Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 09-23-2012, 02:02 PM   #426
gunnshot
Member#: 330970
Got the front of the fender welded solid. Also threw a coat of filler on it so I don't have to worry about surface rust.
gunnshot is offline   Reply With Quote
Old 09-28-2012, 10:54 AM   #427
gunnshot
Member#: 330970
Working on some ideas with how I want to finish out the shape of the fender. What do you think of this? It is just one of the ideas of how I am thinking of doing it.
Old 09-29-2012, 10:14 AM   #428
Dobes
Member#: 164
2008 Exige S240
Originally Posted by gunnshot View Post
It looks like you welded directly to a painted surface? I'm not a welding expert but it seems that wouldn't be the right way to do it.
Dobes is offline   Reply With Quote
Old 09-29-2012, 03:24 PM   #429
gunnshot
Member#: 330970
Nope, I just sanded a minimum amount of distance to limit surface area I would have to worry about priming before I am done. But is was all bare metal when welding.
Old 10-05-2012, 11:06 PM   #430
jdbaubli
Member#: 331947
1998 Legacy Outback
Red
Originally Posted by 98legwag
Installed LEDs from superbrightleds.com in the gauges, hvac controls and hazard button. Also added more reflective tape to the top of the gauge cluster to get more front lighting on the gauges.
I'm a newbie with a 98 legacy outback. Is that the original hvac control set. The only part that illuminates on mine is the ac button. Is that normal?
jdbaubli is offline   Reply With Quote
Old 10-06-2012, 11:17 AM   #431
98legwag
Member#: 160325
09 Legacy 3.0R
Yes it is. All your other bulbs are out. There are three more.
98legwag is offline   Reply With Quote
Old 10-06-2012, 08:34 PM   #432
SpecBlitzed
Member#: 331188
Installed Perrin EL header. Invidia devirced dp
SpecBlitzed is offline   Reply With Quote
Old 10-07-2012, 01:31 PM   #433
rougeben83
Member#: 115154
2005 Outback XT
White on grey
claybar and waxed the car yesterday...then it rained today.
rougeben83 is offline   Reply With Quote
Old 10-07-2012, 07:14 PM   #434
gunnshot
Member#: 330970
Been a pretty busy weekend and fighting with the scattered storms. I removed the rear exterior door handle and just had time to weld in the plate when it started to rain so it looks like crap. I did not have a chance to grind down the welds; I barely had time to hit it with primer.
I also spent some time working on different ideas for how to bring it back into the door. Here is the first and I really did not like it.
Here is the second. I liked it a lot more then the first but just did not feel like it worked with the rears looks enough.
Here is the last one I got done today and I am leaning in its direction. Very agressive like a porsches rear fenders. Not 100% yet. I made the metal template for this design and if the rain had not come it would be on it right now
Old 10-07-2012, 10:57 PM   #435
rougeben83
Member#: 115154
2005 Outback XT
White on grey
I like 1 and 3 myself...
Old 10-08-2012, 07:42 AM   #436
93GC8AWD
Member#: 245268
1993 Impreza L Wagon
I pulled out the ej22t yo get rest for a fresh rebuild.
93GC8AWD is offline   Reply With Quote
Old 10-08-2012, 11:20 AM   #437
ryz252003
Member#: 332086
installed my aem uego wideband now i feel safe driving
ryz252003 is offline   Reply With Quote
Old 10-08-2012, 03:42 PM   #438
FundamentalyConfused
Member#: 313722
1999 Forester S
Red/Tan
I took out the HVAC controls to replace them.
FundamentalyConfused is offline   Reply With Quote
Old 10-08-2012, 10:03 PM   #439
jdbaubli
Member#: 331947
1998 Legacy Outback
Red
So I replaced the whole hvac unit. Went to the junkyard pulled the unit from a 96 legacy wagon along with a fog light button and hazard light button which also do not light up and after replacing them the lights still do not turn on. Interestingly the lights beneath the buttons work along with ac button. Could this be a wiring issue and if so how would I check that.
Old 10-09-2012, 12:16 PM   #440
Member#: 313722
1999 Forester S
Red/Tan
I cursed at my cruise control until it started working!!
Bloody thing, I hate my manic depressed cruise unit!!
