#51 |
Member#: 45323
South East
Vehicle:MY05 Impreza WRX STi Pastelito Racing & SFSOC |
yeah, a metal frame that the splitter is attached to. You want more than a few bolts holding the spiltter together.
#52 |
Member#: 318788
South East
Vehicle:2005 WRX WRB |
My question is, how did you get the STI front bumper splitters to fit on your wagon bumper? Write up or explanation please???
#53 |
Member#: 197764
NESIC
Vehicle:02 WRX Stage DD PRND 01G |
Instead of asking this question in a thread from over one year ago that obviously isn't being checked in on, PM the person you're addressing.
#54 | |
Member#: 95901
SWIC
Vehicle:2004 WRX Wagon White |
--- Had to scrap that High Density Poly Etheline (HDPE) only splitter. It just wouldn't hold up at 6mm thickness. I spent all that time and when tested, it wouldn't support even 10 kg before bending to the ground. Also tended to sag when heated up near the manifolds. Lessons learned. For an upcoming HPDE I decided to revive my dream to make and fit a proper front wind splitter. Sourced a sheet of 10mm Alumalite. Actually Econolite because I only needed one side with paint the underside could be raw aluminum. Saved a bit of coin by buying a damaged sheet. One corner was mangled, but well away from the area I needed. This stuff is stiff and surprisingly lightweight for how stiff it is. ![]() Based the shape on my old HDPE splitter and a second splitter. There's the final shape after cutting against the wall. ![]() Finalizing the placement of one of the seven mounting points. The bar stock for the mount is 6 mm thick. 38 mm wide. ![]() 3/32" 133-strand (7 x 19) Galvanized Steel Wire Rope for the three front mounting points. Breaking strength: 450 kg per wire. So together the three wires could lift up my car before they reached their breaking strength rating. I'm sure it'd just rip out the front bumper beam if it ever got near 1350 kg. But the wire wouldn't fail. Why wire? To allow a bit of upward flex in case of a nose scrape while on (off?) track. ![]() Air dam to help the splitter build up high pressure right on top of it. Leading edge of the splitter sticks out 110mm from the bumper. I varied that 110 a bit for ascetics in certain areas. ![]() Goes back 1.2 meters from the leading edge. Took a video to see if the wires needed to be tightened up but at 60 mph or so they straightened right out as the pressure differential increased. ![]() Those are my foot prints. Did the "can you stand on it?" test. Hope it can it handle the pressure generated at HPDE speed. Last edited by 68Cadillac; 10-09-2012 at 12:11 PM. |
#55 |
Member#: 95901
SWIC
Still needs a bit more work.
![]() But here's how it looks, this evening ![]() Further back. Driving impressions: < 55mph or so the engine just sounds different. No butt dyno noticeable effects. 55 - 65 mph. Felt like the cars was gettin sucked down to the asphalt the way a house vacuum smooth floor attachment feels on tile when on the grout lines. Kind of stuck to it. 70 - 95 mph. Feels planted. Like a big shop vacuum with the same attachment on as above on smooth marble floor. Effort need to move the wand. 100 -105 mph. Felt stuck to the road. Like a magnet to the top of the fridge. Last edited by 68Cadillac; 10-08-2012 at 11:46 PM. Reason: added impressions. |
#56 |
Member#: 95901
SWIC
![]() Here's how the three front wire stays look from the side. ![]() When I apply ~10 kg of force the wire slack disappears. |
#57 |
Member#: 334632
Nice man, hope it works for ya
#58 |
Member#: 290592
TXIC
Vehicle:2006 WRX Wagon 2004 WRX Wagon |
That looks hella functional. I like it. nice job.
#59 |
Member#: 122684
South East
Vehicle:2006 WRB WRX w/ VF39 molested by a drunkmann |
where did you get the sheet of econo lite?.....I have been looking forever to finish my splitter and that is all I'm lacking.
and subscibed ![]() |
#60 |
Member#: 171412
Tri-State
what did you use for the air damn piece? I'm always troubled finding this piece. Is flexible right?
