 PM   #15
VinSVT
Member#: 77637
2011 WRX with 17k miles. Doesn't burn a drop. 100% stock.
VinSVT is offline   Reply With Quote
Old 10-09-2012, 04:17 PM   #16
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
It's not 110 every day in Texas. You have lost all credibility.
Old 10-09-2012, 05:48 PM   #17
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
A few more exclamation points and I would've believed him.
sizemic1 is offline   Reply With Quote
Old 10-09-2012, 07:04 PM   #18
bad72amx
Member#: 296363
2004 STI
For Sale
A tune cannot affect oil consumption unless it causes mechanical issues. That said, I don't think 1/2 quart would worry me in 4k miles. If your concerned, get on level ground, change your oil, idle for a few minutes, shut off and check, drive 4k miles, and check the exact same way again. That 1/8 inch difference between full and half on the dipstick could be as simple as difference in procedure.
bad72amx is offline   Reply With Quote
Old 10-09-2012, 07:25 PM   #19
oh YES tune CAN affect consumption....if ya usin the wrong oil and ya boosting a lot more and running the engine harder your tune sure as hell can cause consumption to increase without any other inherent mechanical issue
Old 10-09-2012, 08:15 PM   #20
some dude
Member#: 100300
06 WRX
135,000 on my car and I go 5k miles or more on the oil and I have yet to ever add any oil between changes. I check it often as well.
Old 10-09-2012, 11:35 PM   #21
bad72amx
Member#: 296363
2004 STI
For Sale
You would have to boost hard enough and often enough to blow oil past the PCV valve or the rings or the turbo seals. I do not see any of the above happening without serious issues otherwise. If you have that much boost, your going to have ring flutter or blown seals and drivability issues besides oil consumption that is slight, if it even exists. And he said hes using Rotella so wrong oil is not an issue, but regardless I do not see how tuning can cause oil consumption without major failure or drivability issues.
Old 10-10-2012, 12:48 AM   #22
44r0nm4n
Member#: 313693
2012 WRX 5-Door
(knock on wood)
i used mobil 1 5w-30 adv full syn (not the ext perf) @ 3,073mi for my 1st oil change... didnt have any signs of burnt oil... same oil weight using castrol edge titanium @ 6325mi for my 2nd... so far no burnt oil as well after checking 3 times on diff occasions... i suppose due to purely stock state or no tune...
44r0nm4n is offline   Reply With Quote
Old 10-10-2012, 11:21 AM   #23
scx89
Member#: 269388
2011 Impreza WRX
obp
alright OP
are you checking your oil in the same conditions?
scx89 is offline   Reply With Quote
Old 10-10-2012, 11:41 AM   #24
STi410
Member#: 158800
2010 STi
I have only ever run mobil 1 5w-30 in my subaru and change it every 3k miles and hardly lose a drop of oil
STi410 is offline   Reply With Quote
Old 10-10-2012, 12:50 PM   #25
masterforce
Member#: 221580
2011 WRX STI
Nothing wrong with that. Normal for me to to use half QT around 3-4k miles but by that time its oil change time.
masterforce is offline   Reply With Quote