Old 10-09-2012, 03:44 PM   #441
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
... discovered I have a bad fuel injector on cylinder three and the annoyances of getting my buddy to get his dealership pricing on the replacement =) ...
Kcwiro is offline   Reply With Quote
Old 10-09-2012, 03:57 PM   #442
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Originally Posted by 98legwag View Post
Its 4 of these:
http://www.superbrightleds.com/morei...edge-base/199/
and 2 of these:
http://www.superbrightleds.com/morei...edge-base/228/
That covers the gauge cluster.
Three of these for the HVAC (also used in the hazard and other buttons):
http://www.superbrightleds.com/morei...panel-led/221/
3 / 4 or 5mm on the HVAC?
Old 10-09-2012, 06:14 PM   #443
98legwag
Member#: 160325
09 Legacy 3.0R
3mm for the HVAC.
Old 10-09-2012, 06:24 PM   #444
98legwag
Member#: 160325
09 Legacy 3.0R
Its probably going to be the bulbs. They go out on most older Legacys. Here is how to change them:http://legacygt.com/forums/showthrea...8.html?t=26408
For the hazard and fog switch they use little twist lock bulbs. I put a LED in my hazard switch. I got it from superbrightleds.com. Its a NEO-3.
Old 10-09-2012, 07:13 PM   #445
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
today i worked on the legacy GT a bit and had some hood-up time.
my 2005 5MT wagon is at 98k miles and needs a major svc that ive pushed to a later date. so today the power steering was making noise and had weird feel through the wheel. topped up the PS fluid reservoir.
car is burning oil like crazy. about 1qt per 1000 miles at this point. admittedly, i drive hard. after getting synthetic this summer about 4th of july, car was nearly bone dry when checked two wks ago. engine was running hot but i did not see it bc my garmin blocks temp gauge. [oops]
radiator also needed fluids badly. my key point: service your subie. im always amazed at how much better it drives after a service. i am cashpoor ATM. at the moment
lastly, and what i had pics of: New DIY honeycomb grille, painted and nearly installed. debating what badge to use. thoughts about this old one i recovered VS the traditional blue stars...?
subaru legacy gt - DIY honeycomb grille by tommyburkart, on Flickr
or
IMG_0445 by tommyburkart, on Flickr
burkart is offline   Reply With Quote
Old 10-10-2012, 06:12 PM   #446
gunnshot
Member#: 330970
Had a little time today before the rain. So I cut and bent the piece I wanted for the door. Got it welded in place just before it started to sprinkle so I quickly did as much grinding as possible and primed it. So excuse the images, it is not finished at all. Did not have time to make to top piece or the bottom piece. Also it is not trimmed for the door and not cut level across the bottom.
Old 10-12-2012, 01:37 PM   #447
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Sunday - Won SM at the local auto-x and set the 2nd fastest raw time. Coulda/woulda/shoulda caught the faster time, but the 2nd heat (which I was in) only got a single dry run in before it started raining.
Tuesday - Rolled 220,000 miles.
As 98legwag said, it's almost certainly the bulbs. It is very common for them to go out, and buying a 16-year-old junkyard HVAC probably was not a step in the right direction.
Old 10-13-2012, 06:21 PM   #448
jdbaubli
Member#: 331947
1998 Legacy Outback
Red
thanks to legwag98 finally got my hvac lights working. Feel like a kid on christmas
Old 10-13-2012, 08:20 PM   #449
gunnshot
Member#: 330970
Got home from work this afternoon and had a little time to make and weld in the piece for the top of the door. Had to run back to work and by the time I got home I only have time to grind the welds and put a coat of primer on it.
Old 10-14-2012, 04:25 PM   #450
gunnshot
Member#: 330970
Got a little time today to work on the car once the sun came out. Cut out the front fender and then tacked in the rear and front piece. I will close up the top over this week.
So what mods have you done to your baja? 2003Baja Baja Forum 22 07-16-2004 03:31 PM
What mods have you done to your WRX? Diesel7 Canada Region Forum 3 11-02-2002 12:16 AM
What have you done to your RS lately? CosmoTheCat North West Impreza Club Forum -- NWIC 8 03-27-2001 10:55 PM
What have you done to your impreza? Hades69 General Forum Archive 2 02-17-2001 07:39 PM