#61 |
Member#: 95901
SWIC
Two places carry it in my area:
Interstate Electric and Montroy Supply. Montroy had a 10mm econolite white damaged sheet in their warehouse so I purchased from them. If you need a list of distributes in your area email the manufacturer Laminators Inc: cheryl.leblanc@laminatorsinc.com Static-Dissipative UHMW (Ultra-high-molecular-weight) Sheet, 1/8" Thick |
#62 |
Member#: 95901
SWIC
![]() Added a lip cap so I wasn't rolling 'round with sharp aluminum edges all round the lip. Glue and rivets to attach. Tape is temporary 'til the glue sets. ![]() ![]() ![]() Custom made tire air dams. Probably a aerodynamic pipe dream that they'll work at the speeds I'll see at the HPDE. I set them to ride 20 mm of the road, which turned out to be a bit too low. The road is slowly sanding with every aggressive corner I take. Eventually they'll be ground down to the perfect height, but 'til then I'm dragin' plastic around every corner. If I' were to made them again I'd go 30 - 35mm off for a start. |
#63 |
Member#: 256810
International
Wow Great job!!!
#64 |
Member#: 95901
SWIC
Video of the testing session.
#65 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
#67 |
Member#: 247023
MAIC
Vehicle:2007 STi OBP |
Super sexy man!! Does this replace your stock splash guard as well??
#68 |
Member#: 29355
NWIC
Vehicle:2003 GD6 Hate chall but i'mma maintain |
i'm wondering if the exposed hardware negates the aerodynamic effect of the splitter at track speeds. like, if it would just be better to use a more rigid material.
#69 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
No. |
#70 |
Member#: 29355
NWIC
well i guess i don't mean negate... i know the splitter is going to still split the air to increase the velocity of the air that goes under the car and provide more downforce... i just mean that literally any splitter will do that as long as it stays rigid. i'm wondering if the exposed wires and bolts sap more speed through drag than would be sapped through inertia of a heavier material or extra cd of a different design.
my bad, i didn't word that well. |
#71 | |
Member#: 45323
South East
#72 |
Member#: 190019
NESIC
Vehicle:07 STi swp |
#73 | |
Member#: 95901
SWIC
Some of the air that would have hit above the splitter slips under increasing the velocity of that air passing under the splitter. Faster Air = Lower Pressure. Here's a video of car in a wind tunnel showing this. |
#74 |
Member#: 95901
SWIC
Other than Alumalite/Econolite to make the splitter. If I were to make another one in the future I'd consider looking at:
Tegris . NASCAR uses this for splitters. It's pricey though. ![]() or Plascore AA3.6-80. Great because it has a hexagonal core. It's also recommended by Turn in Concepts. or just lay my own up in Carbon/Kevlar with Divinycell Foam for a core |
#75 |
Member#: 337127
Vehicle:05 STI Wrb |
Came out clean! Glad to know it does make a difference
| Thread Tools | |
| Display Modes | |
| WTB: 05 CGM Front Bumper, Driver Fender, Front Bumper Beam, Splitters, Fog Covers | elhalisf | Private 'Wanted' Classifieds | 0 | 08-30-2008 07:38 PM |
| WTT: My STI PSM Front bumper with splitters for a 04-05 wrx bumper | eshtog | North West Impreza Club Forum -- NWIC | 7 | 08-19-2005 01:56 PM |
| STi front bumper wind splitters | RexSex | Private 'Wanted' Classifieds | 4 | 03-17-2005 02:04 PM |
| WTB: Silver STi front bumper wind splitters | RexSex | Private 'Wanted' Classifieds | 0 | 03-17-2005 08:03 AM |
| 2004 WRX/STi Front Bumper plus Splitter and Fog Cover | YoSmiley | Private 'Wanted' Classifieds | 1 | 03-09-2004 11:07 AM |
