Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 09-28-2012, 11:53 AM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW > Engine Mount Kit by PERRIN
NEW > PERRIN Performance Engine Mount Kit
PERRIN Performance engine mount kits reduce drivetrain movement under hard acceleration, deceleration and corning.
Allowing the most efficient transmission of all available power to the ground. This means easier transitions from on
and off throttle power in daily driving, more accurate launches during drag racing and auto cross type events where
you do not want drivetrain slop. PERRIN engine mount kits also improve reliability, as they can not tear apart like
OEM mounts leading to other drivetrain related failures.
In stock now > MSRP $349.99
PATENTED INTERLOCK SYSTEM & POLYURETHANE DESIGN
The PERRIN Performance engine mount kit featuring Energy Suspension mounts with a patented Interlock design.
Unlike OEM and Group N mounts, the unique shape of Energy Suspension's steel internals keep the mount from physically tearing apart.
Small oil leaks, or highly corrosive atmospheric conditions combined with extreme temperature changes will make OEM
and Group N rubber mounts brittle and lead to failure. The PERRIN Performance engine mount kit with Energy Suspension mounts
features 75A durometer polyurethane that is impervious to oils and other chemicals, easily outlasting the OEM mounts.
HD MOUNTING
The PERRIN engine mount kit includes upper engine mounts and lower mounting brackets with heat shields. Most replacement mounts reuse the
heavy OEM steel bracket, but PERRIN mounts are CNC'ed 6061-T6 aluminum brackets, making a stronger mounting surface for the stiff urethane mounts.
The PERRIN engine mount kit is ideal for those with OEM plastic type mounts as you will not need to buy additional parts to replace faulty or cracked plastic brackets.
ADDED DRIVER FEEL
PERRIN engine mount kits are stiffer than stock, which adds some NVH (noise, vibration, harshness). The polyurethane compound provides enough
vibration absorption for daily driving, yet strong enough to enhance driver perception with the added feeling of your engine solidly connected to the chassis,
versus having that sloppy disconnected feel.
EASIER TO REMOVE ENGINE
OEM and aftermarket mounts use a stud and nut to secure the engine to the chassis. Making removing and installing the engine into the car somewhat tricky.
The PERRIN Mounts use a bolt in place of the stud which means you do not have to lift the engine up past the studs, or get the mounts perfectly aligned
to the transmission and subframe when installing the engine. This small detail was done specifically for the customer who is constantly pulling the engine out
to add new part, rebuild, change clutch or any other big engine upgrade. Another PERRIN advantage!
Here is a picture of a Groupe N Mount that tore apart in a street/auto-X prepped car...
Dont let this happen to you.
Click HERE to check it out on our web site.
PERRIN is offline   Reply With Quote
Old 10-08-2012, 07:24 PM   #2
Jdub.csu
Member Sales Rating: (5)
Member#: 283784
2013 EVO X GSR
I actually just ordered these I'm tired of the jerkiness of the stock drivetrain and want something between cusco mounts and group N. these fit the bill nicely. I wish you guys made something like this for the tranny mount though for the WRX. I have the group N and want something a little more rigid.
Old 10-08-2012, 10:48 PM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
Originally Posted by Jdub.csu View Post
I actually just ordered these I'm tired on the jerkiness of the stock drivetrain. I wish you guys made something like this for the tranny mount though for the WRX. I have the group N and want something a little more rigid.
Awesome, expect to see somethng for the tranny very soon.
Old 10-08-2012, 10:56 PM   #4
Jdub.csu
Member#: 283784
2013 EVO X GSR
Like <3 months soon =D
Also installing your FMIC, pitch stop, endlinks, sway bars too. Thanks guys
Old 10-08-2012, 11:29 PM   #5
PERRIN
NASIOC Manufacturer
Member#: 6776
< 3 weeks
Old 10-09-2012, 12:20 AM   #6
Jdub.csu
Member#: 283784
2013 EVO X GSR
< 3 weeks
Can't wait!
Old 11-20-2012, 05:32 PM   #7
axelthrasher
Member Sales Rating: (107)
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
You guys should do a group buy for the trans/motor mounts as that is a lump of cash to spend if you want both...
axelthrasher is offline   Reply With Quote
